Old 3rd February 2010, 23:46   #81  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@_hawk_
i use a eSATA external hard drive so all files would be created in BluRip folder
MuLTiTaSK is offline   Reply With Quote
Old 4th February 2010, 12:05   #82  |  Link
_hawk_
BluRip author
Changelog
v0.4.4
- Load/save projects
- Queue system
- Changed avs input source selection
If any1 would like a make a manual/nice splash screen - let me know.
BluRip : 1-Click BluRay/m2ts to h264 mkv converter
http://code.google.com/p/blurip/
_hawk_ is offline   Reply With Quote
Old 4th February 2010, 15:09   #83  |  Link
mackworth
Is there a good way to get media information besides mediaInfo?
THe reason I ask is because I used bluerip to convert Gran Torino which has a 5.1 TrueHD track. When I look at the stream list, its selected, but mediaInfo says the resulting file is only AC3 audio and the audio track is only 500MB? Could that be possible?
Pretty crazy though, this must be a x264 thing(I am using x64 build 1416), but I use the -slow -crf 19 preset that comes with Blurip, and the resulting Gran Torino file is only 4.8 gigs (not including audio)down from ~20. I haven't watched it yet to see if its ok, but that seems crazy small.
mackworth is offline   Reply With Quote
Old 4th February 2010, 16:39   #84  |  Link
_hawk_
BluRip author
Eac3to coverts the audio tracks. Not sure if it can demux them completely untouched. I'll take a look at other GUI how they handle the audio tracks..
Totally depends on movie..
I encoded start trek 1 with crf 18 - resulting file is less then 5gb (looks fine) - original was more then 20gb.
Crf 19 with bourne identity results in a 9gb file..
So on some movies x264 simply doesn't need more bitrate.
Old 5th February 2010, 03:30   #85  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@_hawk
awesome support
Old 5th February 2010, 03:31   #86  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
first post updated
Old 5th February 2010, 03:32   #87  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
Remuxing (HD Stuff)
Old 5th February 2010, 08:39   #88  |  Link
_hawk_
BluRip author
Thanks. I'll add a checkbox "untouched audio".
Old 5th February 2010, 15:21   #89  |  Link
mackworth
Thanks!
Old 5th February 2010, 18:56   #90  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@_hawk_
DGDecNV support wow your like a coding machine great job BluRip is shaping out real nice
remember where you heard it first BluRip will be widely accepted and the swarm of users will come to thank you
vision -> code -> .executable
Old 5th February 2010, 20:50   #91  |  Link
_hawk_
BluRip author
Hehe let's see..
There wasn't much feedback yet.
Old 5th February 2010, 21:15   #92  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@_hawk_
DTS-HD (*.dtshd)
TrueHD (*.thd+ac3)
added in next release?
Old 5th February 2010, 22:21   #93  |  Link
mackworth
@_hawk_
DTS-HD (*.dtshd)
TrueHD (*.thd+ac3)
if he adds this, I am dropping ripbot.
Old 5th February 2010, 22:28   #94  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@mackworth
should'nt be that hard to add eac3to demuxes then mkvmerge muxes harmony
Old 5th February 2010, 22:31   #95  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@_hawk_
i use SupRip to create .srt's adding in srt's manually to BluRip before muxing would save some time
Old 5th February 2010, 22:32   #96  |  Link
The biggest toady i have ever seen on doom9 :O
Old 5th February 2010, 22:39   #97  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@Atak_Snajpera
have you tried BluRip?
i love the Doom9 community sharing ideas helping others aiding in making the backup of there media process easier
Old 5th February 2010, 22:44   #98  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@Atak_Snajpera
welcome more options use them as motivation to keep coding RipBot264 you have a big user base you have helped the community very much with your gifts thank you
Old 6th February 2010, 10:31   #99  |  Link
_hawk_
BluRip author
@_hawk_
DTS-HD (*.dtshd)
TrueHD (*.thd+ac3)
Already in svn..
Have to finish some other things before I'll make a new version.
Old 6th February 2010, 11:04   #100  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@_hawk_
it just keeps getting better
blu-ray, blurip, eac3to, ffms2, mkv, mkvtoolnix, x264
