Old 10th May 2013, 07:42   #17141  |  Link
techno1
Broken City...Failed video encode, aborted
Haven't had a glitch in ages and I usually do 2-3 rebuilds a week. This one has me stuck. Ripped twice, same result.
Here's the log:
[05/09/13] BD Rebuilder v0.44.04 (beta)
[22:19:04] Source: BROKEN_CITY_00800
- Input BD size: 30.69 GB
- Approximate total content: [01:48:41.515]
- Target BD size: 23.44 GB
- Windows Version: 6.1 [7600]
- MOVIE-ONLY mode enabled
- Quality: High Quality (Default), Two Pass
[22:19:11] PHASE ONE, Encoding
- [22:19:11] Processing: VID_00800 (1 of 1)
- [22:19:11] Extracting A/V streams [VID_00800]
- [22:23:51] Reencoding video [VID_00800]
- Rate/Length: 23.976fps, 156,360 frames
- Bitrate: 27,987 Kbs
- [22:23:51] Reencoding: VID_00800, Pass 1 of 2
- Encode failed. Aborting.
- BD-Rebuilder v0.44.04 (beta)
- AVISYNTH Version: 2.5.7.0, Ok
- HAALI Splitter: 1.11.96.14, Ok
- FFDSHOW: 3882, Ok
- AnyDVD settings check: Ok.
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
[22:23:51] - Failed video encode, aborted
AnyDV DHD 7.1.9.0
Summary for drive F: (AnyDVD HD 7.1.9.0, BDPHash.bin 13-04-02)
HL-DT-ST BD-REWH10LS30 1.00 061125099BA4D81734
Drive (Hardware) Region: 1
Current profile: BD-ROM
Media is a Blu-ray disc.
Total size: 20837312 sectors (40697 MBytes)
Video Blu-ray label: BROKEN_CITY
Media is AACS protected!
Media is BD+ protected!
AACS MKB version 36
Using local database!
Removed AACS copy protection!
Removed BD+ copy protection!
Blu-ray Java signatures fixed!
BD-Live deactivated!
Removed UOPs!
techno1 is offline   Reply With Quote
Old 10th May 2013, 09:49   #17142  |  Link
DK
DK's Avatar
Thanks. I'll take a look at it today.
I did Total Recall a while back and don't remember any issues... but I'll do it again with your settings.
At least one release of Total Recall 2012 in Germany was having sync issues with the "Extended Cut".
My version is one of those and I can confirm that the original Disc has this problem only when playing the extended cut.
I'm not sure what version Mark_Venture refers to but maybe converting the sound stream might make a change?
Old 10th May 2013, 14:30   #17143  |  Link
I saw that the existing Intact Video profile has a vBitrate=2000
entry. Did not know if this was a required field even if it wasn't used.
It will be ignored.
Old 10th May 2013, 17:46   #17144  |  Link
techno1
Originally Posted by Sinatrafan View Post
Soo.. it appears that a problem exists with Version 44.4.. Sigh.. it'd just be funny if I'm the only guy with this problem.
You are not alone...I am having similar failure to encode condition trying to rebuild Broken City. I went back a few revisions and 43.06 is currently working for me. I'm sure Jerry will have this sorted out shortly
Old 10th May 2013, 17:55   #17145  |  Link
Originally Posted by AmigaFuture View Post
Alternate MKV output with Intact Audio and Video is doing well from my tests with single M2TS movies. I have not viewed or listened to anything other than sampling video, audio and subtitles (SUP) and all tests look good and sound good. Complete viewing soon.
What I have noticed are movies with multiple M2TS files are extracting the first M2TS well and not reencoding. After the 1st, they are reencoding. At the moment I'm using "Paul" Unrated. Another thing I've noticed is, Paul, multiple VID's are showing in the list. That shows to me, vFormat=8 is not being respected for whatever reason. Are you able to confirm?
I'm currently using:
[00029]
Caption=MKV, Intact Video and Audio
aBitrate=*
aType=2
vFormat=8
vKeyint=Auto
cType=1
I'll check it out.
Old 10th May 2013, 17:58   #17146  |  Link
That disc, so far, is a mystery. You can't even do a simple demux/remux (with no changes whatsoever) without getting sync issues. I'm still working it.
Old 10th May 2013, 18:01   #17147  |  Link
I'll pick it up and give it a test. Can you post your config file contents?
Old 10th May 2013, 19:55   #17148  |  Link
techno1
[Options]
MODE=3
ENCODE_QUALITY=2
ONEPASS_ENCODING=0
AUTO_QUALITY=0
TARGET_SIZE=24000
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=0
DEINTERLACE=0
DTS_REENCODE=1
AC3_REENCODE=1
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=0
AVCHD=0
REMOVE_WORKFILES=1
MOVIE_ONLY_LOOP=0
REMOVE_OUTPUT=0
USE_FILTERS=0
BDMV_CERT_ONLY=1
USE_LAVF=1
IVTC_PULLDOWN=0
ASSUME_DVD_PAL=0
AUDIO_TRACK_LIMIT=1
SUBTITLE_TRACK_LIMIT=0
CUSTOM_TARGET_SIZE=24000
AUTO_BURN=1
VERSION=0.44.0.4
SD_TO_1080=0
CONVERT_WIDE=0
QUICK_EXTRAS=0
PRIORITY_CLASS=2
AUTO_BLANK=0
UNMASK_CHAPTER=0
COMPLETION_BEEP=1
MOVIEONLY_TYPE=0
ALTCRF=20
ALT_TARGET=24000
ALTMETHOD=2
ALTAUTOCROP=0
DGDECNV=0
IMGBURN_TARGET_DEVICE=e:
WIDE_PERCENT=33
WIDE_OFFSET=.40
OUTPUT_3D=0
[Paths]
WORKING_PATH=S:\BD_WORKING\
SOURCE_PATH=T:\BROKEN_CITY\
Old 10th May 2013, 20:14   #17149  |  Link
techno1
***UPDATE*** Now working with USE LAVF de-selected, as previously suggested by "SinatraFan".
-> USE_LAVF=0
[05/10/13] BD Rebuilder v0.44.04 (beta)
[11:57:31] Source: BROKEN_CITY_00800
[11:57:33] PHASE ONE, Encoding
- [11:57:33] Processing: VID_00800 (1 of 1)
- [11:57:33] Extracting A/V streams [VID_00800]
- [12:02:11] Reencoding video [VID_00800]
- [12:02:11] Reencoding: VID_00800, Pass 1 of 2
Old 10th May 2013, 22:48   #17150  |  Link
-> USE_LAVF=0
I'm ripping it right now and will encode with your settings to see what's up with LAVF encoding.
Old 10th May 2013, 23:39   #17151  |  Link
@techno1
Ok, I'm confused. I'm encoding BROKEN_CITY right now with the settings you gave me.
One thought... if your system doesn't support OpenCL it's possible that the latest release of x264 may be the culprit. Can you try the encode again -- and with fails, go to the BD Rebuilder folder and cut the contents of the LASTCMD.TXT file -- and then paste it into a DOS window. That way you should be able to see what specific error you're getting. I added a dummy OpenCL.dll file to the x264 folder, and that should have by-passed that issue in x264, but you never know.
If OpenCL is the issue, you can replace X264.EXE and X264-64.EXE with the one that was distributed with v0.43.06. I'm expecting a new X264 with the OpenCL issue resolved soon. If that isn't it, I'm not sure what to say. I'm using your exact settings and pass 1 has almost completed.
Old 10th May 2013, 23:58   #17152  |  Link
Video Dude
Senior Member
jdobbs, would it be possible to add an option or a hidden option in BD-RB to disable OpenCL. I think the command switch for x264 is --no-opencl ?
The reason is I built a silent PC with a passive cooled nvidia card (no fan). I try to avoid gpu processing for an extended period of time as not to overheat my card and crash my system. My card supports OpenCL and I'm not sure how to tell BD-RB to disable OpenCL in x264.
Video Dude is offline   Reply With Quote
Old 11th May 2013, 00:02   #17153  |  Link
Hmm... I don't see that option in the help and I'm not sure if it would help.
I do think I can get around the problem, though. Normally people use LAVF in order to execute the 64 bit version of X264. I included only the 32 bit DLL. I'll put both the 32 and 64 bit version in the next release and enable the one that matches the system at startup.
Old 11th May 2013, 00:17   #17154  |  Link
AmigaFuture
AmigaFuture's Avatar
I'll check it out.
Thank you.
Old 11th May 2013, 01:48   #17155  |  Link
BD Rebuilder v0.44.05 (beta)
I have updated the first post of this thread with a link to the latest release of BD-RB (v0.44.05). Changes for this version:
- Corrected an error in which ALTERNATE output
  to an MKV file with MKV_MUXSUPS selected and
  a resize specified would cause a failure with
  an MKVMERGE error.
- Corrected an issue in which zero length files
  could be created during ALTERNATE encoding.
- Fixed an error in which some movie-only jobs
  that should use original audio may reencode.
- Fixed an issue in which 3D ALTERNATE output
  to DVD-5/9 was not working (encode error).
- Added the capability to perform 3D backups at
  full resolution (Full Side-By-Side and Full
  Over/Under)(default is HALF, as that is what
  most players expect).  Note: This option will
  ONLY work on ALTERNATE MKV & MP4 output that
  has vFormat set to NO-RESIZE. FULL-3D is meant
  mainly for full HD 3D archiving.
- Corrected an issue related to international
  decimal conversion of framerates during the
  IMPORT function.
- Corrected an error in which ALTERNATE encodes
  using vFormat=8 (intact) was not working on
  multipart sources.
- Added a workaround so that 64 bit LAVF can be
  used on systems that don't support OpenCL.
Old 11th May 2013, 02:03   #17156  |  Link
techno1
@techno1
No, my onboard ATI Radeon HD 4290 chipset does NOT support OPENCL.
LASTCMD:
Old 11th May 2013, 02:05   #17157  |  Link
I believe that in BD-RB the OpenCL would only apply if you have selected LAVF output. Otherwise the rendering is done by DGDecNV or Directshow. But, if there truly is a "--no-opencl" parameter you can add it by putting the lines below in your INI file:
TWEAK_PASS_ONE=--no-opencl
TWEAK_PASS_TWO=--no-opencl
Old 11th May 2013, 02:06   #17158  |  Link
LASTCMD:
Download the new BD-RB version and you should be ok even with LAVF.
Old 11th May 2013, 02:07   #17159  |  Link
AmigaFuture
Beauty, eh! Thank you. Testing.. :-D
Old 11th May 2013, 02:44   #17160  |  Link
Video Dude
Senior Member
Thanks jdobbs.
I have not tested --no-opencl yet in the current build of x264, but I did see a number of references to the parameter on the forum, like this one:
http://forum.doom9.org/showthread.ph...55#post1575155
