#8061 | Link |
sorry i don't know what the xbox screenshoot function does so i can't judge screen shoots for HDR.
but i can do this for you SDR madVR: https://abload.de/img/madvrmsk9y.jpg SDR mpcVR: https://abload.de/img/mpcvr7hj57.jpg so your new HLG bt.2020 to bt.709 doesn't seem to work correctly. the madVR results is AFAIK correct for a SDR display. SDR is BT709 (sRGB) what madVR is doing is simple in theory. it read the primary and then it compares it to the calibration setting. if no calibration setting is set it defaults to BT 709 for SDR and BT 2020 for HDR passthrough. if the primary is not matching with the "calibration setting" it will make it match. so in this case it sees BT 2020 from the file and it applies bt 2020 to bt 709 because of SDR. your HDR -> SDR tonemapping does this too. BT709 and sRGB are not 100 % the same but you can skip this topic no one really calibrates to sRGB(to those that do don't feel offended plz there are reasons to do that) but to BT709 they are very similar to. sorry it's calibration is sadly never easy... BTW. you could force HLG to SDR tonemapping it's "better" anyway. HLG SDR with bt 2020 to bt 709 is more of compatibility thing it looks bad but that's how it should looks on a SDR screen... |
#8062 | Link |
Expert help required.
MFVideoTransferMatrix AVColorSpace zimg_matrix_coefficients_e Let's look at the parameters for BT.2020: Code:
MFVideoTransferMatrix_BT2020_10 MFVideoTransferMatrix_BT2020_12 AVCOL_SPC_BT2020_NCL AVCOL_SPC_BT2020_CL ZIMG_MATRIX_BT2020_NCL ZIMG_MATRIX_BT2020_CL MFVideoTransferFunction AVColorTransferCharacteristic zimg_transfer_characteristics_e Let's look at the parameters for BT.2020: Code:
MFVideoTransFunc_2020_const MFVideoTransFunc_2020 AVCOL_TRC_BT2020_10 AVCOL_TRC_BT2020_12 ZIMG_TRANSFER_BT2020_10 ZIMG_TRANSFER_BT2020_12 MicroSoft confused TransferMatrix and TransferFunction? |
#8063 | Link | |
I7 2600K@4.2 /Asrock P67 Extreme4 Gen 3 /Kingston HyperX 8Gb 1866 (4x2) Kit /OCZ Vertex 3 256Gb /GTX 1650 /Samsung U28R550UQI /LG 47LM620T /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 |
#8064 | Link |
this https://i.imgur.com/l99tCrd.jpg is not correct sdr bt 709. it should look like this: https://abload.de/img/madvrmsk9y.jpg
just take the red in the top left corner. for HDR -> SDR tone mapping there is a lot of freedom i can't 100 % say it wrong or right. even the source doesn't seem to be mastered in a way that they should look alike: it say in HDR10 M03 750 nits it says in HLG M03 75% grey. i don't know what 75% grey means is it a linear image that would be 750 nits. HLG 75% of 1024 range ~767 that's not 750 nits. HLG as HDR seems fine HDR passthrough seems fine both tone mapping of HLG and HDR 10 seems fine but HLG SDR bt2020 to bt709 is obviously wrong even in your new screenshoot. @volt they all 3 seem to be the same. and that'S all i can provide i don't know the difference between bt2020_10 and bt2020_12 same for MFVideoTransFunc_2020_const MFVideoTransFunc_2020. |
#8065 | Link | |
![]() - LAV Video set to d3d11-native - mpcVR set to "Use Derect3D 11" and Swap effect is set to "Flip" (there's with "Discard" as well, but not that brutal) Now, if I set one of the following the tearing goes away: - LAV Video set to d3d11-copyback - uncheck "Use Derect3D 11" in mpcVR (LAV Video falls back to d3d11-copyback) Does it mean that mpcVR doesn't support d3d11-native at all? I haven't noticed this before ...
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED65B8(2160p@23/24/25/29/30/50/59/60Hz) | madvr config |
#8066 | Link | |
Just play this 60p file with CVR custom and stock settings and you will get this jerky playback. I checkd EVR cutom statictics in Filters menu and it reports a lot of dropped frames. If I did something wrong, please let me know what settings I need to tweak. I must add I am on a Nvidia RTX30 card now. But AMD RX 5700XT is still here. https://drive.google.com/file/d/1pDj...ew?usp=sharing |
#8067 | Link | |
MPC-BE 1.5.6 (build 6000) stable and Nightly builds | Video Renderer | Image Source | Script Source |
#8068 | Link | |
I can advise you to check the "Video" and "Frame synchronization" settings, as well as make a frame with active statistics (Ctrl+J). You can also try turning VSync (V) on/off and using the exclusive full screen.
#8069 | Link |
Statistics (Ctrl+J) show that frames are dropped. I also tried all possible combinations of VSync options built into MPC-BE. While playing back the file I rightclick menu and open filter list and click on CVR CP and then on the second it lists the dropped frames which grow fast.
If I turn on Tearing Test and use it for "smooth test" and you can clearly see that I get dropped frames because the double red line jumps during that drop. I tried madVR and also MPC Video Renderer. Both are fine to my eyes and also no dropped frames are reported. So I encounter that issue only on EVR CP. I want that basic renderer be also fine. I created a second sample file, which is now AVC, but also 60p. Also here Audio removed for copyright issues: https://drive.google.com/file/d/1orp...ew?usp=sharing |
#8070 | Link |
Updated german translation - little cosmetic change: more consistent
#8071 | Link | |
![]() Here's the interesting part: it works fine at 59Hz!!! (even with 23p/25p videos) Issue happens if I set the TV (in Windows adapter settings) to: - 23Hz with 23p video - 25Hz with 25p video I have 2 displays connected to the HTPC: - monitor via DVI (only supports 60Hz, so I can't try it on this) - TV via HDMI (supports 23/24/25/29/30/50/59/60Hz) Something is not right. And as I said this only happens when Lav Video is set to d3d11-native and d3d11 output is enabled in mpcVR (more visible with "Flip" presentation).
#8072 | Link | |
Do you try in fullscreen exclusive ?
I7 2600K@4.2 /Asrock P67 Extreme4 Gen 3 /Kingston HyperX 8Gb 1866 (4x2) Kit /OCZ Vertex 3 256Gb /GTX 1650 /Samsung U28R550UQI /LG 47LM620T /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 Last edited by Aleksoid1978; 16th December 2020 at 23:46. |
#8073 | Link | |
P.S. Try reset settings, try in fullscreen exclusive.
#8074 | Link | |
#8075 | Link |
MPCVideoRenderer-v0.4.10.1553_git2020.12.18-73a6d82
I am thinking of removing the "Convert to SDR" feature for HLG. It gives practically nothing. HLG is compatible with SDR displays. added: mpcvr_1553_hdr_stats_1 Test build with dimmed statistics for displays in HDR mode.
MPC-BE 1.5.6 (build 6000) stable and Nightly builds | Video Renderer | Image Source | Script Source Last edited by v0lt; 18th December 2020 at 11:28. |
#8077 | Link | |
the calibrated peak brightness for SDR is 100/120 depending on who you ask while screens in SDR mode are often far over that that's why madVR has a control over the brightness you define that here (i guess): #define DISPLAY_LUMINANCE_PEAK 125.0 https://github.com/Aleksoid1978/Vide...pq_to_sdr.hlsl i have no clue if your algorithm is able to deal correctly with higher peak brightness but madVR defaults to 200 and it's worth a try. |
#8078 | Link |
If you do allow a higher target nit value, then please make it an configurable option.
There are a lot of people who have set their screen to a much lower brightness that its maximum. In that case 200 nits gives a too dark result. It could be a simple dropdown with values 100/125/150/175/200. |
#8080 | Link | |
But I could recreate it on my monitor as well: it seems the problem only occurs when fps = display Hz or really close to it (59p on 60Hz)! So, to try to reproduce it, play back: - 1080p/2160p 59p SDR video on monitor @ 60Hz - set LAV Video to d3d11 native (not copyback) - set mpcVR to d3d11 and set Flip presentation - it happens in window or fullscreen too Can anyone reproduce this crazy stutter?
