Old 29th May 2009, 09:34   #261  |  Link
deank
Programmer (or just 教务长)
deank's Avatar
Make sure you've read all things I posted in the 1st page of this thread.
1) Load your file
2) Click the "QUEUE" button
3) Then you can click "START"
This allows you to add multiple files (to the queue list) and process them in one.
Old 30th May 2009, 09:55   #262  |  Link
rendez2k
rendez2k's Avatar
Think I'm being a bit dim with this: my input video is 1920x800, and uncrop value is 1920x1080 but my video was still at the wrong pixel size after processing. Should it not be 1920x1080?
rendez2k is offline   Reply With Quote
Old 30th May 2009, 09:58   #263  |  Link
deank
deank's Avatar
Try to 'force' the uncrop by selecting "1920x800" in "resize" drop-down. By default it is selected, but there is another 1920x800 after it - use the second.
Old 31st May 2009, 16:50   #264  |  Link
ericd
1) Load your file
oupss... i forgot the queue button sorry deank an thx again for our work..
ericd is offline   Reply With Quote
Old 2nd June 2009, 16:09   #265  |  Link
deank
deank's Avatar
For questions and support, please visit uncropMKV forum:
http://multiforum.deanbg.com/viewtopic.php?f=3&t=3
Old 9th June 2009, 19:26   #266  |  Link
deank
deank's Avatar
Uncrop/resize/reencode functionality is now added to multiAVCHD to ease the process of converting (mkv/mp4) files to compliant video, required by AVCHD/BD standards.
More...
Old 5th July 2009, 21:09   #267  |  Link
maldino800
Hello deank
Why my laptop shut down after afew minnutes when I use uncropMKV program??
maldino800 is offline   Reply With Quote
Old 5th July 2009, 21:29   #268  |  Link
deank
deank's Avatar
Because it was on batteries?!
How could you expect me to be able answer that
Old 5th July 2009, 21:36   #269  |  Link
maldino800
hhhhhhh sorry.but the batteries is on all times.may be this program need the more power of prosessor,because my pc be very hot.
Old 5th July 2009, 21:47   #270  |  Link
deank
deank's Avatar
Yes, it needs a lot of processing power and if you're using a laptop it should have good ventilation. It is possible it shut-off because of overheating.
Old 5th July 2009, 21:54   #271  |  Link
maldino800
Thank you deank.this program is very great and just I need it.before I used mkv2vob and it was takes a very long times,over 20 hours(mkv 4gb) with encode video...but now with this program just a few hour 2 or 3 hour
Old 6th July 2009, 11:49   #272  |  Link
maldino800
Hello dean.
I sucsesful uncroped one film 1920*1040 to 1920*1080,but when I am playing it in ps3 the film stopped after about 1 hour,I am trying with tow films,but still the same problem,,I used this setting cropT/B=0 .resize=1920*1080 . uncrop to=1920*1080 and the other default,,where is the proble??I can not use crop T/B because 1040 it means 40 divided by 2 =20,and ther is no have 20 in the cropT/B text box,so what shoul I do?
is this setting correct??when I will use trim end?
[IMG][/IMG]
Old 6th July 2009, 12:16   #273  |  Link
deank
deank's Avatar
Such resolutions may not need uncropping... 1920x1040 is really close to 1080p so you won't notice it in PS3.
No, you don't need to set the "Crop T/B" to anything than "0". Crop "CROPS" your original video, and you don't need that. This option is useful if your video was 1920x1100 for example.. then Crop 10 will remove 20 pixels...
How big is the output -uncropped.mkv?
Old 6th July 2009, 12:28   #274  |  Link
maldino800
But I must change the resolution to 1920*108 because if I use 1920*1040 and when I use tsmuxer or mkv2vob the results is a big black or green bar at the button on video...just 1920*1080 and 1280*720 results without black and green bar..
input video was 4.3gb
uncroped output video was 2 gb way?
Can I use trim end with all types resolutions?
Old 6th July 2009, 12:31   #275  |  Link
deank
deank's Avatar
Yes, you can... i don't know how 40 pixels are a 'big black/green' bar... but anyway.
Old 6th July 2009, 12:42   #276  |  Link
maldino800
now if I have mkv with resolution 720*544 wich setting is good for quality of video without black,green bar?
crop T/B =?
resize=?
uncrop to?
Bitrate=?
Old 6th July 2009, 12:56   #277  |  Link
deank
deank's Avatar
If you're in a PAL area (have PAL player) and if the FPS of your video is PAL (25fps) then you should use uncrop to 720x576, otherwise you can
1) resize to 720x480
or
2) crop 32 pixels from top and bottom and get it to 720x480.
Old 6th July 2009, 13:17   #278  |  Link
maldino800
or
I am sorry I was wrong,confused...the resolution is 1280*544
so wich setting will be good,I am in pal area??
Old 6th July 2009, 13:48   #279  |  Link
deank
deank's Avatar
uncrop to 1280x720... what else...
Old 6th July 2009, 13:54   #280  |  Link
maldino800
so you mean
CropT/B =0
resize=1280x720
uncrop to=1280x720 ??
avchd, bdmv, compliant, mkv, multiavchd
