Old 2nd September 2018, 12:54   #941  |  Link
SpasV
I need some help with FRIMSource64(), please.
My working enviroment: Windows 10, FRIM version 1.29 (x64) (Avisynth+ (Intel Media SDK 2018 R1))
I'm trying to pipe .h265 video to x265.
>avs2yuv64 -frames 24 -raw -depth 10 -par 1:1 encode_Mission_Impossible.avs -
LoadPlugin("C:\Programs\AviSynth+\plugins64+\FRIMSource64.dll")
FRIMSource64(codec="h264", filename="F:\Mission_Imposssible_Ghost_Protocol\Mission_Imposssible_Ghost_Protocol.h265", cache=1, num_frames=24)
The result is:
error: Script error: There is no function named 'FRIMSource64'.
(encode_Mission_Impossible.avs, line 2)
The requirenment for libmfxsw64.dll to be "placed in any directory which is specified in PATH environment variable" is fulfilled - it is in two directories.
What can I do about this?
Old 3rd September 2018, 06:21   #942  |  Link
videofan3d
What about
FRIMSource(codec="h264", filename=…
videofan3d is offline   Reply With Quote
Old 3rd September 2018, 09:57   #943  |  Link
SpasV
Originally Posted by videofan3d View Post
What about
FRIMSource64.dll is Version 1.29.
Maybe, it is because of the file I'm trying to source - .h265?
Format: HEVC
Bit depth: 10 bits
FRIM_release_notes.txt reads:
2018-07-08
FRIM all:
- experimental HEVC support
Actually, I'm trying to pipe .h265 stream to x265 encoder.
Old 3rd September 2018, 19:48   #944  |  Link
videofan3d
Format: HEVC
Bit depth: 10 bits
2018-07-08
FRIM all:
Second attempt:
FRIMSource(codec="h265", filename=…"
Old 4th September 2018, 01:55   #945  |  Link
SpasV
Second attempt:
The same result.
I've found a workaround:
ffmpeg -i Mission_Imposssible_Ghost_Protocol.h265 -strict -1 -f yuv4mpegpipe -
Maybe, I have some general problem. I cannot get this filter working at all.
Old 5th September 2018, 09:35   #946  |  Link
SpasV
Second attempt:
Are you suggesting my using 32-bit AviSynth+?
Old 5th September 2018, 10:24   #947  |  Link
SpasV
OK. I've run plugins64.reg.
I've run
FRIMSource(codec="h265", filename="G:\Mission_Imposssible_Ghost_Protocol\Mission_Imposssible_Ghost_Protocol.h265", cache=1, num_frames=24)
in AvsPmod and got
ERROR:Failed to load plugin (1D962A45A43FF41A6)
ERROR:undeveloped feature (-3), ...
Is there an instruction for installing these plugins?
Old 5th September 2018, 19:37   #948  |  Link
videofan3d
I've run
in AvsPmod and got
Read document FRIM_setup_readme.pdf which is part of the distribution. There is description of the plugin installation.
In general, you need to edit plugins64.reg and set there path accordingly - only then can FRIM find relevant plugin.
Furthermore, the plugins which are part of free distribution, are SW based only. So you will need to use FRIMSource(…, platform="sw", …)
Old 9th September 2018, 12:29   #949  |  Link
SpasV
Unfortunately, I cannot make FRIM works.
I’ve registered the plugins with plugins64.reg and I have:
>avs2yuv64 -seek 1 -frames 24 -raw -csp I420 -depth 10 avs\encode-FRIM.265.avs -| x265-10b - ...
error: ERROR: expect more data at input (-10), c:\prj\intelmedia\frim_decode\src\pipeline_decode.cpp (587)
ERROR: expect more data at input (-10), c:\prj\intelmedia\frim_decode\src\pipeline_decode.cpp (262)
encode-FRIM.265.avs
[FRIMSource(codec="h265", filename="F:\Mission_Imposssible_Ghost_Protocol\Mission_Imposssible_Ghost_Protocol.mkv", cache=1, num_frames=24, platform="sw")]
This one works:
>C:\Programs\FRIM_x64_version_1.29\x64\FRIMDecode64 -i:mvc insurgent_cut.264 -o output_L.yuv output_R.yuv
FRIM Decoder version 1.29 (experimental) - Win64 (build: Jul 8 2018)
- based on Intel(R) Media SDK
Media SDK impl SOFTWARE (C:\Programs\FRIM_x64_version_1.29\x64\libmfxsw64.dll)
Processing started
Frame number: 4087
Processing finished in 175.66 seconds
Old 11th September 2018, 05:12   #950  |  Link
videofan3d
FRIM does not parse .mkv container...
Old 11th September 2018, 22:45   #951  |  Link
SpasV
Sorry my absentmindedness.
The context is avs2yuv64.exe. It is avs2yuv-0.24bm5 - the last version.
When I use ffms2-2.23.1 as a source FFMS2(<"file_name.m2ts">, colorspace = "yuv420p10")
it works and the process displays the mesage:
encode-FFMS2.265.avs: 3840x2160, YUV420P10, 10-bits, progressive, 12500/473 fps, 3171 frames
When I use FRIMSource - FRIMSource(codec="h265", filename=<"file_name.m2ts">, cache=1, num_frames=24, platform="sw")
the mesage is:
avisynth 16-bit hack enabled
encode-FRIM.265.avs: 1920x2160, YV12, 10-bits, progressive, 24000/1001 fps, 24 frames
The same mesage I've got with ffms2-2.23.1 when I used the old avs2yuv64.exe version - avs2yuv-0.24bm3
Old 12th September 2018, 05:18   #952  |  Link
videofan3d
the mesage is:
When using file.m2ts (i.e. TS-container), you have to add
FRIMSource(… ,container="ts",...)
For more FRIMSource details see FRIMSource_readme.pdf from distribution...
I'm not familiar with avs2yuv64.exe …
Old 12th September 2018, 09:20   #953  |  Link
SpasV
All plugins are in place, obviously.
Intel/MediaSDKPlugin
C:\Programs\AviSynth+\FRIM_x64_version_1.29\x64\
With container="ts"
Old 12th September 2018, 20:16   #954  |  Link
videofan3d
With container="ts"
Can you open your script encode-FRIM.265.avs directly using e.g. MPC-HC(x64) media player?
(You need to use some 64-bit media player which is capable to play Avisynth+ scripts. MPC-HC(x64) is able to do it).
If yes then script is correct and problem is somewhere in avs2yuv64.exe - this I cannot help...
If not, MPC-HC(x64) will show you error message to resolve...
Old 13th September 2018, 10:24   #955  |  Link
SpasV
MPC-HC(x64), AvsPmod too, can play the scripts.
When playing FFMS2("file_name.m2ts", colorspace = "yuv420p10") there is a normal 3640x2160 picture.
When playing FRIMSource(codec="h265", filename="file_name.m2ts", cache=1, num_frames=240) there is no picture.
with FRIMSource(codec="h265", filename="file_name.m2ts", cache=1, num_frames=240, container="ts")
there is the Error message above when I've tried .mkv file.
but FRIMSource(codec="h265", filename="file_name.h265", cache=1, num_frames=240) plays and V: rawvideo, yuv420p, 3840x2140
Old 14th September 2018, 14:36   #956  |  Link
SpasV
@videofan3d
Are you capable of developing an MVC encoder?
Old 14th September 2018, 19:45   #957  |  Link
videofan3d
@videofan3d
I'm not sure whether you read the first post of this thread
Free H.264 MVC 3D Encoder ...
Old 14th September 2018, 19:46   #958  |  Link
videofan3d
Send me the script - I'll check it....
Old 15th September 2018, 15:57   #959  |  Link
SpasV
The scripts:
container not specified - no picture
container="ts" - error
Old 15th September 2018, 16:15   #960  |  Link
SpasV
As to "I'm not sure whether you read the first post of this thread
Free H.264 MVC 3D Encoder ..."
Sorry, I've missed the important part.
I've tried it and I would like to ask you some questions about:
(Better if there is a written instruction.)
- VBR - avg, maximum; obviously I can change them. But, working with x264, I prefer Constant QP with control over the maximum bitrate.
- are there other parameters avilable
- performance - with no more than 38% CPU load I've got 7 fps.
In general, the most information the better.
encoders, mvc
