Old 4th April 2020, 09:03   #1621  |  Link
Patman
Patman's Avatar
Originally Posted by chipsteps View Post
thank you very muck! So chromaloc customizations are the default and can't be manually set?
You can change chromaloc under x265 options -> VUI 2 if you want.
Tools for StaxRip | x264 - x265
Patman is offline
Old 4th April 2020, 16:38   #1622  |  Link
Zetti
MKVToolNix v45.0.0 is released.
Zetti is offline
Old 4th April 2020, 16:43   #1623  |  Link
stax76
stax76's Avatar
Thanks, I've bookmarked your post.
stax76 is offline
Old 5th April 2020, 00:02   #1624  |  Link
impei
Hi, I'm using Staxrip 2.0.8.0 stable, and I can't crop more than 40% from any given side. Is there a way to fix this? I've looked through the settings and can't find anything. Thanks.
impei is offline
Old 5th April 2020, 00:51   #1625  |  Link
chipxtreme
MKVToolNix 45.0.0 is out.
Latest beta's haven't had NVEnc upgraded either.
chipxtreme is offline
Old 5th April 2020, 06:54   #1626  |  Link
JKyle
App Digger
JKyle's Avatar
Two errors
@Stax
I'd like to report two errors.
1) Opening/Remuxing TS to MKV failure
I opened an issue about this error on GitHub, so please take a look.
2) qaac fails to encode some flac files
I ran into this weird error (pop-up message) while encoding a 6 channel flac audio stream in a video file into a stereo aac stream using qaac.
------------------- Audio encoding 1 using qaac 2.68 -------------------
D:\Utilities\StaxRip\Apps\Audio\qaac\qaac64.exe --tvbr 62 --delay -0.001 --normalize "D:\Work\tmp\test_temp\test ID1 -1ms Japanese.flac" -o "D:\Work\tmp\test_temp\test ID1 Japanese_a1.m4a"
qaac 2.68, CoreAudioToolbox 7.10.9.0
ERROR: m_module.stream_decoder_seek_absolute(m_decoder.get(), count)
StaxRip.ErrorAbortException: Audio encoding 1 using qaac 2.68 returned error exit code: 2 (0x2)
It's unclear what the exit code means, in case it's a Windows system error then it possibly means:
The system cannot find the file specified
   at StaxRip.Proc.Start() in D:\Projekte\VB\staxrip\General\Proc.vb:line 394
   at StaxRip.GUIAudioProfile.Encode() in D:\Projekte\VB\staxrip\General\AudioProfile.vb:line 676
   at StaxRip.GlobalClass._Closure$__._Lambda$__31-0() in D:\Projekte\VB\staxrip\General\GlobalClass.vb:line 101
   at System.Threading.Tasks.Parallel.<>c__DisplayClass4_0.<Invoke>b__0()
--- End of stack trace from previous location where exception was thrown ---
   at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
   at StaxRip.GlobalClass.ProcessJob(String jobPath) in D:\Projekte\VB\staxrip\General\GlobalClass.vb:line 133
The original video file is here and the log file is here.
I never had an error when I re-encoded aac streams with 2 channels using qaac even if I set the decoding method to FLAC.
Thanks in advance.
JKyle is offline
Old 5th April 2020, 08:33   #1627  |  Link
sneaker_ger
It's probably because the file was split at some point without re-creating FLAC headers/re-encoding the FLAC part. This was discussed very recently in the MKVToolNix thread. If you use --delay option of qaac it tries seeking and will fail. (Piping from the mkv using ffmpeg should still work.)
https://gitlab.com/mbunkus/mkvtoolni...-not-supported
sneaker_ger is offline
Old 5th April 2020, 09:06   #1628  |  Link
JKyle
App Digger
JKyle's Avatar
Thanks for your advice.
You're right. Setting the decoding method to Pipe solved the problem by piping the flac file via ffmpeg.
In this setting, qaac encodes the wav file piped via ffmpeg instead of directly dealing with the flac file.
D:\Utilities\StaxRip\Apps\Encoders\ffmpeg\ffmpeg.exe -i "D:\Work\tmp\test_temp\test ID1 -1ms Japanese.flac" -ac 2 -loglevel fatal -hide_banner -f wav - | D:\Utilities\StaxRip\Apps\Audio\qaac\qaac64.exe --tvbr 62 --delay -0.001 --normalize --gain 5.4 - -o "D:\Work\tmp\test_temp\test ID1 Japanese_a1.m4a"
JKyle is offline
Old 5th April 2020, 09:08   #1629  |  Link
taulen
Originally Posted by Z'Hadum View Post
Why do you not simply create two jobs for this? If you start staxrip two times, you get also your parallel processing....
Are you able to do this ?
Whenever I try to do two encoding instances of the same source file it always crashes both instances. This is when doing 2-pass x264 cpu encoding at least.
taulen is offline
Old 5th April 2020, 10:22   #1630  |  Link
craigpro
Hi all,
I downloaded 2.1.0.2 beta as I was having issues with NeroEnc freezing in 2.0.8.0 stable and I noticed this error when encoding a video tonight:
C:\Staxrip\Apps\Encoders\NVEnc\NVEncC64.exe --cqp 18:20:22 --codec h265 --preset quality --level 5.1 --output-depth 10 --qp-init 20 --qp-max 22 --qp-min 18 --aq --aq-temporal --gop-len 240 --lookahead 16 --slices 2 --multiref-l0 4 --multiref-l1 4 --strict-gop --nonrefp --weightp -i D:\Temp\videosource_temp\videosource.avs -o D:\Temp\videosource_temp\videosource_out.h265
nvenc : Error on nvEncGetEncodePresetConfig: 4 (NVENC this indicates that device passed to the API call is invalid)
multiref(L1) is lowered 4 -> 3 due to HEVC spec.
weighted prediction with B frames unsupported.
NVEncC (x64) 4.68 (r1402) by rigaya, Mar 7 2020 13:54:44 (VC 1916/Win/avx2)
OS Version Windows 10 x64 (18363)
CPU AMD Ryzen 7 3700X 8-Core Processor (8C/16T)
GPU #0: GeForce RTX 2060 (1920 cores, 1710 MHz)[PCIe3x16][445.75]
NVENC / CUDA NVENC API 9.1, CUDA 11.0, schedule mode: auto
Input Buffers CUDA, 32 frames
Input Info Avisynth+ 2.60(yv12)->nv12 [AVX2], 1280x720, 24000/1001 fps
Vpp Filters copyHtoD
cspconv(nv12 -> p010)
Output Info H.265/HEVC main10 @ Level 5.1
1280x720p 1:1 23.976fps (24000/1001fps)
Encoder Preset quality
Rate Control CQP I:18 P:20 B:22
Lookahead on, 16 frames, Adaptive I, B Insert
GOP length 240 frames
B frames 3 frames [ref mode: disabled]
Ref frames 3 frames, MultiRef L0:4 L1:3
AQ on
CU max / min auto / auto
Others mv:auto nonrefp
what does the error mean please?
Should I be using other NVenc settings?
Sorry for my noobidity. Thank you.
EDIT: nvidia driver 445.75
craigpro is offline
Old 5th April 2020, 18:34   #1631  |  Link
stax76
stax76's Avatar
Thanks, updated.
I don't want to waste time and add useless code so it would need a request with explanation why it's not sufficient, in the Options dialog there is a crop section where values can be edited.
It's hardly possible to handle everything perfectly by default. In this case you can customize the command line at:
Main Menu > Tools > Settings > Pre Processing > ffmpeg: Re-mux TS to MKV > Edit
Command: powershell.exe
Arguments: -nologo -file "D:\ffmpegTsToMkv.ps1" "%source_file%" "%temp_file%.mkv"
$muxingMode = Get-MediaInfoValue ($args[0]) -Kind Audio -Parameter MuxingMode
if ($muxingMode -eq 'ADTS')
    $bsf = '-bsf:a', 'aac_adtstoasc'
ffmpeg -hide_banner -analyzeduration 100M -probesize 50M -i $args[0] -map 0 -c copy @bsf -y $args[1]
You need to install Get-MediaInfo and add ffmpeg to the path env var or use the full path or use the build from today, it adds all exe tools to the path env var of the process and adds all macros as env vars.
You can process it with one instance sequentially or maybe use the Event Command feature where you can run a command line or powershell script.
I can't help with it but you can use the nvenc tracker:
Main Menu > Help > Apps > nvenc > Online > Issues
2.1.0.5 Beta
- new: the global setting 'Add filter to convert chroma subsampling to 4:2:0'
       uses now ConvertToYUV420 instead of ConverttoYV12
- new: in custom command line based demuxers and in the ExecuteCommandLine
       command the path environment variable of the process has all exe tools
       added and all macros are available as environment variables
- new: AviSynth filter profile using ColorYUV function
- update: mkvtoolnix 45.0.0
- update: nvenc 4.69
- update: DFTTest 1.9.5 Clang
- update: L-Smash-Works 2020-03-22 HolyWu
- update: ffms2 89bd1e1 StvG
- fix: the MediaInfo Folder view did not work unless Get-MediaInfo was installed,
       now it should work even without being installed, please try and give feedback
https://www.dropbox.com/sh/4ctl2y928...dd3yqcAHa?dl=0
https://1drv.ms/u/s!ArwKS_ZUR01g0kH4...3GaKe?e=qbOfGS
stax76 is offline
Old 5th April 2020, 19:40   #1632  |  Link
Patman
Patman's Avatar
Thanks, updated.
2.1.0.5 Beta
What are the diffrences between 2.1.04 beta and 2.1.0.5 beta?
Some tools were updated... DFTTest 1.9.6, L-Smash-Works 2020-03-28 HolyWu (L-Smash-Works 2020-03-22 HolyWu is buggy), Xvid_encraw 1.3.7 (My Builds).
Patman is offline
Old 5th April 2020, 23:29   #1633  |  Link
Atlantis
In the log, what does Avg QP mean? If it's higher does it mean the picture quality of the encoded file is better?
Atlantis is offline
Old 5th April 2020, 23:47   #1634  |  Link
JKyle
App Digger
JKyle's Avatar
Nope, it's the opposite.
QP = quantization parameter.
JKyle is offline
Old 5th April 2020, 23:48   #1635  |  Link
JKyle
App Digger
JKyle's Avatar
Thanks for the info.
And QSVEnc is updated to 4.00.
JKyle is offline
Old 6th April 2020, 02:14   #1636  |  Link
jlw_4049
Reporting a bug @Stax76
I'm on version 2.0.8.0
The issue is circled in red.
No matter how many times I create an audio profile with the name that I want it to be. It defaults right back to taking on the track name of what it's encoding from. I have tried creating the profile many different ways and times.
Thanks!
EDIT: Found another bug.
I'm trying to setup some batch encode profiles.
When I setup the profile and set my bitrate here
https://i.imgur.com/4wYNilT.jpg
it will not carry over to the encode if I do multiple files with the same settings (batch)
If i force the command with a custom command it does however work here
https://i.imgur.com/3YRA0kv.png
jlw_4049 is offline
Old 6th April 2020, 02:43   #1637  |  Link
taulen
This is what I do, but with a AMD 3950x it only uses about 50-60% of the CPU, so doing multiple instances REALLY shortens the time. So currently I copy the source file temporarily and run it 2 times that way. But its a bit of a pain tbh :P
What do you mean by the second part of your reply, Im no expert so that went a bit over my head. And thanks for keeping Staxrip alive ! <3
taulen is offline
Old 6th April 2020, 06:41   #1638  |  Link
stax76
stax76's Avatar
There was a bug where Main Menu > Folders showed an error, the underlying function is probably used by other features as well.
I've updated it except xvid for which I've removed the binaries because it's very old, the xvid encoder has still a profile in the video encoder menu and people that try to use it will see the Apps dialog, the download button is linked to your folder so it's easy for people to download.
Also updated
I've changed it now that it uses the title of the source only when the title in the profile is empty.
Maybe try chunk encoding with ripbot or mediacoder, staxrip does not have such a feature and I don't have interest at this time. Building an app capable of it might not be terribly difficult for an experienced programmer, maybe a day or two for a prototype, it should be possible to build it as a console app that can be used as drop in replacement with identical CLI as the encoder.
There are some advanced features for power users, unfortunately there is no documentation and I usually only help advanced users with it these days. I have a plan to write documentation, some projects have really awesome documentation, for instance mpv or x265.
https://mpv.io/manual/master
https://x265.readthedocs.io/en/latest/cli.html
stax76 is offline
Old 6th April 2020, 11:30   #1639  |  Link
taulen
No worries, I manage fine using Staxrip, which I have used for a few years by now, and really like. I was just curious if it was a feature that was "hidden away" or something, and I fully understand that you wont take the time to do it. I think I remember seeing you taking a break or "leaving" behind Staxrip at an earlier point, so Im just glad you continue the updating in any way you can and find the time for, thanks ! =)
taulen is offline
Old 6th April 2020, 11:40   #1640  |  Link
Atlantis
An interesting observation I have made with encoding x265 4K. Encoding with a lower CRF takes more time. CRF 21 is a little slower than CRF 22 and CRF 20 is significantly slower.
I would have thought that if you wanted a better quality and use less compression, it should be faster to encode but it is the opposite. So, it is interesting on how to decide which CRF to use. Not only it depends on the quality you want, you have to consider how slow the encoding will be. I'm thinking that for me 4K CRF 20 is a no go for me. Too slow.
Atlantis is offline
