28th July 2011, 20:31 | #183 | Link |
VidCoder Author
Options are on the VidCoder main page: http://vidcoder.codeplex.com/
I tried getting VidCoder to load in libdvdcss.dll but it would always blow up with an inexplicable error. AnyDVD, Passkey for DVD, DVDFab DVD Copy and DVD Decrypter are some options for you. DVD43 if you're on an x86 OS. |
2nd August 2011, 22:22 | #184 | Link |
RE,
I have a working 0.9.2 Vidcoder x86 running on my x64 Win 7 video machine. I D/L'd the new 0.9.4 X64 version and installed. I ran it and the add to queue button would not become active so I could do a batch encode. I then downloaded the X86 version and installed that and it worked fine...any suggestions? |
8th August 2011, 18:03 | #186 | Link |
When using copy source audio and it's an DTS MA HD, then Vidcoder job gives an unsuccessful error, I clicked then on Log in the Menu then the app didn't respond anymore.
After viewing the Log manually it says: [11:52:10] * audio track 0 [11:52:10] + decoder: Deutsch (DTS-HD MA) (5.1 ch) (track 1, id 0x1) [11:52:10] + DTS-HD passthrough [11:52:10] * audio track 1 [11:52:10] + decoder: Chinese (DTS-HD MA) (5.1 ch) (track 1, id 0x2) [11:52:10] + DTS-HD passthrough ....... x264 [info]: profile High, level 5.0 ERROR: muxmkv: Unknown audio codec: c0040000 [11:52:37] work: average encoding speed for job is 0.000000 fps [11:52:37] sync: got 0 frames, 172920 expected [11:52:37] h264-decoder done: 7 frames, 0 decoder errors, 0 drops [11:52:37] reader: done. 1 scr changes [11:52:37] render: lost time: 0 (0 frames) [11:52:37] render: gained time: 0 (0 frames) (0 not accounted for) [11:52:37] dca-decoder done: 0 frames, 0 decoder errors, 0 drops [11:52:37] dca-decoder done: 0 frames, 0 decoder errors, 0 drops [11:52:37] mux: track 0, 0 frames, 0 bytes, 0.00 kbps, fifo 8 [11:52:37] mux: track 1, 0 frames, 0 bytes, 0.00 kbps, fifo 8 [11:52:37] mux: track 2, 0 frames, 0 bytes, 0.00 kbps, fifo 8 [11:52:37] mux: track 3, 0 frames, 0 bytes, 0.00 kbps, fifo 8 [11:52:37] decomb: deinterlaced 0 | blended 0 | unfiltered 0 | total 0 [11:52:37] libhb: work result = 0 # Encode failed. Error(s) were reported during the encode. Also I noticed this warning: x264 [warning]: --psnr used with psy on: results will be invalid! x264 [warning]: --tune psnr should be used if attempting to benchmark psnr! What does it mean? best regards, and thanks for the program... |
8th August 2011, 22:40 | #187 | Link |
It means HB_ACODEC_FF_I_FLAG was somehow propagated from the input audio codec value to the output audio codec value. This flag should only be present on input codec values. Also, this flag completely goes away in HB svn 4141.
8th August 2011, 22:47 | #188 | Link |
HandBrake enables psnr statistics logging in x264. Many people doing comparisons of encoders try to use these statistics improperly. So the x264 developers added this warning to try to get these people to do proper comparisons. The numbers are still somewhat meaningful without --tune psnr, just not suitable for comparing encoders.
9th August 2011, 12:01 | #190 | Link |
Thanks from me too for explaining, hope to see a fixed version soon, because your program rocks.
* MAy I suggest one thing for future releases: I noticed that there is no way to change the temporary directory which is used during conversion. Because my C:\ Drive is an SSD and therefore not so big, I would really love to see an option to change the temp Folder from the currently used Windows Standard Temp Folder too a custom one... |
9th August 2011, 16:40 | #191 | Link | |
11th August 2011, 20:55 | #192 | Link |
VidCoder Author
Ahh I see. I had applied the HB_ACODEC_PASS_MASK to see if the codec was valid to pass through, but I neglected to apply to to the final output codec (which would have cleared out that flag). That problem will be fixed in the next version.
12th August 2011, 04:14 | #193 | Link |
VidCoder Author
Released VidCoder 1.0.0:
* Added splash screen * Updated to HandBrake svn 4167: This adds AAC and MP3 passthrough as well as DTS and DTS-HD passthrough for MP4. * Fixed that reported encode failure with the incorrectly masked output codec. So it's out of beta! Nothing really special about it, just thought it has gone through enough use and stabilization to get to 1.0. Didn't want to hang out in 0.9.X with HandBrake too long. |
12th August 2011, 04:24 | #194 | Link |
I really like this encoder, very simple, easy to use. For now I have one problem, the high CPU usage (100%)
I have Core 2 quad, 8 GB of ram, Win 7 64-bit Here's the settings I use Code:
<?xml version="1.0" encoding="utf-8"?> <UserPreset Version="3"> <Preset xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"> <Name>Frozen</Name> <IsBuiltIn>false</IsBuiltIn> <IsModified>false</IsModified> <EncodingProfile> <OutputFormat>Mkv</OutputFormat> <PreferredExtension>Mp4</PreferredExtension> <IncludeChapterMarkers>false</IncludeChapterMarkers> <LargeFile>false</LargeFile> <Optimize>false</Optimize> <IPod5GSupport>false</IPod5GSupport> <Width>0</Width> <Height>0</Height> <MaxWidth>0</MaxWidth> <MaxHeight>0</MaxHeight> <CustomCropping>false</CustomCropping> <Cropping> <Top>0</Top> <Bottom>0</Bottom> <Left>0</Left> <Right>0</Right> </Cropping> <Anamorphic>Loose</Anamorphic> <UseDisplayWidth>false</UseDisplayWidth> <DisplayWidth>0</DisplayWidth> <KeepDisplayAspect>true</KeepDisplayAspect> <PixelAspectX>0</PixelAspectX> <PixelAspectY>0</PixelAspectY> <Modulus>16</Modulus> <Deinterlace>Slow</Deinterlace> <Decomb>Off</Decomb> <Detelecine>Default</Detelecine> <Denoise>Medium</Denoise> <Deblock>0</Deblock> <Grayscale>false</Grayscale> <VideoEncoder>X264</VideoEncoder> <X264Options>rc-lookahead=50:b-adapt=2</X264Options> <VideoEncodeRateType>TargetSize</VideoEncodeRateType> <Quality>15</Quality> <TargetSize>350</TargetSize> <VideoBitrate>900</VideoBitrate> <TwoPass>false</TwoPass> <TurboFirstPass>false</TurboFirstPass> <Framerate>0</Framerate> <PeakFramerate>false</PeakFramerate> <AudioEncodings> <AudioEncoding> <InputNumber>1</InputNumber> <Encoder>Faac</Encoder> <Bitrate>160</Bitrate> <Mixdown>DolbyProLogicII</Mixdown> <SampleRateRaw>0</SampleRateRaw> <Gain>0</Gain> <Drc>0</Drc> </AudioEncoding> <AudioEncoding> <InputNumber>2</InputNumber> <Encoder>Faac</Encoder> <Bitrate>160</Bitrate> <Mixdown>DolbyProLogicII</Mixdown> <SampleRateRaw>0</SampleRateRaw> <Gain>0</Gain> <Drc>0</Drc> </AudioEncoding> </AudioEncodings> </EncodingProfile> </Preset> </UserPreset> |
12th August 2011, 08:41 | #196 | Link | |
16th August 2011, 02:20 | #199 | Link |
Brazilian Anime Ripper
I have problems with subtitles here.
Two computer, first with Windows Vista Ultimate 32 bits. All movies i did with this computer are ok, including subtitles in .srt format. Second computer with Windows 7 64 bits. The subtitles here have a black background and the position is not correct (align on right). I am using the same profile in both computers. I already tried x64 and x86 versions and the result is the same. Anybody knows a workaround?
Capture cards: Compro VideoMate Gold+ (Philips SAA7134 based) (not active) Hauppauge PVR 150MCE (not active) ATI TV Wonder Elite (active) |
16th August 2011, 20:32 | #200 | Link |
Hi. Can anyone tell me where VidCoder stores the user presets file?
I've looked in Program Files>VidCoder = I can see the BuiltInPresets .xml file. All Users>Application Data = found nothing. MIKE>Application Data>VidCoder = Found nothing. MIKE>Local Settings>Application Data>VidCoder = found user.config file - looking at it using notepad, there were none of my numerous presets. I thought there would be another .xml file with my user presets stored somewhere. I feel I'm looking in the wrong locations (I have 22 presets and know they can be exported individually. But 22 are loaded when the program starts - chosen via the drop down menu - so they must all be stored somewhere). Last edited by mike20021969; 17th August 2011 at 15:52. |
