Old 18th March 2009, 17:35   #61  |  Link
buzzqw
HDConvertToX author
BTW, why is x264's priority at normal when it is supposed to be at low?
not already implemented the thread priority
EDIT: I found the problem. For some reason it doesn't like b-adapt 2. b-adapt 0 or 1 works, but not 2
even with less bframes b-adapt 2 don't work ?
BHH
HDConvertToX: your tool for BD backup
MultiX264: The quick gui for x264
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
buzzqw is offline   Reply With Quote
Old 18th March 2009, 17:40   #62  |  Link
Chengbin
You're right, if I lower the number of bframes it works. But why?
EDIT: With further testing it showed that the max bframe is 10. For some reason 11 doesn't make x264 quit, but it make it stop encoding. 12-16 makes x264 to quit.
Chengbin is offline   Reply With Quote
Old 18th March 2009, 19:33   #63  |  Link
buzzqw
HDConvertToX author
i suggest you to signal problem to x264 dev team
priority is fixed in next build (at least not using queue)
BHH
Old 18th March 2009, 22:56   #64  |  Link
Chengbin
That's not a problem, because I can use the same settings with 16 bframes in AutoMKV without problems.
Old 18th March 2009, 23:26   #65  |  Link
Dal
Hello again.
I've been a long time user of your AutoMKV, and I have to say this program looks way better. Especially converting my .ts recordings from DVBViewer, INCLUDING DVB Subtitles, is a feature I have never encountered before, but looked long and hard for. OK, for now the program gives me an error when trying to analyse the .ts files, but I'm not sure if it's my PC or the program. (My PC has been acting strange lately)
A few questions:
You mentioned earlier that this program is meant to replace AutoMKV, does that mean you will add support for ripping TV series DVDs, and the possibility to queue all episodes. The feature is in AutoMKV, but the queue hasn't worked in ages.
And can you please add support for the MEGui x264 profiles, as you did in AutoX264? I'm especially interested in the DXVA profiles.
Thank you, and keep up the good work!
Dal is offline   Reply With Quote
Old 19th March 2009, 00:05   #66  |  Link
Crono141
Can I get an ETA on Full DVD/IFO support?
Also, can I request support for large fonts? I use large fonts on my PC, and since the window is non-resizable, I don't see all the options. AutoMKV had this problem too.
Crono141 is offline   Reply With Quote
Old 19th March 2009, 08:23   #67  |  Link
buzzqw
HDConvertToX author
@Dal
could you please upload a sample (30/50mb) ? i want test it too
remove all codec pack, and install ONLY
the required software linked in first post of this thread
No, not actually.
The profile editing is very very easy (a lot more is compared with MeGui or AutoMKV). You must simply open the profile.txt and change the command line.
NMT check is also DVXA compliant! (i will add a tip , thanks for suggesting)
@Chrono141 AND DAL
i am working on it. i cannot give eta, sorry
BHH
Old 19th March 2009, 15:10   #68  |  Link
Dal
Originally Posted by buzzqw View Post
@Dal
No problem, where do you want me to put it?
Old 19th March 2009, 16:01   #69  |  Link
buzzqw
HDConvertToX author
mediafire or rapidshare... where you want
BHH
Old 19th March 2009, 22:39   #70  |  Link
Dal
mediafire or rapidshare... where you want BHH
Ok, here it is: http://www.gaasdal.net/DiscoveryHD.ts
Old 20th March 2009, 17:18   #71  |  Link
buzzqw
HDConvertToX author
For the Brave and the Bold
here the latest BETA with IFO/PGC support . DVD must be already ripped
Instruction: just select the ifo
http://www.64k.it/andres/data/hdconv...TOXviD-ifo.rar
any test is more then appreciated. BUT please give all info when reporting problem
BHH
Old 21st March 2009, 09:28   #72  |  Link
buzzqw
HDConvertToX author
@Dal
seems that eac3to is unable to extract your subs.. i will check further
@Crono141
http://www.64k.it/andres/data/hdconv...TOXviD-ifo.rar has fixed fonts.. so should "scale" with your dpi
BHH
the
Old 21st March 2009, 17:47   #73  |  Link
Crono141
The fonts are fixed now thanks, but the program hangs when the "select PGC" screen pops up, after hitting analyze. Its just an empty window with the windows "thinking" cursor when you hover over the window.
Running Windows 7, but didn't have any trouble with AutoMKV.
Old 21st March 2009, 17:55   #74  |  Link
buzzqw
HDConvertToX author
@Crono141
please check if in hdconverttox there is a "dvdinfo.txt" file
BHH
Old 21st March 2009, 18:04   #75  |  Link
Crono141
Yes, it is there.
Old 21st March 2009, 18:26   #76  |  Link
buzzqw
HDConvertToX author
so, you see the pgc list
you select the pgc
and when analyze starts it goes wrong ?
please post the analyze.avs!
thansk
BHH
Old 21st March 2009, 18:43   #77  |  Link
Crono141
Weird. I've done this twice now, and the third time it worked no problem. It hung on me twice.
One more request; Can we get a lossless mode option on X264?
Also when choosing Coding Tech AAC (with number of channels set to "original), the audio encoder assumes 6 channels, even if source is only 2 channel.
Is there a MOD16 option yet?
Old 21st March 2009, 20:44   #78  |  Link
buzzqw
HDConvertToX author
just select 1 pass Quality and set CRF to 0
i'll check it
yes.. (read the manual!)
just create a file named "mod16.txt" in hdconverttox folder
BHH
Old 23rd March 2009, 03:37   #79  |  Link
BigKing
is there any posibility to change the settings of the divx codec?
I have a problem with the avimux. It doesn't works and crashs. I use Windows Vista.
BigKing is offline   Reply With Quote
Old 23rd March 2009, 08:38   #80  |  Link
buzzqw
HDConvertToX author
just open the profile.txt and check it (make a copy of file before editing...)
BHH
bluray, hdc, hdconverttox, m2ts, network media tank, playstation, x264 gui
