Old 1st December 2007, 09:40   #201  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
I'd load it into soundforge, or any NLE that's handly and shows audio graphically, but that doesn't help if you don't have one. Audacity might be able to help, though.
Old 28th December 2007, 16:54   #202  |  Link
Wilbert
@Myrsloik,
What happens if you open a file (which is DV with color format 4:1:1)?
http://forum.doom9.org/showthread.ph...32#post1080432
Is this a bug in ffmpegsource (for example it doesn't check the color format which is outputted by the decoder, or it doesn't request the appropriate color format from the decoder), or is ffmpeg not decoding it correctly?
Wilbert is offline   Reply With Quote
Old 28th December 2007, 17:02   #203  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Not much because I don't seem to have any DV files at all. Do I get a free sample?
Old 28th December 2007, 20:23   #204  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
http://www1.mplayerhq.hu/MPlayer/samples/DV-raw/ Here's one of the same format.
Old 28th December 2007, 22:36   #205  |  Link
Myrsloik
Myrsloik's Avatar
My results:
FFmpegSource: same odd stuff as in the screenshot
FFmpeg.exe: Unable to find a suitable output format for 'c:/FFmpegSource/voxnews.dv'
Mplayer: dies instantly unless two instances are launched at the same time and then one seems to work
I don't think it's my fault this time...
Old 29th December 2007, 04:59   #206  |  Link
themostestultimategenius
Kwon BoA
themostestultimategenius's Avatar
Try using QTSource?
Incase you don't have the plugin (Just too lazy to search for the thread with it =p)
http://www.mediafire.com/?ahw5eznzazp
Jeremy Clarkson - Getting fat is just evolution
themostestultimategenius is offline   Reply With Quote
Old 5th January 2008, 14:24   #207  |  Link
Myrsloik
Myrsloik's Avatar
Version 1.14 released. The main new thing is that it's statically linked (only one dll) and is linked with a much newer ffmpeg.
Old 5th January 2008, 14:49   #208  |  Link
buzzqw
HDConvertToX author
with 1.14 i got stuck with "LoadPlugin: unable to load c:\xx\ffmpegsource.dll"
even if i keep all other dlls ( like avcodec-51.dll, avformat-51.dll ... from previus package ) in windows\system32
BHH
HDConvertToX: your tool for BD backup
MultiX264: The quick gui for x264
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
buzzqw is offline   Reply With Quote
Old 5th January 2008, 16:14   #209  |  Link
Nikos
Ver. 1.13 works fine but 1.14 give me errors with or without the old dlls.
"Script open failed"
Greece PAL User...
Nikos is offline   Reply With Quote
Old 5th January 2008, 16:33   #210  |  Link
Myrsloik
Myrsloik's Avatar
The file is updated now. For some reason I can't understand the release compile didn't link properly.
Old 5th January 2008, 16:50   #211  |  Link
buzzqw
HDConvertToX author
yes! now working!!
BHH
Old 5th January 2008, 17:19   #212  |  Link
Nikos
Thanks, now working fine!!!
Greece PAL User...
Old 5th January 2008, 21:19   #213  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
Thanks for the new release. Did you have include some patches with it (E-AC3 decoder, TrueHD/MLP...) or not ?
Old 5th January 2008, 21:30   #214  |  Link
Myrsloik
Myrsloik's Avatar
No, it remains patchless. I'm too lazy to bother with adding those things as I don't need it myself and at least one day they'll hopefully be integrated. Feel free to make your own compiles of it..
Old 12th January 2008, 16:01   #215  |  Link
jmartinr
jmartinr's Avatar
DV (Pal) scrambled
Thanks for the good work.
But unfortunately DV stil gives a sort of scrambled outcome.
Screencapture is here: http://www.nkbv.nl/blobs/wedstrijden/test/palintlt.bmp
Script is here: http://www.nkbv.nl/blobs/wedstrijden/test/palintlt.avs
AVI (Pal DV) is here: http://www.nkbv.nl/blobs/wedstrijden/test/palintlt.avi
1.13 had the same error. Avi does play in ffplay SVN-r8891.
jmartinr is offline   Reply With Quote
Old 12th January 2008, 18:55   #216  |  Link
Myrsloik
Myrsloik's Avatar
The file decodes in a just as messed up way with a recent ffplay. Not my fault and I have no idea what causes it.
Old 12th January 2008, 23:18   #217  |  Link
jmartinr
jmartinr's Avatar
Could you tell me which version of ffplay that is? Rev11143 still works fine.
Old 12th January 2008, 23:35   #218  |  Link
Myrsloik
Myrsloik's Avatar
I think c/c++ compilers hate me in general. One recompile of ffmpeg+ffmpegsource and it works. Behold the newer version which will be known as 1.15.
Old 13th January 2008, 15:05   #219  |  Link
jmartinr
jmartinr's Avatar
Old 14th January 2008, 13:10   #220  |  Link
Klute
ive got a problem with an quicktime file, which has a res of 582x319.
when i try to transcode it using ffmpegsource, i get an "YV12 images for output must have a width divisible by 4 (use crop)!" error.
Klute is offline   Reply With Quote
