Old 28th March 2009, 22:44   #4581  |  Link
nugmebot
1) Uninstall AviSynth
2) Reboot
3) Install AviSynth 2.5.8 (http://sourceforge.net/project/showf...ease_id=650255)
Thanks trying that now
Also now that I've done that it appears to be demuxing quicker? or is that just me
Old 29th March 2009, 00:23   #4582  |  Link
lister61
Sorry if already answered But Green Text readout top left
I have CPU usage, Resolution, etc readout encoded into some movies I rip. Top Left hand corner and is encoded into the MKV?
How do I stop this info form being encoded into my files.
lister61 is offline   Reply With Quote
Old 29th March 2009, 00:32   #4583  |  Link
Disable OSD in FFDshow
Old 29th March 2009, 02:04   #4584  |  Link
HouseCat
Im looking at getting a AMD 8750 triple core cpu to replace my core 2 duo e6400.
Would it increase my ripbot performance as my current system works at only 3fps on second pass.
I would get quad core but i'm on a budget.
HouseCat is offline   Reply With Quote
Old 29th March 2009, 05:57   #4585  |  Link
Ajax_Undone
I dont care so should you
Ajax_Undone's Avatar
Don't! AMD isn't as fast as Intel. Plus you would need to get a new motherboard.
My Installer's ||
Ajax_Undone is offline   Reply With Quote
Old 29th March 2009, 07:48   #4586  |  Link
HouseCat
Yes its common knowledge that AMD isn't as fast as some intels but like I said "im on a budget"
I was also looking at a PHENOM II X4 PROCESSOR 920 quad
My current mobo is a GA-965P-DS3 which with bios update could run newer intel CPU but meh.
Old 29th March 2009, 09:20   #4587  |  Link
jhmac
jhmac's Avatar
Why do you need this? Besides BDSup2Sub requires Java installed
I found it to be the easiest way to convert and add subs to video combined with RipBot264. Can you recommend a better way to do this?
jhmac is offline   Reply With Quote
Old 29th March 2009, 11:12   #4588  |  Link
zAndy1
I'm about to buy a new PC and was wanting to install the latest 64 bit Windows 7 beta on it, before I go down this route and make a very expensive mistake can I just check that Ripbot264 works fine on the 64bit version of Windows 7? I've read that Windows 7 prevents stuff like Haali Media Splitter and FFDShow being used, is that correct and if so how do you get around it? Basically at the moment I'm using ToNMT with AnydvdHD to rip my blu-ray discs and Ripbot264 to re-encode them, all I want is confirmation that I'll still be able to do that if I move to Windows 7 64 bit.
Andy
zAndy1 is offline   Reply With Quote
Old 29th March 2009, 11:26   #4589  |  Link
If you are lucky you can still find Q6600. It should not be very expensive. It works without problems at 3Ghz! I highly recommend this cpu!!!
False! Everything works well. AviSynth , FFDshow and Haali.
Old 29th March 2009, 16:10   #4590  |  Link
Sarreq Teryx
Location: Between a clown and a mime, holding an uzi to each head.
what happened to the option for deciding how to deal with differing audio/video lengths? I have videos where the last fractional second is getting cut off when I don't want it to.
And as I walk through the Valley of the Shadow of Death, Lord, thy balls and shaft, they comfort me, you annoint my head with oil, some salt, a dash of pepper, a sprigg of parsley......Lord?............Lord??? What dost thou intend to do with that fork???
Sarreq Teryx is offline   Reply With Quote
Old 30th March 2009, 06:26   #4591  |  Link
Ajax_Undone
You will still need to buy a new motherboard for your AMD (AM2+) and in order to get the full benefit of such processor it require a new Deck of Ram and you would need to find one that had you current Video config (ie ATI or Nvidia).
Usually when I am looking to upgrade I just build A new System. It seems to be cheaper that way.
My Installer's ||
Old 30th March 2009, 20:25   #4592  |  Link
unimatrix0
Hey guys, sorry if it's been asked before, tried googling but didn't find any help: Automatic Crop doesn't seem to work when resizing. I want to encode a blu-ray source to 720p, and use automatic crop to remove black bars, but the output ends up either stretched, or with black bars. Please help
unimatrix0 is offline   Reply With Quote
Old 30th March 2009, 23:29   #4593  |  Link
Saber007
Hi.
I uninstalled K-lite codec pack as recommended and am just using FFDSHOW and HAALI. Ripbot264 seems to be working fine. Great Program, Thanks.
One thing however that i have noticed is that not as many of my video files now generate thumbnails. Previously all my .m2ts and .ts blu-ray rips plus .MKV files would show thumbnails in explorer but since uninstalling K-Lite they are no longer working.
Am I missing a setting in FFDSHOW to get my thumbnails back. I turned the thumbnail option on in HAALI but it doesn't seem to have made a difference.
Thanks for any help.
Saber007 is offline   Reply With Quote
Old 31st March 2009, 02:06   #4594  |  Link
illestdomer2005
Anybody running an i7 920? How many FPS on 2-Pass with default settings? What other hardware are you using?
Currently I have a Q6700 at 3.33GHz and get about 9-10 FPS on second pass. If the i7s make a big difference there, I might take the plunge.
illestdomer2005 is offline   Reply With Quote
Old 31st March 2009, 10:06   #4595  |  Link
i7 is about 30 % faster at the same clock
Old 31st March 2009, 15:36   #4596  |  Link
hoju3508
I just click the 'Subtitle' button and select the .sup file.
Old 31st March 2009, 16:23   #4597  |  Link
illestdomer2005
Thanks, Atak. And I assume that the latest x264 maximizes all of that?
Old 31st March 2009, 16:24   #4598  |  Link
illestdomer2005
Same problem here with Polar Express last night. I don't have a fix, just manually adjusted.
Old 31st March 2009, 17:03   #4599  |  Link
unimatrix0
Yea.. I tried manual but it does't work either, it keeps resetting the size setting to "Do not resize" but I do want it to resize to 720p.
Old 31st March 2009, 17:28   #4600  |  Link
OHHHH MYYY GOOOD!!!!!! WHAT HAPPENS IF YOU SET CROP SETTINGS MANUALLY AND THEN 720p?!??!?!?!?!?
