18th August 2015, 19:30 | #401 | Link |
@Anakunda
I wanted to test it but my license don't work, I reinstalled Windows often recently (migrated to Win10 and currently migrating to skylake hardware but having trouble with bad RAM), the problem is the URL for license key generation is dead (http://neuron2.net/licensing.html). @amango You mean file batch mode? In normal mode there is a new data view in the muxing dialog, this data view has columns to set default and forced flags. @ShamisOMally Jesus, last game I played and can remember by name was Half Live! Thanks for the offer. There are three games I want to try at some time: GTA V, Metal Gear Solid V and Mindcraft.
18th August 2015, 19:51 | #402 | Link | |
http://rationalqm.us/ http://rationalqm.us/licensing.html |
18th August 2015, 19:51 | #403 | Link | |
From the temporary script I see StaxRip tries DGdecNV but fails. Playing .dgi files using 32bit DGDecodeNV works. Edit: ffplay encode_Source.avs is playable! Problem must be on StaxRip side. Code:
LoadPlugin("C:\Program Files (x86)\DGDecNV\x64 Binaries\DGDecodeNV.dll") DGSource("H:\video\(workset)\MadMaxFuryRoad\source.dgi") Last edited by Anakunda; 18th August 2015 at 20:04. |
18th August 2015, 21:38 | #404 | Link |
@Anakunda
first please try if it also happens with a recent build, I tried it and it works here. http://www.mediafire.com/download/kb..._2015.08.18.7z https://onedrive.live.com/redir?resi...hint=file%2c7z
18th August 2015, 21:52 | #405 | Link |
Stax, two questions:
1. Did you see my post two pages back about RGTools? "RgTools.dll cannot be found, while RemoveGrain is selected, even though RgTools does exist in the Apps subfolder." EDIT: This now works on the build you posted before me. 2. When using DGSource, after trying to load a video into StaxRip, it fails and gives me the following error: Code:
System exception - Access Violation (C:\PATH_TO_VIDEO\video.avs, line 2) DGSource("C:\PATH_TO_VIDEO\video.dgi") EDIT: This is still happening on the build you posted before me. Last edited by dejong12; 18th August 2015 at 22:06. |
18th August 2015, 22:10 | #406 | Link | ||
18th August 2015, 22:51 | #408 | Link |
Can MPC x64 open the avs file?
18th August 2015, 23:53 | #411 | Link |
Does MPC show the same error message and can VirtualDub x64 open it?
19th August 2015, 03:56 | #412 | Link | |
I confirm that's not A/V issue, using no A/V, beyond that as I wrote feeding the temporary script StaxRip creates into ffplay64, the source video can pass through to screen. Last edited by Anakunda; 19th August 2015 at 05:12. |
19th August 2015, 05:52 | #413 | Link |
Are you sure you re-downloaded 2049 and set the path to the correct x64 DLL? There was a memory access violation raised by DGDecodeNV, this memory access violation was only happening under special circumstances like running Windows 8 or higher but not Windows 7, it was happening only in certain clients like .NET applications or MPC but not in all clients, VirtualDub x64 was not affected for instance. Donald has fixed it and re-uploaded 2049. If you absolutely cannot get it working then please send a log file.
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 19th August 2015 at 05:54. |
19th August 2015, 10:29 | #414 | Link | ||
I can't send you a log file because StaxRip does not create one. When it asks to try using another source, it fails by giving the same error. No video is then imported into StaxRip. |
19th August 2015, 10:55 | #419 | Link |
the last changed date of the DLL must be exactly 2015.05.10
http://forum.doom9.org/showthread.ph...17#post1721117
19th August 2015, 11:00 | #420 | Link | |
