Old 20th November 2016, 01:31   #25261  |  Link
Mark_Venture
What I don't get is how it would cause an error in CreateAVS()? All that does is create the AVS file... it doesn't attempt the conversion.
@Mark_Venture
What language to you have selected as the default for subtitles? Are you using the default of English. I'll see if I can pick up that movie and give it a test.
English is the default language, and sub titles.
The INI I shared in Post #25199 is what I'm using.
IF you don't already own this movie, don't buy it if its just me facing this issue!! I do have options to have a working back up. Since it ran with "Use SupTitle for Alternate Forced Subs" unchecked, I'm happy to just extract the subtitles using HdBrStreamExtractor and SubTitle Edit. Plus I have DVDFab Ripper which I've successfully used on this title. I mean I like BD Rebuilder better, and its the way I prefer to make my backups!! it gives me much better picture quality when I compare output of the same disc..
@jdobbs
I have that movie, so if you want me to run some tests let me know
If you have the ability to run, and see if you get the same error as I do, that would be appreciated.. I'd love to know if its something in my system (although since I get the same error on a fresh install of Win10 & BD Rebuilder, as well as the installs on my Win 7 partitions, I hope its not my system)..
Old 20th November 2016, 02:24   #25262  |  Link
I was in town today so I picked it up. I'll run it with your INI and see what happens. I hope I can repeat it, I want to see what could possibly cause it to crash win a Runtime Error 0.
Old 20th November 2016, 03:09   #25263  |  Link
@Mark_Venture
Just so you know, I ran the job using your INI and, sure enough, I got the same error. I've already identified what is happening, now I just have to put my finger on why. I also found out why it is incorrectly reporting the error as 0. I should have it fixed for the next release.
Good bug report. Thanks.
Old 20th November 2016, 04:01   #25264  |  Link
Originally Posted by ascottj View Post
I have made numerous encoding attempts on IP Man 3 Blu-ray, but the subtitles simply will not sync ... first time I have come across this issue. The subtitles are in sync when playing the AnyDVD HD rip. What elements should I address in BD-RD to attempt to correct the subtitle syncing?
I had this listed in my bug to-do list, and noticed something related in something I was working on today. Can you tell me more about this error.
1. What type of encode are you doing (ALTERNATE, MOVIE-ONLY, FULL)?
2. Is this a multipart source for which you are trying movie-only backup?
3. Were subtitles forced ON from within the streams list?
Old 20th November 2016, 05:03   #25265  |  Link
Originally Posted by HandiA View Post
Just wondering.
Any other thoughts on BD Rebuiler failure for this film?
Don't know if I responded to this back in October... but, I haven't forgotten it, and I've updated BD-RB so it will be more specific as to what kind of error you got in CreateAVS() -- I suggest you try that disc one more time when I release version 0.50.20. It may not fix the problem -- but it could at least help identify what is happening.
Also, can you tell me whether you had any subtitles forced ON in that source? That may be an indicator of a problem I found/fixed for the next release.
Old 21st November 2016, 21:11   #25266  |  Link
ggtop
I am looking forward solving the problem I had with e.g. Bridge of Spies and MP4 output
ggtop
Old 21st November 2016, 21:58   #25267  |  Link
ggtop
I'm pretty sure this latest fix will work for that one as well.
Old 22nd November 2016, 13:14   #25268  |  Link
Mark_Venture
@Mark_Venture
Thank you! Glad to know it wasn't just something on my end this time
Old 23rd November 2016, 05:49   #25269  |  Link
Lathe
Lathe's Avatar
If you have something on your end, you probably should get it looked at...
Old 23rd November 2016, 06:19   #25270  |  Link
Or wipe it off.
Old 23rd November 2016, 14:52   #25271  |  Link
Mark_Venture
wow.. um.. yeah, i guess that didn't come across right...
Old 23rd November 2016, 23:20   #25272  |  Link
gonca
Don't worry, doctors can do amazing things with needles now a days
Old 23rd November 2016, 23:34   #25273  |  Link
MrVideo
MrVideo's Avatar
It came across so that that you can be made the butt of their jokes.
Old 23rd November 2016, 23:37   #25274  |  Link
gonca
No pun intended?
Old 24th November 2016, 18:57   #25275  |  Link
MrVideo
MrVideo's Avatar
No pun intended?
Spelling is correct.
Old 24th November 2016, 19:00   #25276  |  Link
@gonca
Sorry about your image. I enabled it, but it was way too big so I removed it.
Old 24th November 2016, 22:56   #25277  |  Link
gonca
@gonca
Okay, I should have checked closer
Old 29th November 2016, 09:40   #25278  |  Link
Marban
[11.29.16] Checking System Settings
- BD-Rebuilder v0.50.19
- Windows Version: 6.2 [9200]
- Working Path Free Space: 47,76GB
- AVISYNTH Version: 2.6.0.6, Ok
- LAVFILTERS: Ok
- X264: Wrong version found
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
- FRIMEncode: Ok
bug? i downloaded the new Version from her.
Marban is offline   Reply With Quote
Old 29th November 2016, 15:47   #25279  |  Link
- LAVFILTERS: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
- FRIMEncode: Ok
See this post. My mistake.
Old 3rd December 2016, 20:34   #25280  |  Link
lauguru
hello @jdobbs
It would be possible to add these values, in ARCHIVE MODE
main 10
level 5.1
bt.2020
http://www.dvd-logic.com/kite/screenshots.html
lauguru is offline   Reply With Quote
