17th May 2018, 02:23 | #5342 | Link |
Latest SVN version always here - https://yadi.sk/d/hlf1lfC8mKU58/!_last
17th May 2018, 04:10 | #5343 | Link |
Wrong. The last beta release was released on February 28 this year.
We do not release on timeout. We make a release when we do it.
MPC-BE 1.7.0 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource Last edited by v0lt; 17th May 2018 at 04:14. |
17th May 2018, 05:45 | #5345 | Link |
We don't have "manager" who will be released project
17th May 2018, 08:09 | #5346 | Link |
I agree with the devs, they can release hotfixes if it's necessary any time, but a release should be time independent but feature dependent.
18th May 2018, 15:25 | #5348 | Link |
Well, clearly they 'developed' something. The bug doesn't seem to be present in the latest SVN build. I've conducted a short test with several different files and didn't managed to get it hung once.
Time for another stable, I think |
18th May 2018, 15:41 | #5349 | Link |
I'm a bit surprised and happy that MPC-BE's DXVA2 Native works on a HEVC 10-bit sample on my AMD's APU but not with LAVFilters.
Anyway why don't put crossfeed feature on sound processing? Looking for stable release as well here |
18th May 2018, 19:57 | #5350 | Link |
18th May 2018, 21:06 | #5351 | Link |
19th May 2018, 18:42 | #5353 | Link |
Can perhaps the Subtitle menus be combined?
You have right click > Subtitles (to access subtitle options and to enable) And right click > Navigate > Subtitle Language (to change the subtitle; you can also enable here too, which overlaps in functionality) Doesn't make sense that these are separate. Why do I need to access a different subtitle menu to change the language? Last edited by JarrettH; 19th May 2018 at 18:44. |
19th May 2018, 23:45 | #5354 | Link |
For subtitles use SUB button on toolbar, left/right mouse button.
20th May 2018, 12:04 | #5355 | Link |
Bug: wrong black levels with MPC-BE's EVR-CP with some files. Sample
MPC-BE's internal video decoder outputs correct black levels with all EVR, EVR-CP and madVR LAVVideo decoder outputs wrong black levels with EVR-CP, but correct black levels with EVR & madVR LAVFilters-0.71.0-35 MPC-BE 1.5.2.3648 Windows 7 x64
Intel UHD Graphics 750; Win 10 22H2 |
20th May 2018, 13:44 | #5356 | Link | |
20th May 2018, 16:21 | #5358 | Link |
@Mercury_22
The driver settings may be affected. The "Output range" option may be affected. In any case, LAV Video Decoder does not report the nominal range.
20th May 2018, 17:48 | #5359 | Link |
If the file does not expose a range, then none is reported. Limited Range should always be assumed to be the default by the renderer in such a case.
20th May 2018, 18:27 | #5360 | Link |
@nevcairiel
Yes, but we got a more correct result if the decoder reports the nominal range. I do not remember the exact reason why we did this (maybe it was the effect of the settings of the video driver, it sometimes does not work as expected by the user). I will not deny that the EVR-CP in this case may not work correctly. But the solution to this problem is not obvious, and other negative effects may appear.
