Old 28th March 2012, 10:15   #641  |  Link
mike20021969
Are we getting close to the next stable?
mike20021969 is offline   Reply With Quote
Old 29th March 2012, 00:10   #642  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
It's done when it's done
Old 30th March 2012, 23:26   #643  |  Link
LoRd_MuldeR
Software Developer
LameXP v4.04 Beta-11:
Changes between v4.03 and v4.04:
* Added support for the QAAC Encoder, requires QuickTime v7.7.1 or newer (see FAQ doc for details)
* Added Chinese and Taiwanese translations, thanks to 456Vv <123@456vv.com>
* Added experimental support for dcaenc, created by Alexander E. Patrakov <patrakov@gmail.com>
* Added CSV export/import for Meta tags (see context-menu on the "Source Files" tab)
* Added a button to modify the current output folder path in an edit box
* Updated Qt runtime libraries to v4.8.0 (2011-12-15), compiled with MSVC 10.0
* Updated LAME encoder to v3.99.5 Final (2012-02-28), compiled with ICL 12.1.7 and MSVC 10.0 (details)
* Updated MediaInfo to v0.7.54 (2012-03-13), compiled with ICL 12.1.7 and MSVC 10.0
* Updated SoX to to v14.4.0 (2012-03-04), compiled with ICL 12.1.7 and MSVC 10.0
* Updated mpg123 decoder to v1.13.6 (2011-03-11), compiled with GCC 4.6.1
* Updated Monkey's Audio binary to v4.11 (2011-04-20)
* Updated Musepack decoder to revision 475 (2011-08-10), compiled with ICL 12.1.6 and MSVC 10.0
* Updated GnuPG to v1.4.12, compiled with GCC 4.6.1
* Implemented coalescing of update signals to reduce the CPU usage of the LameXP process (details)
* Run more than four instances in parallel on systems with more than four CPU cores (details)
* Improved handling of different character encodings for Playlist and Cue Sheet import
* Tweaked directory outline on "output folder" tab for improved performance (hopefully)
* Improved LameXP inter-process communication by adding queue support
* Workaround for a bug that causes MediaInfo to not detect the duration of Wave files (64-Bit only)
* Prevent LameXP from blocking a system shutdown (encoding process is aborted, if necessary)
* Improved internal handling of MediaInfo output, including extraction of cover art
* Fixed a very rare "live-lock" situation in early initialization code
In one of my tests, the latest tweaks could reduce the number of file system operations that were needed to initialize the directory outline from more than 20,000 to about 3,500 (as measured by ProcessMonitor). The actual speed-up may not be as high as these numbers may indicate, because Windows itself seems to do some caching to speed-up these file system operations. Still there should be a decent speed-up. Feedback is welcome...
Old 31st March 2012, 23:49   #644  |  Link
mike20021969
LameXP v4.05 has been released
The installer has certainly shrunk - 1.5MB compared with 15.8MB.
And the program launches ultra quick.
Didn't we used to be able to encode to mp4 using AAC?
I can only seem to do mp3 for some reason.
EDIT - I just noticed the changes. Oh well, back to the previous version for me.
Sorry, but 4.05 is a gigantic step backwards if ever there was.
Old 1st April 2012, 04:09   #645  |  Link
Taurus
Taurus's Avatar
Har,har,har,
Old 1st April 2012, 04:32   #646  |  Link
lethedoom
lethedoom's Avatar
re flac
I nearly always need to encode flac files to mp3 and I value the import metadata feature added during 4,04 beta development. Since 4.04 beta license is time limited and no 4.04 final seems to have been offered ( 4.03 final-->4.04 betas -->4.05 final ) is my only option to revert to 4,03 final and use other applications to amend tags ?
Again, thank you for your generosity in providing this very useful free application for many years and valued tutelage.
best wishes for your efforts.
lethedoom
I just remembered today is already April 1 in your time zone--Is the de facto termination of the v 4.04 development process a joke ?
lethedoom is offline   Reply With Quote
Old 1st April 2012, 05:06   #647  |  Link
boyumeow
boyumeow's Avatar
* Major codec clean-up: Dropped all encoders, except for LAME MP3 and Ogg Vorbis
Were U facing some problems or U are just re-writing LameXP? Anyway, do take good care of yourself.
P.S. Can U add 'Normalization' in the 'config' page, Thanks in advance.
boyumeow is offline   Reply With Quote
Old 1st April 2012, 09:32   #648  |  Link
mr soft
mr soft's Avatar
Originally Posted by Taurus View Post
Har,har,har,
+1
got me too
mr soft is offline   Reply With Quote
Old 1st April 2012, 20:31   #649  |  Link
cengizhan
That have you done? This version is 1st April joke.
cengizhan is offline   Reply With Quote
Old 2nd April 2012, 08:11   #650  |  Link
boyumeow
boyumeow's Avatar
Bug report:
expiered!
Old 2nd April 2012, 08:41   #651  |  Link
Octo-puss
Why did you drop all the encoders? Sounds like months of work wasted.
edit: that's what happens when I catch up on forums with delay. (and only read the first line on top of that lol)
Octo-puss is offline   Reply With Quote
Old 2nd April 2012, 16:06   #652  |  Link
LoRd_MuldeR
Software Developer
Originally Posted by boyumeow View Post
Bug report:
expiered!
Typo will be fixed for next year's version
Old 3rd April 2012, 22:03   #653  |  Link
LoRd_MuldeR
Software Developer
LameXP v4.04 Beta-12:
Old 4th April 2012, 08:22   #654  |  Link
mr soft
mr soft's Avatar
Thank you , output folder is now opening a lot faster.
Old 4th April 2012, 21:27   #655  |  Link
LoRd_MuldeR
Software Developer
Good to know
Old 6th April 2012, 02:12   #656  |  Link
LoRd_MuldeR
Software Developer
LameXP v4.04 Beta-14:
http://sourceforge.net/projects/lame...29/2012-04-06/
Old 9th April 2012, 19:36   #657  |  Link
manolito
manolito's Avatar
The only thing I can say is that personally I wouldn't infect my computer with a mess like iTunes or QuickTime...
Totally agreed...
But according to the latest test results, QAAC seems to have an edge over Nero and even over FHG.
Do you know if there is a way (maybe some unofficial hack) to use QAAC without actually having to install QuickTime?
Cheers
manolito
Old 9th April 2012, 21:12   #658  |  Link
LoRd_MuldeR
Software Developer
Originally Posted by manolito View Post
Totally agreed...
Cheers
manolito
In order to use QAAC, you need an "Apple Application Support" installation. You don't need QuickTime or iTunes, but AFAIK these are the only official downloads that include "Apple Application Support".
If you already have an installation of "Apple Application Support" on another system, you can copy over the files. But it won't be possible redistribute these files...
Old 9th April 2012, 22:13   #659  |  Link
littleD
littleD's Avatar
Since forever iTunes instalation was selfexecutable archive. Just unpack it and u will get every program instalation separated. You may install Apple Application Support as standalone but dont ask me how to install QTime aac codec, i used iTunes two to three versions before. I bet there are some instructions over internet.
To install iTunes without QuickTime use bat file with code: msiexec.exe /i iTunes.msi /quiet . Old hacks always the best http://www.mydigitallife.info/downlo...out-quicktime/
littleD is offline   Reply With Quote
Old 10th April 2012, 15:56   #660  |  Link
LoRd_MuldeR
Software Developer
LameXP v4.04 Beta-15:
http://sourceforge.net/projects/lame...29/2012-04-10/
* Updated MediaInfo to v0.7.56 (2012-04-08), compiled with ICL 12.1.7 and MSVC 10.0
