Old 7th July 2018, 10:14   #3081  |  Link
unix
core.ffms2.Source("AFX.avi", alpha = True)
this is how it should be =)
unix is offline   Reply With Quote
Old 9th July 2018, 08:52   #3082  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Go test R44-RC1. Especially the fixed stuff like the crop bug. Will make a release in a few days if no serious regression is found.
r44:
fixed crop with compatbgr32 format where top and bottom crop would be switched
fixed crash in scdetect with one frame clips, now it simply returns an error since the operation is pointless
fixed potential multithreading issues in vsscript (stuxcrystal)
the resizer will now properly apply a shift even if no actual resizing/format conversion is being done
updated to zimg v2.7.4 to fix crash that only happens on core2 quad cpus
updated visual studio runtimes in installer
updated pismo runtime
added experimental large page support and changed cache logic (sekrit-twc)
minor documentation updates
Myrsloik is online now   Reply With Quote
Old 9th July 2018, 09:19   #3083  |  Link
ChaosKing
I get Failed to initialize VapourSynth environment after updating to RC1.
Python 3.6.5 is installed. Tested via vspipe and blankclip script.
I tried to restart my pc and reinstalled VS, didn't help.
Edit:
Reinstalled R43 again -> it works
Reinstalled R44rc1 -> Failed to initialize VapourSynth environment
EDIT2:
works good now with fixed link, thx
Old 9th July 2018, 09:38   #3084  |  Link
Myrsloik
Myrsloik's Avatar
Edit:
Doh, the 64bit python module was miscompiled for some reason. Link updated with a fixed version now.
Old 11th July 2018, 13:05   #3085  |  Link
Myrsloik
Myrsloik's Avatar
I have created a simple repository which can now basically install havsfunc and all its dependencies with one simple command.
VSRepo test2
Usage:
vsrepo.py install havsfunc
vsrepo.py upgrade all
vsrepo.py list
You can also add the -p switch to run it in portable mode and -f to force unknown versions of plugins to be upgraded.
Files will be installed to %APPDATA%\VapourSynth\PluginsXX and %APPDATA%\Python\X.Y\site-packages
(also known as the per user autoload directory and python's per user site directory)
All installed files will by default end up in the path. Make sure that the portable python directory is also the working directory when running in portable mode.
HELP CREATING MORE PLUGIN DEFINITIONS WELCOME. See the files in the local folder for examples.
Old 11th July 2018, 13:47   #3086  |  Link
ChaosKing
Nice.
I had similar ideas but no time and motivation...
I have gathered almost all plugins & many scripts in a big json file incl. dependencies. It should be very easy to generate near ready plugin definitions with this: https://www53.zippyshare.com/v/WHUKg6fV/file.html
Scripts have "2 dependencies". The dependencies to import a script and dep. for each function.
example:
  "com.wolframrhodium.bilateralGPU": {
    "namespace": "bilateralgpu",
    "identifier": "com.wolframrhodium.bilateralGPU",
    "name": "BilateralGPU",
    "type": "plugin",
    "weblinks": [
        "name": "source",
        "link": "https://github.com/WolframRhodium/VapourSynth-BilateralGPU"
    "description": "Bilateral filter for VapourSynth based on the OpenCV-CUDA library.",
    "functions": {
      "Bilateral": {
        "defaults": "clip, sigma_spatial=1.0, sigma_color=1.0, planes, kernel_size=0, borderMode=4, device=0",
        "description": "Bilateral filter is a non-linear, edge-preserving and noise-reducing smoothing filter for images.",
        "bitdepth": "32",
        "gpusupport": "CUDA",
        "parameters": "clip:clip;sigma_spatial:float[]:opt;sigma_color:float[]:opt;planes:int[]:opt;kernel_size:int[]:opt;borderMode:int[]:opt;device:int[]:opt",
        "tags": [
          "Bilateral"
"havsfunc.py": {
    "namespace": "havsfunc",
    "shortalias": "haf",
    "name": "havsfunc",
    "description": "Holy's ported AviSynth functions for VapourSynth",
    "weblinks": [
        "name": "source",
        "link": "https://github.com/HomeOfVapourSynthEvolution/havsfunc"
        "name": "doom9-link",
        "link": "https://forum.doom9.org/showthread.php?t=166582"
    "type": "script",
    "dependencies": [
      "mvsfunc",
      "adjust",
      "mv",
      "nnedi3_resample"
    "dependencies-optional": [],
    "functions": {
      "daa": {
        "defaults": "c, nsize=None, nns=None, qual=None, pscrn=None, int16_prescreener=None, int16_predictor=None, exp=None, opencl=False",
        "description": "Anti-aliasing with contra-sharpening by Didée",
        "bitdepth": "unknown",
        "weblinks": [
            "name": "Avisynth wiki",
            "link": "http://avisynth.nl/index.php/DAA"
        "dependencies": [
          "nnedi3",
          "nnedi3cl",
          "rgvs",
          "znedi3"
        "tags": [
          "antialiasing"
      "santiag": {
        "defaults": "c, strh=1, strv=1, type='nnedi3', nsize=None, nns=None, qual=None, pscrn=None, int16_prescreener=None, int16_predictor=None, exp=None, aa=None, alpha=None, beta=None, gamma=None, nrad=None, mdis=None, vcheck=None, fw=None, fh=None, halfres=False, typeh=None, typev=None, opencl=False",
        "description": "santiag v1.6 - Simple antialiasing",
        "dependencies": [],
        "tags": []
Old 11th July 2018, 14:05   #3087  |  Link
ChaosKing
Could you add a 7z.exe parameter? My 7zip is not installed in "c:\\Program Files\\7-Zip\\7z.exe"
Old 11th July 2018, 14:40   #3088  |  Link
Myrsloik
Myrsloik's Avatar
I will in the next version and registry detection for the default. Completely forgot about it...
Old 11th July 2018, 14:43   #3089  |  Link
ChaosKing
"Installed" via portableApps
Edit: here are some packages
It seems like the local folder is not necessary!?
minideen + smoothuv
	"name": "MiniDeen",
	"type": "Plugin",
	"description": "MiniDeen is a spatial denoising filter. It replaces every pixel with the average of its neighbourhood. This is a port of the 'a2d' method from the Avisynth plugin Deen, version beta 2.",
	"website": "https://github.com/dubhater/vapoursynth-minideen",
	"doom9": "https://forum.doom9.org/showthread.php?t=175587",
	"category": "Denoising",
	"identifier": "com.nodame.minideen",
	"namespace": "minideen",
	"releases": [{
		"version": "v1",
		"win32": {
			"url": "https://github.com/dubhater/vapoursynth-minideen/releases/download/v1/vapoursynth-minideen-v1-win32.7z",
			"files": ["libminideen.dll"],
			"hash": { "libminideen.dll": "250be1497035a51cabca751692010bd9300d9353" }
		"win64": {
			"url": "https://github.com/dubhater/vapoursynth-minideen/releases/download/v1/vapoursynth-minideen-v1-win64.7z",
			"hash": { "libminideen.dll": "7dfbdd3c7adf05e0deb7e99feee6b72000008d27" }
	"name": "SmoothUV",
	"type": "Plugin",
	"description": "SmoothUV is a spatial derainbow filter.",
	"website": "https://github.com/dubhater/vapoursynth-smoothuv",
	"doom9": "https://forum.doom9.org/showthread.php?t=175520",
	"category": "Derainbowing",
	"identifier": "com.nodame.smoothuv",
	"namespace": "smoothuv",
	"releases": [{
		"version": "v2",
		"win32": {
			"url": "https://github.com/dubhater/vapoursynth-smoothuv/releases/download/v2/vapoursynth-smoothuv-v2-win32.7z",
			"files": ["libsmoothuv.dll"],
			"hash": { "libsmoothuv.dll": "67cfb0cec822c5f8ca3caef2b48034ebf22082e6" }
		"win64": {
			"url": "https://github.com/dubhater/vapoursynth-smoothuv/releases/download/v2/vapoursynth-smoothuv-v2-win64.7z",
			"hash": { "libsmoothuv.dll": "2780e39bd1c974aea580c57f2f041233fc9db1e6" }
	"name": "RainbowSmooth",
	"type": "PyScript",
	"description": "RainbowSmooth is a script which adds edge detection to SmoothUV. It is a port of the Avisynth function rainbow_smooth()",
	"identifier": "RainbowSmooth",
	"modulename": "RainbowSmooth",
	"dependencies": [
		"releases": [{
		"version": "v1",
		"script": {
			"url": "https://raw.githubusercontent.com/dubhater/vapoursynth-smoothuv/master/RainbowSmooth.py",
			"files": ["RainbowSmooth.py"],
			"hash": { "RainbowSmooth.py": "2479c799ad1be9b1e6dfc2c50bf8595310934b2a" }
Old 11th July 2018, 17:07   #3090  |  Link
ChaosKing
Now the question is: Is RainbowSmooth v1 or v2? it is in the same git repo as smoothuv but was not changed since the v1 release and is not inside the release zip. :-/
Old 11th July 2018, 22:16   #3091  |  Link
Myrsloik
Myrsloik's Avatar
I figured it out, added all your entries now
Old 11th July 2018, 22:45   #3092  |  Link
Myrsloik
Myrsloik's Avatar
VSRepo discussion continues in this thread
Old 13th July 2018, 16:24   #3093  |  Link
Myrsloik
Myrsloik's Avatar
R44 released. It's a real maintenance release with nothing exciting added. Have fun...
Old 13th July 2018, 17:11   #3094  |  Link
ChaosKing
msvcp140_1.dll & msvcp140_2.dll <- are these testing leftovers? (see portable64 zip)
Will the next version be based on python 3.7?
Old 13th July 2018, 18:00   #3095  |  Link
Myrsloik
Myrsloik's Avatar
They're official runrine dlls and not a leftover.
Yes, next version will be for python 3.7.
Old 19th July 2018, 21:31   #3096  |  Link
lansing
Is there a specific filter that can double the frames of a clip? I wanted to convert a 30fps clip to 60fps by doubling each frame but I couldn't find any info from the documentation.
Old 19th July 2018, 21:41   #3097  |  Link
Myrsloik
Myrsloik's Avatar
Just plain repeat of the same frame twice?
std.Interleave([clip, clip])
Old 19th July 2018, 21:49   #3098  |  Link
lansing
Thanks it works.
Old 20th July 2018, 22:34   #3099  |  Link
lansing
I'm trying to pipe my script to ffmpeg to use its hardware encoding like this
vspipe --y4m "bob.vpy" - | ffmpeg -i pipe: -c:v h264_nvenc -preset llhq -rc:v vbr_minqp -qmin:v 19 -qmax:v 21 -b:v 2500k -maxrate:v 5000k -profile:v high hw_output.mp4
For some reason it has been pointing to the 32 bit version of vapoursynth, which result in failed attempt with errors like "znedi3 does not exist" because the required plugins in my script only has a 64 bit version. I checked my pc, my python default is 64 bit and the ffmpeg is also 64 bit, why does it still calling the 32 bit vapoursynth?
Old 21st July 2018, 03:31   #3100  |  Link
lansing
How do you make sure that vspipe.exe you are calling is 32 bit? I guess it's in your PATH environment variable.
I checked the PATH variable, it was not there. I tried uninstall and reinstall again, but the problem still existed.
speed, vaporware, vapoursynth
