Old 6th November 2013, 19:49   #18121  |  Link
RobertM
Originally Posted by Darth_Emma View Post
Can you tell me where the config.ini file is? I can't seem to locate it on my system. (Sorry to sound like such a noob.)
Look in the same folder as BDRB.exe for the BDREBUILDER.INI file. This file holds your config settings for BDRB.
What audio setting should I select rather than the HD audio? I'd be happy to use another audio setting to get around this issue.
On the setup screen in BDRB de-select the "Keep HD audio" option.
Old 6th November 2013, 21:35   #18122  |  Link
I turned off MSSE/Defender antivirus and tried again (only thing I'm running for antivirus). Same error.
I really appreciate your help.
It's in the installation path of BD-RB and it's called BDREBUILDER.INI.
But you can get to it by selecting "View/Edit Config File" from the FILE menu in BD-RB. Just cut-and-paste the contents into a post here.
Old 6th November 2013, 22:01   #18123  |  Link
Nico8583
Here is my config file :
[Options]
VERSION=0.44.0.17
MODE=3
ENCODE_QUALITY=3
ONEPASS_ENCODING=0
AUTO_QUALITY=0
TARGET_SIZE=23500
AUTO_BURN=2
PRIORITY_CLASS=0
AUDIO_TO_KEEP=fra;fre;
SUBS_TO_KEEP=fra;fre;
SD_CONVERT=0
OPEN_GOP=1
RESIZE_1080=0
DEINTERLACE=1
SD_TO_1080=0
CONVERT_WIDE=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=1
AVCHD=1
REMOVE_WORKFILES=1
MOVIE_ONLY_LOOP=0
REMOVE_OUTPUT=1
USE_FILTERS=0
BDMV_CERT_ONLY=1
USE_LAVF=0
IVTC_PULLDOWN=0
ASSUME_DVD_PAL=0
UNMASK_CHAPTER=0
COMPLETION_BEEP=0
DGDECNV=0
OUTPUT_3D=0
AUDIO_TRACK_LIMIT=0
SUBTITLE_TRACK_LIMIT=0
CUSTOM_TARGET_SIZE=47000
[Paths]
SOURCE_PATH=D:\ORIGINAUX\FAST_AND_FURIOUS_6_G51\
WORKING_PATH=F:\RIPS\
I have made Star Trek this afternoon and no problem but it was not multiple parts, so perhaps is multiple parts movies ?
Fast & Furious 6 (French Blu ray) contains short and long version, with parts shared between the 2 versions for information. I select playlist 00800 for short version, keep DTS audio and french subtitle and I backup movie only.
Nico8583 is offline   Reply With Quote
Old 6th November 2013, 22:19   #18124  |  Link
Darth_Emma
Here it is. I very much appreciate your help.
[Options]
VERSION=0.44.0.17
MODE=3
ENCODE_QUALITY=0
ONEPASS_ENCODING=2
AUTO_QUALITY=1
TARGET_SIZE=23500
AUTO_BURN=0
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=eng;
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=0
RESIZE_1440=0
RESIZE_720=0
DEINTERLACE=1
SD_TO_1080=0
CONVERT_WIDE=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=0
AVCHD=1
REMOVE_WORKFILES=0
MOVIE_ONLY_LOOP=1
REMOVE_OUTPUT=0
USE_FILTERS=0
BDMV_CERT_ONLY=0
USE_LAVF=0
IVTC_PULLDOWN=0
ASSUME_DVD_PAL=0
UNMASK_CHAPTER=0
COMPLETION_BEEP=0
DGDECNV=0
OUTPUT_3D=0
NEROAAC=0
SUPTITLE=0
AUDIO_TRACK_LIMIT=1
SUBTITLE_TRACK_LIMIT=1
CUSTOM_TARGET_SIZE=23500
QUICK_EXTRAS=0
[Paths]
WORKING_PATH=D:\TEMP\
SOURCE_PATH=D:\MY MOVIES\TEMP\MONSTERS_UNIVERSITY\
Darth_Emma is offline   Reply With Quote
Old 6th November 2013, 22:39   #18125  |  Link
Darth_Emma
I do not have that check box on my BDRB set up screen.
Under Audio encoding I have 5 options:
"Do not convert DTS to AC3 (Blu-Ray only)"
"Do not reencode AC3 (Blu-Ray only)"
"Use 448 Kbs for AC3 encoding"
"Use 192 Kbs, 2 ch for AC3 encoding"
"Keep HD Audio for BD25/Alternate Intact"
The first 2 are checked.
Old 6th November 2013, 23:22   #18126  |  Link
AmigaFuture
AmigaFuture's Avatar
Check that.
Old 7th November 2013, 01:33   #18127  |  Link
Darth_Emma
Originally Posted by AmigaFuture View Post
Check that.
I believe the idea is to not use the HD audio to stop the BDRB from reencoding the video.
Old 7th November 2013, 03:40   #18128  |  Link
AmigaFuture
Keep HD isn't checked and Uncheck your first Check. Try that.
Old 7th November 2013, 06:12   #18129  |  Link
RobertM
I have all 5 of those audio options unchecked.
The practical reason to un-check the "HD Audio" option is that it reduces the size of the audio tracks (by down-converting to AC3 640), without making any difference whatsoever to what you actually hear. Some people will argue about this, but all the objective testing says there is no difference at all. If you think you have golden ears, and are willing to spend big bucks on digital patch cords and huge speaker cables, then you might want to keep the HD audio tracks. But you'll likely be degrading the video quality by doing so, and this is more likely to be noticeable.
Old 7th November 2013, 08:37   #18130  |  Link
Crocluvr92
That's almost assured to be a heat related issue or some other system instability. If you are overclocked, slow it down a bit. If not, check your heatsink etc.
I checked my heatsink and downloaded CoreAVC and yet I still get the error! This never used to happen even with the new beta. Here is my log
[11/07/13] BD Rebuilder v0.44.17 (beta)
[00:57:45] Source: LAST_SAMURAI
- Input BD size: 29.19 GB
- Approximate total content: [04:39:20.710]
- Target BD size: 23.31 GB
- Windows Version: 6.1 [7601]
- Auto Quality: Good (Very Fast), Two Pass
[00:57:47] PHASE ONE, Encoding
- [00:57:47] Processing: VID_00000 (1 of 16)
- [00:57:47] Extracting A/V streams [VID_00000]
- [01:33:51] Reencoding video [VID_00000]
- Rate/Length: 23.976fps, 221,816 frames
- Bitrate: 14,440 Kbs
- [01:33:52] Reencoding: VID_00000, Pass 1 of 2
- Encode failed. Aborting.
- BD-Rebuilder v0.44.17 (beta)
- FFDSHOW: 4504, Ok
- AnyDVD settings check: Ok.
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- WAVI: Ok
- TSMUXER: Ok
[01:34:17] - Failed video encode, aborted
Crocluvr92 is offline   Reply With Quote
Old 7th November 2013, 15:09   #18131  |  Link
Well, before you posted your config I went ahead and did "Monsters University". It ran without issue. I'm not sure what to say. I'll load up your config and run it again, but I suspect it will be the same. I still suspect your anti-virus software. Files don't just "disappear" -- and about the only software (other than a virus) that removes files without your permission is anti-virus packages. Sometimes when you think they are disabled -- they really aren't. Here's the important parts of my log:
[11/06/13] BD Rebuilder v0.45.02 (beta)
[13:27:28] Source:  MONSTERS_UNIVERSITY_00800
  - Input BD size: 25.17 GB
  - Approximate total content: [01:43:47.720]
  - Target BD size: 22.95 GB
  - MOVIE-ONLY mode enabled
  - Quality: High Quality (Default), Two Pass
  - Decoding/Frame serving: DGDecNV [3-way]
  - Audio Settings: AC3=1 DTS=1 HD=1 Kbs=640
[13:27:29] PHASE ONE, Encoding
 - [13:27:29] Processing: VID_00875 (1 of 132)
 - [13:27:29] Extracting A/V streams [VID_00875]
   - Extracting A/V to M2TS [VID_00875]
   - Extracting A/V from M2TS [VID_00875]
 - [13:56:37] Reencoding video [VID_00875]
   - Rate/Length: 23.976fps, 3,176 frames
   - Bitrate: 21,297 Kbs
 - [13:56:37] Reencoding: VID_00875, Pass 1 of 2
 - [13:57:17] Reencoding: VID_00875, Pass 2 of 2
 - [13:59:32] Video Encode complete
 - [13:59:32] Processing audio tracks
 - [13:59:32] Processing: VID_00876 (2 of 132)
 - [13:59:32] Extracting A/V streams [VID_00876]
 - [13:59:40] Reencoding video [VID_00876]
   - Rate/Length: 23.976fps, 395 frames
   - Bitrate: 21,344 Kbs
 - [13:59:40] Reencoding: VID_00876, Pass 1 of 2
 - [13:59:46] Reencoding: VID_00876, Pass 2 of 2
 - [14:00:03] Video Encode complete
 - [16:17:50] Reencoding video [VID_01138]
   - Rate/Length: 23.976fps, 14,717 frames
   - Bitrate: 19,769 Kbs
 - [16:17:50] Reencoding: VID_01138, Pass 1 of 2
 - [16:20:25] Reencoding: VID_01138, Pass 2 of 2
 - [16:28:39] Video Encode complete
 - [16:28:39] Processing: VID_01150 (131 of 132)
 - [16:28:39] Extracting A/V streams [VID_01150]
 - [16:28:48] Reencoding video [VID_01150]
   - Rate/Length: 23.976fps, 745 frames
   - Bitrate: 18,747 Kbs
 - [16:28:48] Reencoding: VID_01150, Pass 1 of 2
 - [16:28:57] Reencoding: VID_01150, Pass 2 of 2
 - [16:29:25] Video Encode complete
 - [16:29:25] Processing: VID_01153 (132 of 132)
 - [16:29:25] Extracting A/V streams [VID_01153]
 - [16:29:32] Reencoding video [VID_01153]
   - Rate/Length: 23.976fps, 635 frames
   - Bitrate: 25,574 Kbs
 - [16:29:32] Reencoding: VID_01153, Pass 1 of 2
 - [16:29:40] Reencoding: VID_01153, Pass 2 of 2
 - [16:30:10] Video Encode complete
[16:30:10]PHASE ONE complete
[16:30:10]PHASE TWO - Rebuild Started
 - [16:30:10] Rebuilding BD file Structure
[16:36:18] - Encode and Rebuild complete
[16:36:18] JOB: MONSTERS_UNIVERSITY finished.
Old 7th November 2013, 15:12   #18132  |  Link
I just wanted to make sure I was replicating your settings... and if you didn't have some flag set set that forced encoding (and you did) no reencoding would have been done.
Old 7th November 2013, 15:43   #18133  |  Link
Capsbackup
It has always been said to NOT have any other codec packs installed, only the ones on the first page of this thread!
Old 7th November 2013, 16:19   #18134  |  Link
I tried Monsters U again by ripping the movie as files to the hard drive. Then I used BDRB to encode movie only (25BD). I got the exact same error with the same missing file. Here are the last few lines of the log file...
[21:39:30]PHASE TWO - Rebuild Started
- [21:39:30] Rebuilding BD file Structure
- Failed in attempt to multiplex: MUX_MOVIE_ONLY.meta
- Can't open file: D:\TEMP\WORKFILES\00875.track_4113.264
[21:39:33] - Failed to REBUILD
I just noticed something here. The that seems to be the wrong filename for a typical remux... I'll see what happens when the job with your settings completes.
[Edit] Well... it's definitely something that is related to your INI settings. I was able to repeat it. That's good -- if I can repeat it then I can fix it.
Old 7th November 2013, 16:25   #18135  |  Link
Darth_Emma
Thanks for all your help. So, I need to know exactly what to do here. Because I'm not 100% sure where I have set the flag to force encoding. (Again, my apologies for being a noob at this.)
Do I need to uncheck all 5 of the options under "Audio encoding"? I was running BD-RB with the first 2 audio options checked assuming it would produce better audio quality... I have a 7.1 set up.
I went back and reread the FAQ and I think I should have unchecked all of them. I just want to confirm that.
BTW, I'm off to donate to the BD-RB Paypal to get the Pro version. You have been awesome and I really appreciate your help.
Old 7th November 2013, 16:55   #18136  |  Link
You don't have to do anything. It's obviously a bug in BD-RB and I'm working on it.
I'll be appreciative of any donation -- but remember, there is no "Pro" version of BD-RB. It is currently based entirely on voluntary donations.
Old 7th November 2013, 17:03   #18137  |  Link
Darth_Emma
Thank you.
Old 7th November 2013, 17:30   #18138  |  Link
I don't get the connection to CoreAVC at all...
Old 7th November 2013, 17:42   #18139  |  Link
HWK
HWK's Avatar
My guess would be user checked heatsink and still it didn't work. Then OP probably thought let me try with coreavc since it can decode h.264 files as well.
Old 7th November 2013, 17:44   #18140  |  Link
HWK
HWK's Avatar
- FFDSHOW: 4504, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- WAVI: Ok
- TSMUXER: Ok
Uninstall all the codecs pack including ffdshow and Haali Matroska Splitter and then reinstall only ffdshow and Haali Matroska Splitter from forum first page.
http://forum.doom9.org/showthread.php?p=1227473#post1227473
