#7081 | Link | |
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /AMD Radeon R9 16Gb@3200 /Kingston 500Gb M.2 /GTX 1650 /Samsung U28R550UQI /LG 47LM620T /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 |
#7082 | Link |
I got new DAC recently (RME ADI 2 on USB) and I tried it with MPC Audio Renderer, but the WASAPI exclusive mode is causing stuttering in movie playback. No problems in shared mode or with other audio renderer, but then the sample rate is obviously not auto switched. How is the WASAPI implemented in MPC? Push mode or event mode? For example in foobar this DAC has problems in event mode but push mode works OK. I also tried various settings in MPC Audio Renderer including buffer sizes but it always stutters in exclusive mode with any content no matter what.
Then I tried Sanear Audio Renderer from GitHub and it works without any problems in WASAPI exclusive mode with this DAC, including auto sample rate switching. No hiccups whatsoever. But I really would like to use the internal MPC Audio Renderer - can this be fixed? I am on win10 x64 1909, MPC x64 1.5.4. |
#7083 | Link |
MPC Audio Renderer using event mode, Sanear - push. As you say, using foobar, problem with event mode. There is nothing to do. I don't have plan to implement push method.
And - i don't have such device and can't test/development to improvement.
#7085 | Link |
@Klaus1189
Please check MPCVideoRenderer-v0.4.0.1120_git2020.01.27-2e9d681.
MPC-BE 1.5.6 (build 6000) stable and Nightly builds | Video Renderer | Image Source | Script Source |
#7087 | Link | |
#7088 | Link |
Wow, thanks. Its almost there.
Stuttering is gone in exclusive mode, but there are continuous cracks in audio (on all buffer size settings). For the sample rate auto switching I have to enable the CheckBox "Do not check format support", then it works. This DAC is using 32bit format (cannot be changed in Windows) and in foobar the default HW buffer size is 200ms so maybe the code just need a little bit of tweaking. |
#7089 | Link | |
it's create log on Desktop. Playback some video 5-10 seconds and upload log for me.
#7091 | Link |
Don’t attach here, use any file hosting, like google drive or other.
#7092 | Link |
Sorry about that, this should work then:
https://uloz.to/file/79BNXS8kP3Nb/mp...DirectDownload or on google drive: https://drive.google.com/open?id=1ks...ZgtFy5ilZZxKV- Last edited by dezo; 29th January 2020 at 11:23. |
#7093 | Link |
Here new build - https://yadi.sk/d/eMpxNwmqcPn8ZA
it's have more detail log.
#7094 | Link |
Log with more details on google drive:
https://drive.google.com/open?id=1R6...k6uho6X-TuFYo9 |
#7095 | Link |
Try this build - https://yadi.sk/d/z_NWcXTNY77AKg
with different "Device buffer".
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /AMD Radeon R9 16Gb@3200 /Kingston 500Gb M.2 /GTX 1650 /Samsung U28R550UQI /LG 47LM620T /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 Last edited by Aleksoid1978; 30th January 2020 at 01:37. |
#7096 | Link |
And now it seems to be working! No more cracking.
I also tried different sample rates ranged from 44.1kHz up to 192kHz and so far so good. Only the "Do not check format support" must be enabled for the automatic sample rate to work, but that is just a cosmetic thing - considering this DAC is not very Windows friendly. Thank you very much. I really appreciate it. |
#7097 | Link |
"Do not check format support" need for some device when it's driver can't say what formats it's supported.
#7098 | Link |
In rev. 5051 add selecting WASAPI method - Event/Push.
#7099 | Link |
Updated german translation for new WASAPI method choice
#7100 | Link |
Some suggestions for MPCVR:
First tab of properties window is called "VR Options". Somehow VR first makes me first think of Virtual Reality instead of video renderer. Why not just "Options"? Is it correct that "Shader Video Processor" is only used when DXVA2/D3D11 video processor is not used for resizing? If so, I suggest to rename "Use for resizing" to something more clear like "Use this for resizing (instead of shader video processor)". I still get DVD Copy Protect Fail on Windows 7 with latest build 1122. |
