Old 12th January 2020, 09:17   #7041  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Originally Posted by JarrettH View Post
Did you solve this? I had the same problem tonight (Windows 10, BE 1.5.4). WASAPI Exclusive = laggy video, WASAPI Shared = all fine. My DAC wouldn't detect the sample rate in Shared mode, in Exclusive mode it does but that's unusable. Changing the device buffer has no effect.
@Aleksoid1978
Try this build - it's create log on Desktop. Upload log for me after.
https://yadi.sk/d/EONq2cmaYADEjQ
I7 2600K@4.2 /Asrock P67 Extreme4 Gen 3 /Kingston HyperX 8Gb 1866 (4x2) Kit /OCZ Vertex 3 256Gb /GTX 1650 /Samsung U28R550UQI /LG 47LM620T /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Old 12th January 2020, 18:48   #7042  |  Link
JarrettH
Thanks!
https://drive.google.com/file/d/1XoW...ew?usp=sharing
I played the video for about 5 minutes.
Is "DefaultDevicePeriod = 10.00 ms" the default buffer?
Old 12th January 2020, 22:25   #7043  |  Link
999999999
Go here and download some builds of previous versions, find the one where the performance got worse and report back here with the build number.
Thanks but yeah that was an obvious thing to do and yet, doesn't really get me a solution. There probably isn't one, and it's not worth THAT much work, with 100-something releases in that era.
I ended up just accepting that I can't hold onto an old version of MPC-BE forever if I wish to support more/better features so gave up on the prior setup, set the 750TI to max performance instead of power savings (dynamic downclocking like all modern NV cards do) for MPC-BE specifically (per-app), then if I'm going to take that power and heat penalty anyway, gives me more headroom to switch to madvr rendering and that feature set.
Regardless, what testing I did do, did show a clear correlation between this newest version of MPC-BE and loss of performance with nothing else changed. There is no mistaking when the same file starts dropping frames, stuttering with audio out of sync and substantial, simultaneous Windows GUI slowdown. Disable downclocking/Pwr-Mgmt the GPU via the power management setting in Nvidia Control Panel and all that is gone.
999999999 is offline   Reply With Quote
Old 12th January 2020, 22:28   #7044  |  Link
This could be compiler related or an unexpected and a possibly improved upon side effect. I'd recommend testing, it probably won't take long.
Old 12th January 2020, 22:45   #7045  |  Link
Klaus1189
For fast finding the last version behaving what you need, test the middle build between 1.5.3 stable and 1.5.4 stable, if this middle version does work, then try in the new middle between this and 1.5.4.
If that first middle version doesn‘t work, then try the new middle between 1.5.3 stable and the first middle.
And repeat till you found the version. I hope I wrote it understandable
Old 13th January 2020, 01:18   #7046  |  Link
Aleksoid1978
Thanks!
All look's good. Without such device i can't test and say what's wrong.
P.S. Try another app with WASAPI Exclusive Output(need use WASAPI Exclusive Event mode) - foobar, AIMP.
Old 13th January 2020, 05:00   #7047  |  Link
JarrettH
I've been using jriver with wasapi exclusive for years, but that's audio only. Oh well, I might even prefer Shared mode for movies, just that I'll have to make a shortcut to sound properties to change the sample rate initially.
Old 13th January 2020, 06:47   #7048  |  Link
wushantao
https://send.firefox.com/download/d3...DKdi7REae7hMog
there is no vcd anymore
wushantao is offline   Reply With Quote
Old 13th January 2020, 07:09   #7049  |  Link
Aleksoid1978
Originally Posted by Klaus1189 View Post
I checked with CCExtractor 0.88 and the info is definitely there, but I don't know why it doesn't show up:
00:00:03,280 --> 00:00:05,919
- SEEMS TO HAVE BEEN A BURGLARY.
- OH? WHAT OF?
2
00:00:06,000 --> 00:00:07,759
WELL, THAT'S JUST IT.
NOTHING MISSING, REALLY.
3
00:00:09,200 --> 00:00:11,559
WHAT'S HE DOING IN MANCHESTER?
4
00:00:11,640 --> 00:00:13,839
SOMETHING WITH MACHINES.
5
00:00:15,040 --> 00:00:16,199
(EXHALES)
6
00:00:21,120 --> 00:00:23,079
THE PROJECT AT THE NPL.
7
00:00:23,160 --> 00:00:25,559
I CHECKED
BUT HE WON'T SAY WHAT IT'S ON.
8
00:00:27,760 --> 00:00:29,119
PROFESSOR TURING?
9
00:00:29,200 --> 00:00:31,159
DETECTIVE NOCK, MANCHESTER POLICE.
10
00:00:35,480 --> 00:00:37,959
SERGEANT STAEHL HERE TELLS ME
YOU HAD A BURGLARY LAST NIGHT.
11
00:00:39,200 --> 00:00:40,239
PROFESSOR TURING?
12
00:00:41,200 --> 00:00:44,319
(ALAN) TAKE A STEP BACK
AND DON'T BREATHE HEAVILY.
13
00:00:44,400 --> 00:00:46,679
- BREATHE?
- (ALAN) UNDILUTED CYANIDE.
14
00:00:46,760 --> 00:00:49,959
IT WOULDN'T TAKE MORE
THAN A THIMBLEFUL TO KILL YOU.
15
00:00:51,000 --> 00:00:51,959
AH.
16
00:00:53,680 --> 00:00:56,379
- DISAPPOINTING.
- PARDON?
I am begging for help
EDIT: Seems like the second line is not displayed, perhaps after a new line is started?
Thanks for info - fixed.
Old 13th January 2020, 09:03   #7050  |  Link
mogli
Two minor convenience issues when dowloading youtube videos:
  1. Sometimes the video name has the suffix " - YouTube" added by MPC-BE, sometimes not. Why? (I don't need it and remove it when that happens.)
  2. The dialog shown while downloading the video is at the same postion as the player. However the dialog when downloading the audio always opens in the middle of the screen. The latter is mildly annoying because it usually overlays other stuff I'm currently working on and sometimes I accidently click abort and need to redownload.
Btw thanks for the latest stable version, especially remembering the sounddevice by name.
mogli is offline   Reply With Quote
Old 13th January 2020, 09:08   #7051  |  Link
Aleksoid1978
Sometimes Google API block request and app can’t parse metadata and get Title from youtube’s page.
Old 13th January 2020, 15:53   #7052  |  Link
v0lt
@wushantao
AviSynth script and AVS are two different files, but have the same extension .avs.
added:
Do you have an AVS video file that can be opened in MPC-BE or MPC-HC?
Old 13th January 2020, 17:54   #7053  |  Link
Klaus1189
Thank you, I love that project
Old 14th January 2020, 06:40   #7054  |  Link
wushantao
Originally Posted by v0lt View Post
@wushantao
added:
thx for the info
script=脚本,file=文件
i don't have any AVS files actually, this is the first time i know the AVS file.
in wiki and search, i think AVS is a file format, is a standard from a trade association by ours government......independent intellectual property rights......
strictly speaking, AviSynth script=AviSynth 脚本
but usually, we basically say that this is "AVS 脚本"(AviSynth script)
to prevent misunderstandings, i think "AviSynth 脚本" is truely better
i cant open firefoxsend right now...and dont know why...try this one...https://fil.email/iYmaArTT (with "AviSynth 脚本")
Old 14th January 2020, 07:32   #7055  |  Link
roytam1
Firefox User
MPC Video Renderer v0.3.8.1060
Description.
Changes:
Improved compatibility with third-party players.
Fixed switching supported formats for DXVA2 and D3D11 video processors during playback.
Faster statistics rendering. A pre-prepared texture with symbols is used.
it seems that it shows a black frame before showing actual frame when seeking. (environment: win7 x64, MPC-HC 1.9.0 64bit)
roytam1 is offline   Reply With Quote
Old 14th January 2020, 09:34   #7056  |  Link
Aleksoid1978
Test in MPC-BE, show screenshot with statistics(Ctrl+J).
Old 14th January 2020, 18:33   #7057  |  Link
Klaus1189
My buddy has another issue with a specific line in this sample with a Teletext subtitle:
https://drive.google.com/open?id=1_p...K3wISRnNhQ_DCG
There is the mpg file with is the sample file and he made some screenvideos using MPC-BE and Potplayer and what happend.
I downloaded 1.5.5.5000 and can reproduce that the following piece at 01:30 is showed a bit too late.
When I served under Leia,
she would say, hope is like the sun.
I beg for help, again
Old 15th January 2020, 03:58   #7058  |  Link
Aleksoid1978
Options -> Internal Filters -> Buffer length - set to 10 sec.
Default value 3 is not enough to parse end of this subtitles block and it's happened small later
Old 15th January 2020, 11:57   #7059  |  Link
Klaus1189
Thank you, it works for him
Old 15th January 2020, 18:24   #7060  |  Link
v0lt
@wushantao
Thanks. Updated in r5001.
