Old 14th April 2020, 23:25   #1701  |  Link
Lynx_TWO
Originally Posted by almanteka View Post
i installed Vapoursynth and the requiring packages just to test it out. it's possible to use it with mkv files converting to x265 using staxrip? what settings i need to use so staxrip use Vapoursynth? thanks in advance for any advice!
There's a couple things AVISynth does that Vaporsynth doesn't (yet) SuperRes is one
Lynx_TWO is offline
Old 15th April 2020, 06:56   #1702  |  Link
Natty
Noob
because avisynth uses lower RAM
Natty is offline
Old 18th April 2020, 13:54   #1703  |  Link
craigpro
Rigaya's NVenc 5.0 released
craigpro is offline
Old 20th April 2020, 09:53   #1704  |  Link
VincAlastor
SVT-AV1 v0.8.2 released 7 hours ago
https://github.com/OpenVisualCloud/S...ses/tag/v0.8.2
Latest SVT-AV1 encoder release brings new command line parameters,which is why Staxrip (2.1.0.8) integration should be revised, please.
I'm using following custom cmd right now:
--preset 6 --keyint 255 --irefresh-type 2 --scm 2
So just -q you can be set in staxrip GUI window.
The default value --irefresh-type 1 results in a problem to seek/skip in video stream. The problem seems to be known, but i can't find a solution. Maybe you know how to merge SVT-AV1 open GOPs with mkvmerge correctly, otherwise maybe you can think about to recommend users to use --irefresh-type 2 and longer GOPs up to 255 (256) in staxrip for now.
VincAlastor is offline
Old 21st April 2020, 07:57   #1705  |  Link
kalehrl
Is there something like 'analyse source' in staxrip?
I like this option which is present in MeGUI but I haven't found it in staxrip.
kalehrl is offline
Old 21st April 2020, 09:18   #1706  |  Link
VincAlastor
I tested Staxrip 2.1.0.9 test build. Integration of the modified SVT AV1 parameters works. --irefresh-type 1 is still not decoded correctly. So I assume that you haven't found a solution to the problem yet either.
Thanks for good and very fast implementation.
Old 21st April 2020, 20:18   #1707  |  Link
almanteka
where i can download the latest beta releases for StaxRip? since 2.1.0.1 i can't locate any download of the beta releases, only know about them in the changelog.md file. right now is at 2.1.0.9 and https://staxrip.readthedocs.io/intro.html#download send me to an page doesn't exist error! TIA!
almanteka is offline
Old 21st April 2020, 20:28   #1708  |  Link
Patman
Patman's Avatar
Look here
Tools for StaxRip | x264 - x265
Patman is offline
Old 21st April 2020, 21:38   #1709  |  Link
Atlantis
Question why do we have the msvc version of x265? What is it good for?
Atlantis is offline
Old 21st April 2020, 21:48   #1710  |  Link
Patman
Patman's Avatar
It was requested by some users and is not difficult to create. Compared to gcc8, it did better, but since gcc9 and above, this advantage has been gone.
Patman is offline
Old 22nd April 2020, 00:55   #1711  |  Link
almanteka
Originally Posted by Patman View Post
thanks!!!!
Old 22nd April 2020, 06:12   #1712  |  Link
Mister XY
Since Version 2.1.0.8 DGIndex is missing in package. But it is needet for mpeg2, vob etc.
Mister XY is offline
Old 22nd April 2020, 06:55   #1713  |  Link
stax76
stax76's Avatar
In v2.1.0.9 DGIndex is disabled by default, it can be enabled in the settings dialog.
The author had requested to remove it from the distribution.
stax76 is offline
Old 22nd April 2020, 15:51   #1714  |  Link
Mister XY
Is there any alternate for this "vob mpg DGIndex" problem?
Old 22nd April 2020, 17:09   #1715  |  Link
Patman
Patman's Avatar
You can still use DGIndex, you just have to activate it in the settings. DGIndex should just not be distributed with the package. And if you don't have DGIndex ready, you can download it.
Patman is offline
Old 22nd April 2020, 17:36   #1716  |  Link
DavidRyan
Is there any way to change the 'FLAC' audio encoding profile to use a FLAC binary instead of ffmpeg? Have a recently compiled FLAC binary I wanted to use but despite trying a few things I can't seem to make it available as an option so would appreciate any advice - guessing I'm missing something obvious.
DavidRyan is offline
Old 22nd April 2020, 18:54   #1717  |  Link
manolito
manolito's Avatar
Even the latest Version 1.5.8 of DGIndex/DGDecode is still licensed under the GPL. This means that it can be distributed without the author's permission as long as the GPL requirements are fulfilled. Of course the friendly way is to ask the author for permission, but for GPL software this is not required.
manolito is offline
Old 22nd April 2020, 18:55   #1718  |  Link
stax76
stax76's Avatar
I think you can use eac3to as encoder (there is an Encoder option), the libFLAC.dll it uses is from 2019.
There is a generic command line audio encoder where a custom command line can be used.
This generic audio encoder is probably still based on bat files and the general policy is to remove bat files from everywhere, it's probably the last feature where bat is used, there will be a replacement then, possibly using cmd.exe directly without bat file like the generic command line video encoder or more or less all command lines staxrip executes for job processing.
stax76 is offline
Old 22nd April 2020, 19:44   #1719  |  Link
Patman
Patman's Avatar
And you can follow the discuss in the other staxrip thread.
Patman is offline
Old 22nd April 2020, 20:26   #1720  |  Link
DavidRyan
Thanks for the advice stax76, will try those.
