Old 15th March 2019, 13:16   #3281  |  Link
jackoneill
unsigned int
jackoneill's Avatar
Originally Posted by _Al_ View Post
I might found a culprit, but not sure what to do with it or how to fix it.
for example NTSC video there is 1 byte per sample, if I get_stride for all three planes:
f = clip.get_frame(0)
print(f.get_stride(0),f.get_stride(1),f.get_stride(2))
I get:
736 384 384 (expected: 720 360 360)
for HDV video from HDV tape camcorder (shooting 1440x1080) I get:
1440 736 736 (expected: 1440 720 720)
after resize I get even values, like resizing NTSC video to 640x480 I'd get:
640 320 320
or resizing that HDV video to 1920x1080, I'd get:
1920 960 960
Those are expected numbers and encoding is also ok, so this looks like a cause to offset the output if resizing is not done. If I resize to the same resolution values stay the same, it would not help.
Is there any way to get those values even without resizing? What are those data that are trailing (or preceding) each line in plane array? If it is not stride itself (wrong value) that offsets things.
This is a known bug which will be fixed in the next release.
There was a bit of code in clip.output() which assumed that the width multiplied by bytes_per_sample is the same as the stride. This is only true when the width multiplied by bytes_per_sample is a multiple of 32.
This is why you have a problem with 720x___ but not with 1280x___, 1440x____ or 1920x____. 720 / 32 = 22.5; 1280 / 32 = 40; 1440 / 32 = 45; 1920 / 32 = 60.
The stride (the distance between two consecutive rows) is not always the same as the width multiplied by bytes_per_sample in order to make every row start at a memory location which is a multiple of 32. (The first row starts at a multiple of 32 because that's what VapourSynth requests from the memory allocator.) This apparently makes filters run faster. The extra (stride - width * bytes_per_sample) bytes are left unused.
Buy me a "coffee" and/or hire me to write code!
jackoneill is offline   Reply With Quote
Old 15th March 2019, 18:50   #3282  |  Link
_Al_
Thank you for explanation, now when it is clear it is even workable.
Width for output() function now has to be any even number x 32. Multiple of odd number would not work. So any width divided by 32 with even result would work.
Thank you.
_Al_ is offline   Reply With Quote
Old 15th March 2019, 21:24   #3283  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Thank you.
This will be fixed in the next release
Old 15th March 2019, 21:36   #3284  |  Link
_Al_
Thank you,
that direct export is a fantastic feature where even progress update is available
Old 16th March 2019, 00:14   #3285  |  Link
asarian
Encoding using clip.output() right from vapoursynth script itself, where input video is ANY anamorphic video like HDV camcorder M2T video or NTSC DV or VOB gives jagged lines....
Some interesting script files you have there. Speaking of which, is there a variable for the running script name itself?
Old 16th March 2019, 01:02   #3286  |  Link
_Al_
Not sure if I understand, do you want to give it output name as script name?
You'd use __file__ variable, if you want just basename, you'd do something like:
import os
output_dir = r'F:\Destination'
output = os.path.join(output_dir, os.path.basename(__file__)+'.264')
In practical terms you'd perhaps always import your modul for encoding, you'd put that encoding part as a separate py file and put it in Python\Lib\vapoursynth directory and just import it as a modul in each script and run it. You couldpass the whole cmd line as a variable string and let that sorted out in that modul with shlex.split(cmd as a string) etc.
Old 16th March 2019, 01:38   #3287  |  Link
asarian
import os
^^ That's exactly what I wanted to do!
Old 16th March 2019, 11:16   #3288  |  Link
asarian
Thank you,
So, how do you call the script?! When I just try
'VSPipe f:\jobs\test.vpy'
It tells me 'No output file specified'
I must be doing it wrong.
Old 16th March 2019, 20:22   #3289  |  Link
_Al_
vspipe is another (perhaps preferred) way how to encode your script. It pipes frames into an encoder of your choice from OUTSIDE of vapoursynth script *.vpy or *.py,
but method from above, vapoursynth outpus raw frames directly from script itself, you bypass vspipe, but you need to have *.py, not *.vpy because you run Python basically , vapoursynth does its wrapping part in Python and serving frames with clip.output(). You just run script itself with this method and it will start encoding, you can choose a python consol of your choice (IDLE for example came with Python, so you should have it) and pressing F5 or even using VSEditor, but VS Editor needs clip.set_output(), otherwise it would not let script run, therefore encode (and then showing preview). If you want to avoid preview popup after encoding, you'd just evaluate script.
if you do not use a console and prefer windows command line, you'd need to run:
python3 "test.py"
or
python "test.py"
Old 17th March 2019, 14:36   #3290  |  Link
ChaosKing
Why is the avisynth RemoveDirt.dll only availible if the RemoveDirtVS_x64.dll is not autoloaded.
My steps
core.avs.LoadPlugin(r"D:\avs_plugins64\RemoveDirt.dll") # no loading error
But clip = core.avs.RestoreMotionBlocks(clip) is not availible
Checking with print(core.get_plugins()) confirms that com.fakeurl.removedirtvs is loaded but nothing with avisynth.
Now without RemoveDirtVS_x64.dll
print(core.get_plugins()) -> RestoreMotionBlocks is available
'com.vapoursynth.avisynth': {'namespace': 'avs', 'identifier': 'com.vapoursynth.avisynth', 'name': 'VapourSynth Avisynth Compatibility', 'functions': {'LoadPlugin': 'path:data;', 'RestoreMotionBlocks': 'c1:clip;c2:clip ...
So why is VS-RemoveDirt blocking the avisynth RemoveDirt functions?
VS and AVS dlls: https://www.dropbox.com/s/nkho8s2pje...irtVS.zip?dl=1
Old 18th March 2019, 04:24   #3291  |  Link
Iron_Mike
is it possible to output the version number of a loaded VS plugin ? if so, what is the command ?
Iron_Mike is offline   Reply With Quote
Old 18th March 2019, 10:39   #3292  |  Link
Myrsloik
Myrsloik's Avatar
There are no exported version numbers
Old 18th March 2019, 22:47   #3293  |  Link
asarian
python3 "test.py"
or
python "test.py"
Thank you!
Old 19th March 2019, 01:16   #3294  |  Link
ChaosKing
I have this "prop transfer" code:
def _Transfer(n, f):
   fout = f[0].copy()
   fout.props['_Diff'] = f[1].props['_Diff']
   return fout
alt_clip = core.std.ModifyFrame(alt_clip, [alt_clip, alt_clip_butt], selector=_Transfer)
Is it possible to make _Transfer() more universal, like this _Transfer(n, f, prop_name), so I can pass any prop -> f[1].props[prop_name] ? If yes, how to call/pass it?
@Myrsloik have you seen my RemoveDirt post? https://forum.doom9.org/showthread.p...51#post1869151
Old 19th March 2019, 05:13   #3295  |  Link
WolframRhodium
   fout = f[0].copy()
   return fout
from functools import partial
def _Transfer(n, f, prop_name):
   fout = f[0].copy()
   fout.props[prop_name] = f[1].props[prop_name]
   return fout
alt_clip = core.std.ModifyFrame(alt_clip, [alt_clip, alt_clip_butt], selector=partial(_Transfer, prop_name="_Diff"))
WolframRhodium is offline   Reply With Quote
Old 19th March 2019, 10:44   #3296  |  Link
ChaosKing
Exactly what I wanted, perfect
Old 19th March 2019, 15:07   #3297  |  Link
lansing
When I try to extract planes and merge them back together, I got error "ShufflePlanes: Plane 1 and 2 are not subsampled multiples of first plane"?
clip_yuv16 = core.resize.Bicubic(clip, format=vs.YUV420P16)
y_clip = core.std.ShufflePlanes(clip_yuv16 , planes=0, colorfamily=vs.YUV)
u_clip = core.std.ShufflePlanes(clip_yuv16 , planes=1, colorfamily=vs.YUV)
v_clip = core.std.ShufflePlanes(clip_yuv16 , planes=2, colorfamily=vs.YUV)
yuv16_new = core.std.ShufflePlanes(clips=[y_clip, u_clip, v_clip], planes=[0,0,0], colorfamily=vs.YUV)
Old 19th March 2019, 15:35   #3298  |  Link
Wolfberry
Helenium(Easter)
Wolfberry's Avatar
y_clip = core.std.ShufflePlanes(clip_yuv16 , planes=0, colorfamily=vs.YUV) ←
u_clip = core.std.ShufflePlanes(clip_yuv16 , planes=1, colorfamily=vs.YUV) ←
v_clip = core.std.ShufflePlanes(clip_yuv16 , planes=2, colorfamily=vs.YUV) ←
You need to use GRAY (not YUV) if you want to extract individual planes.
Monochrome Anomaly
Wolfberry is offline   Reply With Quote
Old 19th March 2019, 15:51   #3299  |  Link
lansing
Thanks it works
Old 27th March 2019, 20:17   #3300  |  Link
Selur
Selur's Avatar
I'm wondering could someone adjust https://github.com/HENDRIX-ZT2/Deep-Video-Deinterlacing to be used as a Vapoursynth filter? sounds interesting,..
speed, vaporware, vapoursynth
