#6061 | Link | |
Aleksoid / Volt can you please let MPC-BE show all the mpls in descending order of the duration, there's no point in hiding some of the mpls as long as MPC-BE can't chose, or even show as it seems, the correct main movie's mpls for sure, without a directshow Bluray disc navigator filter ? P.S. I will not send another sample cause the fix seems very easy to me: let MPC-BE show all the mpls in descending order of the duration
Windows 10 19042.508 x64, HD7790 Adrenalin 2020 Edition 20.9.1, HDMI Full RGB 4:4:4 |
#6062 | Link | |
1) duration > 3 min 2) mpls don't contain duplicate .m2ts files entry.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /AMD Radeon R9 16Gb@3200 /Kingston 500Gb M.2 /GTX 1650 /Samsung U28R550UQI /LG 47LM620T /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 |
#6063 | Link | |
#6066 | Link |
@wushantao
Thanks. Updated in r4392.
MPC-BE 1.5.6 (build 6000) stable and Nightly builds | Video Renderer | Image Source | Script Source |
#6067 | Link | |
I made a new screenshot of r4391. Here you can see that only the close symbol is larger than the button. The button itself should be fine. Maybe it helps you, although I am pretty sure you know it already. I beg to fix this little cosmetic issue. Thank you devs |
#6068 | Link | |
#6069 | Link | |
#6070 | Link |
I'm glad
#6071 | Link |
Updated german translation based on r4402
#6073 | Link |
Feature requests:
Magically yours Raistlin Last edited by GCRaistlin; 14th February 2019 at 08:45. |
#6075 | Link |
All working good.
#6076 | Link |
Perhaps you have an active playlist window. Click on the main window and check again.
#6078 | Link |
Thanks for the updates for High DPI settings
There are 3 additional places which could do with similar tweaks. Flybar and header within settings dialog; ![]() Additional thought, is that header text even required within the dialogs now? OSD; ![]() I have set font size 18 for OSD which is likely slighly bigger than default. At 100% its good and 250% its a bit too big. Windows is set with 250% within the above snips. Thanks
Windows 10 Pro x64 (1809), CPU: Core i7 6700K, GPU: GeForce GTX 980 /w 417.71, Audio: HDMI to Yamaha RX-A3060 (5.1) Last edited by VipZ; 11th February 2019 at 20:59. |
#6079 | Link |
I have been using MPC BE for more than a year without issues but after upgrading to a 4K screen, I am now facing Desktop Window Manager crashes when using this player. I figured out a way to trigger the crash consistently, basically in full screen (Madvr standard, not exclusive) when I make the seek bar appear there is a very brief white flash across the entire screen, like a random white frame. This doesn't make the Desktop Window Manager crash, but if I make the seek bar appear and disappear for 5-10 times in a row, I can trigger the crash consistently. After the Desktop Window Manager crashes, the video's audio still plays in the background with the last frame stuck on the screen. The mouse is displayed on the screen but it cannot interact with anything and the application can't be closed, forcing me to cut the power the PC. I tried to reset the player's settings to their defaults, I also tried to run the standard EVR but I can still trigger the crash. The crash is limited to MPC BE, all the other players, 3D applications, games are stable. The event viewer reports the following: Faulting application name: dwm.exe, version: 10.0.17763.1, time stamp: 0xe52aabf3 Faulting module name: KERNEL32.DLL, version: 10.0.17763.292, time stamp: 0x7c9c19c8 Exception code: 0xe0464645 Fault offset: 0x00000000000181f4 Faulting process id: 0x230 Faulting application start time: 0x01d4bb2c84b487c9 Faulting application path: C:\WINDOWS\system32\dwm.exe Faulting module path: C:\WINDOWS\System32\KERNEL32.DLL Report Id: 7a653986-1b58-42ac-84ea-8521496361dd Faulting package full name: Faulting package-relative application ID: Any suggestion on how to solve this issue would be appreciated. System: i7 7820X GTX 1080 16 GB DDR4 3400 Windows 10 v 1809 with the latest updates applied. MPC BE 1.5.3 (build 4419) beta (the current stable release crashes as well). Last edited by artins90; 17th February 2019 at 00:50. |
#6080 | Link |
About osd text - it's scale by DPI.
