#8241 | Link |
@cmhrky
Great work, but I also think using a microphone for an audio out function is not the best solution. I think you should create an icon based on a speaker symbol and give it your spin. Thanks !! |
#8244 | Link | |
I think most would agree, which is why I said I think they should be the default but I also understand you've just updated the old style so I didn't expect it. Thanks cmhrky, I will take a look. The thickness of the flybar is good. The toolbar also needs extra too. Look. @1920x1200 400% zoom. Needs to be more in line with system taskbar icons (wifi, volume etc) This weak strength of the lines is obvious even without enlargement but I have done so to highlight the issues here. ![]() Volt, I know you probably won't update the toolbar, but the flybar should be updated to flybar (2).svg, It's much better. ![]() Last edited by ryrynz; 21st January 2021 at 01:34. |
#8246 | Link |
I like the first and second the most too. Probably the second over the first, since the width is similar to the other icons.
madVR options explained |
#8247 | Link |
@cmhrky
Please сhoose 2-4 good toolbars, put them in different folders, rename to toolbar.svg, add readme.txt, and pack it into one ZIP archive. I will upload this archive to SourceForge.net.
MPC-BE 1.5.6 (build 6000) stable and Nightly builds | Video Renderer | Image Source | Script Source Last edited by v0lt; 22nd January 2021 at 04:52. |
#8248 | Link |
Acid fr0g
It's a long time I don't update MPC-BE and, now that I updated to last two nightly, the time in the bar skips second or doesn't run at all.
I have tried with internal or LAV filters, default renderer or MPC renderer. No solution. The very same MKV files play ok on MPC-HC with MPC renderer and LAV filters. Anybody else with this issue?
@turment on Telegram |
#8249 | Link | |
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /AMD Radeon R9 16Gb@3200 /Kingston 500Gb M.2 /GTX 1650 /Samsung U28R550UQI /LG 47LM620T /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 |
#8251 | Link |
@ryrynz
I can't make much changes to most svg files but I guess I was able to fix it a bit. I will prepare another toolbar.svg by drawing it myself. It will be better. @volt toolbar_flybar_svg.zip When I close the status bar with "View> Status" and "View> Presets ...> Compact" skips second. Last edited by cmhrky; 23rd January 2021 at 00:27. |
#8252 | Link |
@cmhrky:
The toolbars look great ![]() I tried the files you uploaded and found a little cosmetic issue: #3 is fine, but the corner around the speaker of #4 is a bit weird. I don't know how to decribe it, I made screenshots: #3 #4 I use a 3840x2160p screen and 200% windows scaling, if this is needed. |
#8253 | Link |
Already fixed.
#8254 | Link |
@Klaus1189
It can happen. Because I cannot interfere with some svg icons I use. Their quality is starting to deteriorate. I will prepare it by drawing it myself in line. It will look better at higher resolutions. @Aleksoid1978 In live streams, the time stays in the seek bar when the status bar switches. Last edited by cmhrky; 23rd January 2021 at 13:09. |
#8255 | Link | |
#8257 | Link |
@cmhrky
Your toolbars are now on SourceForge.net.
MPC-BE 1.5.6 (build 6000) stable and Nightly builds | Video Renderer | Image Source | Script Source Last edited by v0lt; 24th January 2021 at 06:36. |
#8259 | Link |
Can you add App Paths registry entry to MPC-BE setup files?
For example, in Logitech SetPoint application, this registry entry is required to set it as a media player. Code:
Windows Registry Editor Version 5.00 [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\mpc-be64.exe] @="C:\\Program Files\\MPC-BE x64\\mpc-be64.exe" "Path"="C:\\Program Files\\MPC-BE x64" |
