Old 22nd June 2008, 07:35   #21  |  Link
IanB
Avisynth Developer
@Gavino, short answer is it's gone!
It sneaked into the code a while back and I meant to remove it, but forgot. It was simply returning (int32)(frame_number*audioSamplesPerFrame) which is so wrong on so many levels. So R.I.P.
IanB is offline   Reply With Quote
Old 22nd June 2008, 18:48   #22  |  Link
Gavino
Avisynth language lover
Originally Posted by gzarkadas View Post
I wonder whether it would worth the effort to make the global vartable being just an alias (for not breaking existing code) of the script-level local vartable and get rid of the global keyword in exchange for a new can of worms .
@gzarkadas: Much as I would like to see changes in the way variable scopes operate in Avisynth, I think this probably is too big a can of worms to open, at least in Avisynth 2.5x.
I think any revision worth doing would be difficult to do a in a 100% backwards compatible way, and it certainly would require at least some changes to the parser and evaluating engine (something I know you have a particular aversion against ).
@IanB: I see we haven't convinced you enough to put the 'global current_frame' change into the latest release.
When does voting close?
Votes so far:
For : 3 (Gavino, gzarkadas, Wilbert)
Against: 1 (IanB)
Abstentions: several 1000's
Gavino is offline   Reply With Quote
Old 22nd June 2008, 21:05   #23  |  Link
Wilbert
In that case, I think such a change doesn't belong in a release candidate
Wilbert is offline   Reply With Quote
