Old 31st January 2020, 17:52   #7101  |  Link
v0lt
Originally Posted by clsid View Post
I mean when DXVA2 is used for resize, then the upscaling/downscaling shader isn't used, right?
Right. Not used.
@Klaus1189
Thanks. Updated in r5052.
Old 2nd February 2020, 09:31   #7102  |  Link
wushantao
hi~
i can't find "event" and "push" from the wasapi method option in mplayerc.XX.rc.txt
can you put the strings "event" and "push" into mplayerc.XX.rc.txt?
wushantao is offline   Reply With Quote
Old 2nd February 2020, 11:54   #7103  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Originally Posted by wushantao View Post
hi~
It's technical "name" - there is no need to translate.
Old 4th February 2020, 11:17   #7104  |  Link
mpc-be build 4969 with mpc-vr 1060 closes on start when lavfilter is forced to output p010 mpc-vr settings doesn't seem to matter.
software decoding is used source is 8 bit.
found more clues video has to be "VP9" with a selected hardware decoder but it falls back to software.
so the player closes when a hardware decoder is supposed to be used but lavfilter fallback to software decoding.
Old 4th February 2020, 12:43   #7105  |  Link
Aleksoid1978
Can't confirm. Tested on latest git version - https://yadi.sk/d/462c_ERVDmAy6A
Old 4th February 2020, 18:57   #7106  |  Link
no difference on that version.
Old 4th February 2020, 22:57   #7107  |  Link
Aleksoid1978
Try latest svn MPC-BE - https://yadi.sk/d/hlf1lfC8mKU58/!_last
Old 5th February 2020, 13:47   #7108  |  Link
same but i just found this in the event viewer.
Faulting application name: mpc-be64.exe, version: 1.5.5.5060, time stamp: 0x5e3a3bc1
Faulting module name: MpcVideoRenderer64.ax, version: 0.4.0.1123, time stamp: 0x5e3958a9
Exception code: 0xc0000005
Fault offset: 0x0000000000041320
Faulting process ID: 0x1670
Faulting application start time: 0x01d5dc220df2200d
Faulting application path: C:\Program Files\MPC-BE x64\mpc-be64.exe
Faulting module path: C:\MPCVideoRenderer-v0.3.2.860\MpcVideoRenderer64.ax
Report ID: dafe5f23-ca8a-4f6a-9057-40d4e539048c
Faulting package full name:
Faulting package-relative application ID:
just to make that clear i test something every odd here with normal lavfilter settings it works.
Old 6th February 2020, 00:07   #7109  |  Link
Aleksoid1978
Test on this "set" - https://yadi.sk/d/Z6S8gGdwuUMsXA. Enable MiniDump - Options -> Miscellaneous.
If after crash MPC-BE create dump file - upload it for me.
Old 6th February 2020, 14:53   #7110  |  Link
here you go:
http://s000.tinyupload.com/index.php...59697457352508
Old 7th February 2020, 00:04   #7111  |  Link
Aleksoid1978
Show LAV Video settings & MPC VR settings.
Also give MediaInfo for your file or upload short sample.
Old 7th February 2020, 09:58   #7112  |  Link
https://abload.de/img/forcep010qmjrr.png
https://abload.de/img/forcep010mpcvroij36.png
file: http://s000.tinyupload.com/index.php...77137616059722
the file here should be hardware decoded but lavfilter is falling back to software GPU 5700 XT.
Old 7th February 2020, 10:29   #7113  |  Link
Aleksoid1978
It's working with madVR ? DXVA or software decoding ?
Old 7th February 2020, 10:40   #7114  |  Link
yes works with madVR d3d11 and DXVA2 falling back to software sending p010.
mpcVR crashes when a VP9 profile 0 stream fallback to software decoding with a different output type in this case p010.
Old 7th February 2020, 12:02   #7115  |  Link
Shark007
Shark007's Avatar
Maybe you should test with current release of the renderer v0.4.0.1124
Shark007 is offline   Reply With Quote
Old 7th February 2020, 13:00   #7116  |  Link
i didn't care about the folder name the version is the test version he wanted me to test:
Old 7th February 2020, 14:37   #7117  |  Link
v0lt
Record the log using the debug version of MPC VR and DebugView.
added:
I can’t get a crash. Win8.1, MPC-BE 5046/5063 x64 + MPC VR 1126 + LAV Video Decoder 0.74.1.13.
Nvidia GTX 950 decodes hardware - DXGI_NV12
Intel HD 4000 decodes software - P010
Old 7th February 2020, 16:06   #7118  |  Link
[\\DESKTOP-Q0AA7MI]
00000003	4.85314131	[1640] OnFocusWindowChanged to window type: k_nGameIDControllerConfigs_Desktop, AppID 413080
00000004	4.85361290	[1640] Loaded Config for Local Override Path for App ID 413080, Controller 0: D:\Steam/controller_base/empty.vdf
00000005	5.48875284	[1640] OnFocusWindowChanged to window type: k_nGameIDControllerConfigs_Desktop, AppID 413080
00000006	5.48929119	[1640] Loaded Config for Local Override Path for App ID 413080, Controller 0: D:\Steam/controller_base/empty.vdf
00000007	5.52361107	[10720] Loading modified build of detours library designed for MPC-HC player (http://sourceforge.net/projects/mpc-hc/)
00000008	5.79585218	[1640] OnFocusWindowChanged to window type: k_nGameIDControllerConfigs_Desktop, AppID 413080
00000009	5.79633141	[1640] Loaded Config for Local Override Path for App ID 413080, Controller 0: D:\Steam/controller_base/empty.vdf
00000010	6.88179541	[10720] MpcVideoRenderer64.ax(tid 30d0)       22 : Windows 10
00000011	6.88183498	[10720] MpcVideoRenderer64.ax(tid 30d0)       22 : MPC Video Renderer v0.4.0.1126 (git-2020.02.07-341bea6) x64 DEBUG
00000012	6.88190699	[10720] MpcVideoRenderer64.ax(tid 30d0)       22 : CDX11VideoProcessor::Init()
00000013	6.88197374	[10720] MpcVideoRenderer64.ax(tid 30d0)       22 : CDX11VideoProcessor::ReleaseDevice()
00000014	6.88198948	[10720] MpcVideoRenderer64.ax(tid 30d0)       22 : CDX11VideoProcessor::ReleaseVP()
00000015	6.88201666	[10720] MpcVideoRenderer64.ax(tid 30d0)       22 : CDX11VideoProcessor::ClearPostScaleShaders().
00000016	6.88236618	[10720] MpcVideoRenderer64.ax(tid 30d0)       22 : D3D11_1SDKLayers.dll could not be loaded. D3D11 debugging messages will not be displayed
00000017	6.90024233	[10720] MpcVideoRenderer64.ax(tid 30d0)       40 : CDX11VideoProcessor::Init() : D3D11CreateDevice() successfully with feature level 11.1
00000018	6.90025616	[10720] MpcVideoRenderer64.ax(tid 30d0)       40 : CDX11VideoProcessor::SetDevice()
00000019	6.90027380	[10720] MpcVideoRenderer64.ax(tid 30d0)       40 : CDX11VideoProcessor::ReleaseDevice()
00000020	6.90028811	[10720] MpcVideoRenderer64.ax(tid 30d0)       40 : CDX11VideoProcessor::ReleaseVP()
00000021	6.90031195	[10720] MpcVideoRenderer64.ax(tid 30d0)       40 : CDX11VideoProcessor::ClearPostScaleShaders().
00000022	6.90360975	[10720] MpcVideoRenderer64.ax(tid 30d0)       44 : Supported input DXGI formats (for 1080p):
00000023	6.90360975	[10720]   B8G8R8A8_UNORM
00000024	6.90360975	[10720]   B8G8R8X8_UNORM
00000025	6.90360975	[10720]   B8G8R8A8_UNORM_SRGB
00000026	6.90360975	[10720]   NV12
00000027	6.90360975	[10720]   P010
00000028	6.90360975	[10720]   420_OPAQUE
00000029	6.90360975	[10720]   YUY2
00000030	6.90363836	[10720] MpcVideoRenderer64.ax(tid 30d0)       44 : Supported output DXGI formats (for 1080p):
00000031	6.90363836	[10720]   R16G16B16A16_FLOAT
00000032	6.90363836	[10720]   R10G10B10A2_UNORM
00000033	6.90363836	[10720]   R8G8B8A8_UNORM
00000034	6.90363836	[10720]   R8G8B8A8_UNORM_SRGB
00000035	6.90363836	[10720]   B8G8R8A8_UNORM
00000036	6.90363836	[10720]   B8G8R8X8_UNORM
00000037	6.90363836	[10720]   R10G10B10_XR_BIAS_A2_UNORM
00000038	6.90363836	[10720]   B8G8R8A8_UNORM_SRGB
00000039	6.90363836	[10720]   NV12
00000040	6.90363836	[10720]   P010
00000041	6.90651941	[10720] MpcVideoRenderer64.ax(tid 30d0)       46 : CDX9Device::InitDX9Device()
00000042	6.90692711	[10720] MpcVideoRenderer64.ax(tid 30d0)       47 : Display Mode: 1920x1080, 240p
00000043	6.94155455	[10720] MpcVideoRenderer64.ax(tid 30d0)       81 :     => CreateDeviceEx() : S_OK
00000044	6.94159603	[10720] MpcVideoRenderer64.ax(tid 30d0)       82 : Graphics adapter: AMD Radeon RX 5700 XT (1002:731F)
00000045	6.94830656	[10720] MpcVideoRenderer64.ax(tid 30d0)       88 : Direct3D11 initialization successfully!
00000046	6.94965219	[10720] MpcVideoRenderer64.ax(tid 30d0)       90 : CDX11VideoProcessor::Init()
00000047	6.94973183	[10720] MpcVideoRenderer64.ax(tid 30d0)       90 : CDX11VideoProcessor::InitSwapChain()
00000048	6.95024729	[10720] MpcVideoRenderer64.ax(tid 30d0)       90 : CVideoRendererInputPin::ReceiveConnection()
00000049	6.95027208	[10720] MpcVideoRenderer64.ax(tid 30d0)       90 : CMpcVideoRenderer::SetMediaType()
00000050	6.95030499	[10720] MpcVideoRenderer64.ax(tid 30d0)       90 : CDX11VideoProcessor::InitMediaType()
00000051	6.95036221	[10720] MpcVideoRenderer64.ax(tid 30d0)       90 : CDX11VideoProcessor::ReleaseVP()
00000052	6.95239782	[10720] MpcVideoRenderer64.ax(tid 30d0)       92 : CDX11VideoProcessor::InitializeTexVP() started with input surface: NV12, 1920 x 1080
00000053	6.95294380	[10720] MpcVideoRenderer64.ax(tid 30d0)       93 : GetShaderConvertColor() started for NV12 1920x1080 extfmt:0x288d2500 chroma:0
00000054	6.95296574	[10720] MpcVideoRenderer64.ax(tid 30d0)       93 : GetShaderConvertColor() frame consists of 2 planes
00000055	6.95303440	[10720] MpcVideoRenderer64.ax(tid 30d0)       93 : GetShaderConvertColor() set chroma location MPEG-2
00000056	6.95664978	[10720] MpcVideoRenderer64.ax(tid 30d0)       97 : CDX11VideoProcessor::InitializeTexVP() completed successfully
00000057	6.95825052	[10720] MpcVideoRenderer64.ax(tid 30d0)       98 : CMpcVideoRenderer::CalcImageSize() buffer size changed from 1920x1080 to 2048x1080
00000058	6.95828390	[10720] MpcVideoRenderer64.ax(tid 30d0)       98 : CMpcVideoRenderer::SetMediaType() : upstream filter accepted new media type. QueryAccept return S_OK
00000059	6.95830059	[10720] MpcVideoRenderer64.ax(tid 30d0)       98 : CDX11VideoProcessor::InitMediaType()
00000060	6.95831680	[10720] MpcVideoRenderer64.ax(tid 30d0)       98 : CDX11VideoProcessor::ReleaseVP()
00000061	6.95860815	[10720] MpcVideoRenderer64.ax(tid 30d0)       99 : CDX11VideoProcessor::InitializeTexVP() started with input surface: NV12, 1920 x 1080
00000062	6.95900297	[10720] MpcVideoRenderer64.ax(tid 30d0)       99 : GetShaderConvertColor() started for NV12 1920x1080 extfmt:0x288ca500 chroma:0
00000063	6.95902252	[10720] MpcVideoRenderer64.ax(tid 30d0)       99 : GetShaderConvertColor() frame consists of 2 planes
00000064	6.95906544	[10720] MpcVideoRenderer64.ax(tid 30d0)       99 : GetShaderConvertColor() set chroma location MPEG-2
00000065	6.96099997	[10720] MpcVideoRenderer64.ax(tid 30d0)      101 : CDX11VideoProcessor::InitializeTexVP() completed successfully
00000066	6.99651766	[10720] MpcVideoRenderer64.ax(tid 30d0)      129 : CVideoRendererInputPin::GetAllocator()
00000067	6.99937344	[10720] MpcVideoRenderer64.ax(tid 30d0)      133 : CDX11VideoProcessor::ClearPostScaleShaders().
00000068	7.02087688	[10720] MpcVideoRenderer64.ax(tid 3810)      161 : CMpcVideoRenderer::Pause()
00000069	7.02117586	[10720] MpcVideoRenderer64.ax(tid 3874)      161 : CMpcVideoRenderer::NewSegment()
00000070	7.03836012	[10720] MpcVideoRenderer64.ax(tid 38b4)      178 : CVideoRendererInputPin::ReceiveConnection()
00000071	7.03844070	[10720] MpcVideoRenderer64.ax(tid 38b4)      178 : CVideoRendererInputPin::GetAllocator()
00000072	7.03849745	[10720] MpcVideoRenderer64.ax(tid 38b4)      178 : CDX11VideoProcessor::InitMediaType()
00000073	7.03854799	[10720] MpcVideoRenderer64.ax(tid 38b4)      178 : CDX11VideoProcessor::ReleaseVP()
00000074	7.03894234	[10720] MpcVideoRenderer64.ax(tid 38b4)      179 : CDX11VideoProcessor::InitializeTexVP() started with input surface: P010, 1920 x 1080
00000075	7.03981352	[10720] MpcVideoRenderer64.ax(tid 38b4)      180 : GetShaderConvertColor() started for P010 1920x1080 extfmt:0x288ca500 chroma:0
00000076	7.03987265	[10720] MpcVideoRenderer64.ax(tid 38b4)      180 : GetShaderConvertColor() frame consists of 2 planes
00000077	7.03992796	[10720] MpcVideoRenderer64.ax(tid 38b4)      180 : GetShaderConvertColor() set chroma location MPEG-2
00000078	7.04203367	[10720] MpcVideoRenderer64.ax(tid 38b4)      182 : CDX11VideoProcessor::InitializeTexVP() completed successfully
00000079	7.04289341	[10720] MpcVideoRenderer64.ax(tid 38b4)      183 : CMpcVideoRenderer::SetMediaType()
00000080	7.04296017	[10720] MpcVideoRenderer64.ax(tid 38b4)      183 : CDX11VideoProcessor::InitMediaType()
00000081	7.04300642	[10720] MpcVideoRenderer64.ax(tid 38b4)      183 : CDX11VideoProcessor::ReleaseVP()
00000082	7.04323769	[10720] MpcVideoRenderer64.ax(tid 38b4)      183 : CDX11VideoProcessor::InitializeTexVP() started with input surface: P010, 1920 x 1080
00000083	7.04373932	[10720] MpcVideoRenderer64.ax(tid 38b4)      184 : GetShaderConvertColor() started for P010 1920x1080 extfmt:0x288ca500 chroma:0
00000084	7.04377747	[10720] MpcVideoRenderer64.ax(tid 38b4)      184 : GetShaderConvertColor() frame consists of 2 planes
00000085	7.04382181	[10720] MpcVideoRenderer64.ax(tid 38b4)      184 : GetShaderConvertColor() set chroma location MPEG-2
00000086	7.04585218	[10720] MpcVideoRenderer64.ax(tid 38b4)      186 : CDX11VideoProcessor::InitializeTexVP() completed successfully
00000087	7.04604340	[10720] MpcVideoRenderer64.ax(tid 38b4)      186 : CDX11VideoProcessor::InitMediaType()
00000088	7.04606390	[10720] MpcVideoRenderer64.ax(tid 38b4)      186 : CDX11VideoProcessor::ReleaseVP()
00000089	7.04631376	[10720] MpcVideoRenderer64.ax(tid 38b4)      186 : CDX11VideoProcessor::InitializeTexVP() started with input surface: P010, 1920 x 1080
00000090	7.04642248	[10720] MpcVideoRenderer64.ax(tid 38b4)      186 : GetShaderConvertColor() started for P010 1920x1080 extfmt:0x288ca500 chroma:0
00000091	7.04646254	[10720] MpcVideoRenderer64.ax(tid 38b4)      186 : GetShaderConvertColor() frame consists of 2 planes
00000092	7.04651213	[10720] MpcVideoRenderer64.ax(tid 38b4)      186 : GetShaderConvertColor() set chroma location MPEG-2
00000093	7.04839182	[10720] MpcVideoRenderer64.ax(tid 38b4)      188 : CDX11VideoProcessor::InitializeTexVP() completed successfully
00000094	7.04961538	[10720] MpcVideoRenderer64.ax(tid 38b4)      189 : CVideoRendererInputPin::ReceiveConnection()
00000095	7.04965782	[10720] MpcVideoRenderer64.ax(tid 38b4)      189 : CVideoRendererInputPin::GetAllocator()
00000096	7.04969454	[10720] MpcVideoRenderer64.ax(tid 38b4)      190 : CDX11VideoProcessor::InitMediaType()
00000097	7.04974413	[10720] MpcVideoRenderer64.ax(tid 38b4)      190 : CDX11VideoProcessor::ReleaseVP()
00000098	7.04996777	[10720] MpcVideoRenderer64.ax(tid 38b4)      190 : CDX11VideoProcessor::InitializeTexVP() started with input surface: P010, 1920 x 1080
00000099	7.05046415	[10720] MpcVideoRenderer64.ax(tid 38b4)      190 : GetShaderConvertColor() started for P010 1920x1080 extfmt:0x288ca581 chroma:0
00000100	7.05048227	[10720] MpcVideoRenderer64.ax(tid 38b4)      190 : GetShaderConvertColor() frame consists of 2 planes
00000101	7.05053616	[10720] MpcVideoRenderer64.ax(tid 38b4)      190 : GetShaderConvertColor() set chroma location MPEG-2
00000102	7.05246544	[10720] MpcVideoRenderer64.ax(tid 38b4)      192 : CDX11VideoProcessor::InitializeTexVP() completed successfully
00000103	7.05297422	[10720] MpcVideoRenderer64.ax(tid 38b4)      193 : CMpcVideoRenderer::SetMediaType()
00000104	7.05299282	[10720] MpcVideoRenderer64.ax(tid 38b4)      193 : CDX11VideoProcessor::InitMediaType()
00000105	7.05300951	[10720] MpcVideoRenderer64.ax(tid 38b4)      193 : CDX11VideoProcessor::ReleaseVP()
00000106	7.05323601	[10720] MpcVideoRenderer64.ax(tid 38b4)      193 : CDX11VideoProcessor::InitializeTexVP() started with input surface: P010, 1920 x 1080
00000107	7.05328226	[10720] MpcVideoRenderer64.ax(tid 38b4)      193 : GetShaderConvertColor() started for P010 1920x1080 extfmt:0x288ca581 chroma:0
00000108	7.05330181	[10720] MpcVideoRenderer64.ax(tid 38b4)      193 : GetShaderConvertColor() frame consists of 2 planes
00000109	7.05334949	[10720] MpcVideoRenderer64.ax(tid 38b4)      193 : GetShaderConvertColor() set chroma location MPEG-2
00000110	7.05523443	[10720] MpcVideoRenderer64.ax(tid 38b4)      195 : CDX11VideoProcessor::InitializeTexVP() completed successfully
00000111	7.05586243	[10720] MpcVideoRenderer64.ax(tid 38b4)      196 : CDX11VideoProcessor::InitMediaType()
00000112	7.05588102	[10720] MpcVideoRenderer64.ax(tid 38b4)      196 : CDX11VideoProcessor::ReleaseVP()
00000113	7.05610895	[10720] MpcVideoRenderer64.ax(tid 38b4)      196 : CDX11VideoProcessor::InitializeTexVP() started with input surface: P010, 1920 x 1080
00000114	7.05615187	[10720] MpcVideoRenderer64.ax(tid 38b4)      196 : GetShaderConvertColor() started for P010 1920x1080 extfmt:0x288ca581 chroma:0
00000115	7.05616951	[10720] MpcVideoRenderer64.ax(tid 38b4)      196 : GetShaderConvertColor() frame consists of 2 planes
00000116	7.05621576	[10720] MpcVideoRenderer64.ax(tid 38b4)      196 : GetShaderConvertColor() set chroma location MPEG-2
00000117	7.05802584	[10720] MpcVideoRenderer64.ax(tid 38b4)      198 : CDX11VideoProcessor::InitializeTexVP() completed successfully
00000118	7.05894804	[10720] MpcVideoRenderer64.ax(tid 38b4)      199 : CMpcVideoRenderer::SetMediaType()
00000119	7.05898952	[10720] MpcVideoRenderer64.ax(tid 38b4)      199 : CDX11VideoProcessor::InitMediaType()
00000120	7.05902863	[10720] MpcVideoRenderer64.ax(tid 38b4)      199 : CDX11VideoProcessor::ReleaseVP()
00000121	7.05923605	[10720] MpcVideoRenderer64.ax(tid 38b4)      199 : CDX11VideoProcessor::InitializeTexVP() started with input surface: NV12, 1920 x 1080
00000122	7.05927992	[10720] MpcVideoRenderer64.ax(tid 38b4)      199 : GetShaderConvertColor() started for NV12 1920x1080 extfmt:0x288ca500 chroma:0
00000123	7.05929756	[10720] MpcVideoRenderer64.ax(tid 38b4)      199 : GetShaderConvertColor() frame consists of 2 planes
00000124	7.05934334	[10720] MpcVideoRenderer64.ax(tid 38b4)      199 : GetShaderConvertColor() set chroma location MPEG-2
00000125	7.06122732	[10720] MpcVideoRenderer64.ax(tid 38b4)      201 : CDX11VideoProcessor::InitializeTexVP() completed successfully
00000126	7.06241131	[10720] MpcVideoRenderer64.ax(tid 38b4)      202 : CDX11VideoProcessor::InitMediaType()
00000127	7.06245422	[10720] MpcVideoRenderer64.ax(tid 38b4)      202 : CDX11VideoProcessor::ReleaseVP()
00000128	7.06273699	[10720] MpcVideoRenderer64.ax(tid 38b4)      203 : CDX11VideoProcessor::InitializeTexVP() started with input surface: NV12, 1920 x 1080
00000129	7.06279612	[10720] MpcVideoRenderer64.ax(tid 38b4)      203 : GetShaderConvertColor() started for NV12 1920x1080 extfmt:0x288ca500 chroma:0
00000130	7.06285286	[10720] MpcVideoRenderer64.ax(tid 38b4)      203 : GetShaderConvertColor() frame consists of 2 planes
00000131	7.06288385	[10720] MpcVideoRenderer64.ax(tid 38b4)      203 : GetShaderConvertColor() set chroma location MPEG-2
00000132	7.06490803	[10720] MpcVideoRenderer64.ax(tid 38b4)      205 : CDX11VideoProcessor::InitializeTexVP() completed successfully
00000133	7.08284378	[10720] MpcVideoRenderer64.ax(tid 50c)      223 : CMpcVideoRenderer::Run()
the debug version of mpc-be or mpcVR is crashing so it doesn't close without the help of the taskmgmt this is different with the none debug versions.
Old 7th February 2020, 18:35   #7119  |  Link
v0lt
I see such function calls. CMpcVideoRenderer::SetMediaType(): NV12, NV12, P010, P010, NV12.
And I don’t understand why the last SetMediaType() sets the NV12 format. This does not happen to me.
Old 7th February 2020, 19:06   #7120  |  Link
the situation is special here.
the file in question should be hardware decoded and as far as i can see lavfilter even tries to do that with mpc-hc i can see for a very short time the H/W information in the bottom left:
https://abload.de/img/mpc-hc27k63.png
it pretty much impossible to find a file that looks like it is hardware compatible but isn't in the end when using nvidia or intel GPUs.
this is nothing serious anyway i just forced p010 to see issues with D3D11 processing and the new AMD driver i really really don't need this.
