9th September 2007, 21:10 | #21 | Link |
@Chainmax
Yep, that is correct. @cwk I did a more complete speed test. Results for bobbing the 657 frame clip I mentioned earlier: Code:
1.6 Ghz Pentium M: EEDI2: 3.74 fps New Filter: 2.38 fps Q6600 @ 2.8 Ghz: EEDI2: 7.64 fps EEDI2 (mt): 18.77 fps (multithreaded version by foxyshadis) New Filter (1 threads): 6.99 fps New Filter (2 threads): 13.27 fps New Filter (4 threads): 23.89 fps New Filter (8 threads): 23.46 fps EDIT: there was a little problem with the fps numbers the first time. Last edited by tritical; 9th September 2007 at 22:26. |
10th September 2007, 23:04 | #22 | Link |
Huh?
Approaching the 29k mark...
Sorry for the slowness, but I can't leave it on 24h a day .
Read Decomb's readmes and tutorials, the IVTC tutorial and the capture guide in order to learn about combing and how to deal with it. |
11th September 2007, 00:16 | #24 | Link |
Huh?
I'd like to see it reach at least the 40k mark before uploading it, but if doing it now will result in better data then I will upload it at once.
12th September 2007, 00:11 | #25 | Link |
Huh?
Files have been uploaded.
27th September 2007, 19:59 | #27 | Link |
Angel of Night
Still lots left. Check who has what to see.
30th September 2007, 09:28 | #31 | Link |
x264 developer
71 C is pretty normal for a full-load Core 2 Quad to be honest. To get lower you need a seriously powerful air cooler or better. Four cores generate a hell of a lot of heat.
30th September 2007, 09:30 | #32 | Link |
The program that came with the motherboard and speedfan 4.32 both show the same values, so I'd assume they're correct.
EDIT: I'm assuming other people have run this on a Q6600 and can tell me if it's normal or not. |
30th September 2007, 10:30 | #33 | Link |
I run it on 2 Q6600s overclocked to 2.8 and 3.0, but they aren't using the stock heatsink/fan so I'm not sure this info will help much. Both stay right around 55C for cores 0/1 and 50C for cores 2/3. That is according to core temp v0.95. They both have Thermalright Ultra 120A heatsinks with 120mm Scythe fans which move about 49 CFM.
Also, are you going to run 34 or just testing? ... I couldn't tell from your post. |
30th September 2007, 15:41 | #34 | Link |
I'll run it completely. My Q6600 is a B0 stepping (engineering sample) so it's probably going to be hotter than the latest (G0?). It's got a Zalman CNPS7700 cooler (didn't come with a stock cooler), not overclocked, cores 0/1 are 80C and 2/3 are 71C. The only thing that worries me is that I think the bios is set to shutdown at 75C. Good thing the weather is still cold here.
