2nd June 2015, 18:20 | #30681 | Link |
Whoever advised that using the High Speed HDMI cable would allow me to get 12bit not only @ 23Hz, but also at 60Hz was dead on right! I just got one of these cables and I can select 60Hz + 12bit in nVidia CP with no artifacts! I hope games will look better now!
BTW, is it a placebo effect that my games (Withcer 3) look better in 12bit mode than in 8bit mode? I know transitions are better, especially since I use a 1D LUT, but colors also seem richer! I tested my calibration done in 8bit with 12bit mode and there was no difference anywhere, and yet 12bit seems to produce richer colors... Last edited by XMonarchY; 2nd June 2015 at 19:23. |
2nd June 2015, 19:29 | #30682 | Link |
Also, I noticed an odd problem. I am getting an occasional stutter during my SMPTE 170M content playback that I have not had before... I can't seem to narrow down which setting causes it. There are no frame drops or glitches or delayed frames for 25-30 minutes and suddenly there is this stutter where the screen shakes for a second and then all is fine for the next 30 minutes. GPU is fine, all is stable. I did update MPC-HC to the latest nightly build, do you think that may be reason?
2nd June 2015, 21:29 | #30683 | Link | |
2nd June 2015, 22:13 | #30684 | Link |
here is my opinion on debanding.
i used a BD with a on of banding encoded with VC-1 with about 14 mbit combined with bad mastering. untouched: http://abload.de/img/untouchednwsn8.png madVR high: http://abload.de/img/madvrhighqesn8.png shiandow 1.0 0.0: http://abload.de/img/madvrnew1.00.036sp3.png shiandow 1.0 1.0: http://abload.de/img/madvrnew1.01.0wds61.png madVR high is stronger in debanding than shiandow 1.0 with margin 0.0 but a little bit more harmful too. margin 1.0 has a very bad effect on moving scene this effect is still visible with 0.0 margin but not visible with madVR high. so i give madVR high a clear edge in moving scenes. here a screen with the problem i call it clouding on the blue car it is way worse in moving. untouched: http://abload.de/img/untouched2xpuk6.png shiandow 1.0 1.0: http://abload.de/img/clouding61ucd.png shiandow 1.0 0.2: http://abload.de/img/clouding1.00.274ukn.png shiandow 1.0 0.0: http://abload.de/img/clouding1.00.0neuas.png madVR high: http://abload.de/img/cloudingmadvr5nux5.png a deblock filter before debanding may help shiandow's algorithm a lot. |
2nd June 2015, 22:25 | #30685 | Link | |
http://s000.tinyupload.com/?file_id=...04695651332179 |
2nd June 2015, 22:49 | #30686 | Link | |||
When madVR tries to copy the rendered frame to the backbuffer, exactly one out of four times it takes ca. 150-200ms. Every other time it takes 0ms (meaning no measurable time). I've no idea why copying to the backbuffer sometimes is so slow and sometimes so fast, and why it seems to have a certain rhythm. It could either be a bug in the GPU drivers, or it could be a misconfiguration of some sort. You already tried lowering the number of pre-presented frames without success, right? And you already double checked the NVidia GPU control panel to make sure that the number of pre-rendered frames is set to application control, correct? Have you changed the madVR flush settings at some point? Have you tried restoring the madVR default settings at some point, just in case? Are you running some background process which might access the GPU (e.g. GPU-Z, or similar)? Try closing all processes which are not strictly needed, including the browser. There's one more thing: In the original log I could see that madVR had to reset the VSync Direct3D device sometimes, because Direct3D reported it was "occluded". Which suggests that maybe some window might have covered the media player, at least for a short time. Does that make any sense to you? The test build you've tested with now doesn't reset the VSync device, anymore. I had hoped this would make a difference, but seemingly it doesn't. |
3rd June 2015, 01:05 | #30687 | Link |
Thanks - i try
3rd June 2015, 01:33 | #30688 | Link | |
All the flush settings are at default, I never had need to touch them, and If I had, it would be corrected when I reset to default settings. nVidia's control panel is set globally for "application control" for frames. I had hoped nVidia's new 353.06 drivers might have an effect but it appears to have made no difference. I don't have gpu-z running nor any type of gpu overclocking/monitoring software running. I have tried closing processes to bare minimum with no changes. I messed around a little more with the new .ax tonight One thing I noticed that on the untouched, original .88.10 .ax, changing the exclusive mode present frames in advance didn't change the behavior of the queue, it would stay at 1-4/X until I set it below that. Even then, it would stay 1-4, 1-3, 1-2, etc. The latest madVRtest5.ax, the presented frames will completely fill if set to 4. (4-4/4). With some more queue adjustments, I currently have all the queues filling up, using .88.10 and MadVRtest5.ax Decoder queue: 14-15/15 Upload queue: 8-9/9 Render queue: 8-9/9 Present queue: 4/4-4 (lower than I like but the highest setting that works) Also, remember me mentioning that the Decoder queue (in exclusive mode) would always show one more than it should, such as 14-16/15? When I set the exclusive mode to 4 frames or below, it will show correctly, 14-15/15. Not sure if that has anything to do with this issue, though. The "occluded" D3D you saw was most like me tinkering with things at one point with the log running and I unintentionally sent you a log with my messing around. Sorry about that. I always can use .88.8 if I want use 10 bit output with higher " presented frames in advance" settings in 10 bit DSD11 mode but of course I couldn't play with the added /changed features in .88.10. I do appreciate you taking extra time troubleshooting this issue with me even though I'm the only one to have reported it up to now. Here is the log for the full queues if you want to take a look. http://s000.tinyupload.com/?file_id=...78447616236926 Last edited by cyberscott; 3rd June 2015 at 01:47. Reason: added link |
3rd June 2015, 04:15 | #30690 | Link |
The newest MPC-HC official release for June 1st causes my render and present queues to bounce around zero despite having render times of around 28-30ms for 24p content. Dropped frame count is surprisingly fine, with only a couple frames per minute, but clearly something isn't working as it was before.
Anyone have a link to a copy of 1.7.6.156 I could revert to? That was the tweaked 64 bit build to support 64 bit madvr. The old one on dropbox from weeks/months back is dead. Hmm, with further testing to isolate the problem, it went away without me doing anything. Go figure. Last edited by har3inger; 3rd June 2015 at 04:25. |
3rd June 2015, 06:01 | #30691 | Link |
Soul Architect
Hey I have a very simple suggestion that would make the usage much simpler.
Why are downscaling algorithms like Catmul in the upscaling pages, and why are upscaling algorithms like Lanczos in the downscaling page? You could remove downscaling algorithms from the upscaling page and upscaling algorithms from the downscaling page. That would make the interface simpler and make it easier for new users. Also, someone mentioned that Scale in Linear Light shouldn't be used when downscaling except for Catmul when also using Anti-Ringing. If it's a bad choice for others, it could be removed for other algotirhts.
FrameRateConverter | AvisynthShader | AvsFilterNet | Natural Grounding Player with Yin Media Encoder, 432hz Player, Powerliminals Player and Audio Video Muxer Last edited by MysteryX; 24th June 2015 at 06:07. |
3rd June 2015, 07:21 | #30692 | Link | |
With regards to scaling in linear light it's a case of only enabling it if you you need it. Some options may move to advanced section but I suspect this rejigging if it occurs will happen closer to 1.0. |
3rd June 2015, 08:13 | #30693 | Link | |
http://madshi.net/madVR8810test6.rar This time it's a release mode build. So please double click "activate release mode.bat" first, then replace the madVR.ax file. Then please just double check if this test build still fills the queues with your current settings (4 frames pre-presented). If it does, as is well. If it doesn't, the VSync reset stuff is still a problem. I don't need a log this time. Just the information whether this build still fills the queues for you, or not. Thanks. |
3rd June 2015, 11:29 | #30694 | Link |
I try ... and it's don't help. Maybe something wrong with system ?? I do clean install latest Nvidia drivers. But - i create custom mode that work "true" 23.976 mode, maybe it's broken 24p mode ??
3rd June 2015, 11:34 | #30695 | Link |
How does your code look like? Should be something like this:
LONG res = ChangeDisplaySettingsExA(MonitorInfo->szDevice, &devMode, 0, CDS_UPDATEREGISTRY | CDS_NORESET, NULL); if (res == DISP_CHANGE_SUCCESSFUL) res = ChangeDisplaySettingsEx(NULL, NULL, 0, 0, NULL); |
3rd June 2015, 12:06 | #30696 | Link | |
ChangeDisplaySettingsEx(DisplayName1, &dmScreenSettings, NULL, CDS_UPDATEREGISTRY | CDS_NORESET, NULL); ChangeDisplaySettingsEx(NULL, NULL, NULL, 0, NULL);
3rd June 2015, 12:15 | #30697 | Link |
If you create a custom 23.976 mode on NVIDIA, it can break the 24.000 mode. Delete your custom mode, and both should work fine.
3rd June 2015, 12:19 | #30698 | Link |
But why does it work with madVR then? At least that's how I understood Aleksoid1978's original comment.
We're talking about windowed mode playback, not FSE mode, right? In FSE mode things can be more complicated because Direct3D itself can also try to change/set the display mode... |
3rd June 2015, 12:20 | #30699 | Link | |
Nvidia don't have a mode for 23.976 fps )) P.S. we are talking about FSE.
3rd June 2015, 12:25 | #30700 | Link |
How about windowed mode then? Does it work there?
And in FSE mode, are you changing the display mode after or before you enter FSE mode? If you change the display mode, after the switch to FSE has fully completed, your ChangeDisplaySettingsEx() call should overwrite whatever Direct3D has done before. If you change the display mode too early, Direct3D might switch it again during the windowed -> FSE mode transition. |
