Old 20th March 2020, 16:05   #7261  |  Link
tormento
Acid fr0g
tormento's Avatar
Originally Posted by v0lt View Post
No. It only works with UnRAR.dll and UnRAR64.dll.
Would you consider to add support to a free archive format such as 7z?
@turment on Telegram
Old 20th March 2020, 19:22   #7262  |  Link
v0lt
Not planned.
1. I did not see subtitles in the ".idx/.7z" format. I do not know where there is such support.
2. The CVobSubFile::ReadRar function has a size of 84 lines (including empty lines). I did not find a simple example of working with .7z archives using 7zxa.dll.
But if someone makes a patch, then I'll see it.
Old 20th March 2020, 20:07   #7263  |  Link
Zulithe
Hi V0lt. Just wanted to drop a mention that the main file store for nightlies is not getting new builds. Other mirrors are fine. Cheers!
Zulithe is offline   Reply With Quote
Old 25th March 2020, 21:27   #7264  |  Link
mithra66
Hello,
OSD doesn"t display Title or Volume anymore for me but System Time instead. I installed many versions: From 1.5.4.4969 to 1.5.5.5149, all faulties.
Back to 1.5.4.4491, it works fine again.
BTW thanks for your great work)
mithra66 is offline   Reply With Quote
Old 26th March 2020, 06:12   #7265  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Originally Posted by mithra66 View Post
Hello,
Check options.
Old 26th March 2020, 20:51   #7266  |  Link
mithra66
My bad. Somehow I must have pressed key 'I' which displays system time in OSD. Funny thing it did nothing in older versions. So I pressed 'I' to rollback to normal. Txs for your help,
Old 28th March 2020, 04:20   #7267  |  Link
Anima123
There's like nearest neighbor been applied as scaler when playing back a h.265 file with P010 format and auto 8/10bit integer as output format.
Please check here.
I have to set the output format to 8bit integer to avoid the bad scaler. Any improvement in the future?
Anima123 is offline   Reply With Quote
Old 28th March 2020, 04:55   #7268  |  Link
Aleksoid1978
Please check here.
Comfirm.
Old 28th March 2020, 05:15   #7269  |  Link
v0lt
Anima123
Try using MPC VR v0.4.2.1196.
Old 28th March 2020, 05:21   #7270  |  Link
Anima123
Anima123
I was using 1197.
Edit: Just checked with 1196, the issue gone.
Old 28th March 2020, 06:52   #7271  |  Link
s0meone_new
If everything works fine now, a new stable version?
s0meone_new is offline   Reply With Quote
Old 30th March 2020, 11:27   #7272  |  Link
v0lt
@Anima123
I suggest trying MPCVideoRenderer-v0.4.2.1214_git2020.03.30-800fd4c.
If there are no serious problems compared to v0.4.1.1130, then we plan to release a release soon.
Old 30th March 2020, 19:52   #7273  |  Link
LouieChuckyMerry
LouieChuckyMerry's Avatar
Hello, and thanks for MPC-BE; I've been using it for some years to watch movies on my laptop and I love it . I recently scored a used HD TV that I connect to my laptop with an HDMI cable and, although the video is much improved over the laptop screen, I'm having trouble with the audio: If the volume is loud enough to hear conversations, then it's much too loud when there's any kind of action or soundtrack background music. I'm wondering if there's any way to "normalize" the audio so the soft parts are louder but the loud parts are softer? Currently in "Options/Audio" it's set to "1. DirectSound: System Default" and in "Options/Audio/Sound processing" it's set to "Default". I've checked the TV and the audio settings are as neutral as possible, no added effects or equalizer settings. Any suggestions for tweaking the audio settings in MPC-BE would be much appreciated.
LouieChuckyMerry is offline   Reply With Quote
Old 30th March 2020, 23:59   #7274  |  Link
Aleksoid1978
Options -> Audio -> Sound processing -> Auto volume control. Also can change Center/Surround level.
Old 31st March 2020, 19:30   #7275  |  Link
LouieChuckyMerry
Thanks for your reply, Aleksoid1978, ticking "Auto volume control" definitely helped and I'll play with the "Center" and "Surround" levels. What's the "Release time" slider do?
Old 1st April 2020, 06:23   #7276  |  Link
v0lt
MPC Video Renderer v0.4.3.1215.
Description.
Changes:
Fixed frame brightness for 10 bit video after D3D11 video processor.
Added dithering. It is used for final reduction of bit depth from 10/16 bits to 8 bits.
Fixed statistics when playing some devices.
Fixed frame skipping in some rare cases.
Improved display of subtitles.
Improved compatibility with some players.
Added the ability to get the displayed image.
Added the ability to switch the "Swap effect" setting during playback.
Fixed problems with rotation and zoom in some situations.
Added support for IVideoWindow:ut_MessageDrain and IVideoWindow::get_MessageDrain calls.
Recommended version of MPC-BE v1.5.5.5125 or later.
Old 1st April 2020, 07:33   #7277  |  Link
Anima123
Thanks for the nice new version. There's no regression spotted so far.
Old 1st April 2020, 11:56   #7278  |  Link
cmhrky
Latest Turkish translation based on r5154.
cmhrky is offline   Reply With Quote
Old 2nd April 2020, 06:22   #7279  |  Link
v0lt
@cmhrky
Thanks. Updated in r5155.
Please correct the translations after r5158.
"Remember last playlist" -> "Remember main playlist".
Old 2nd April 2020, 10:15   #7280  |  Link
s0meone_new
Hungarian translation updated (5158):
https://www115.zippyshare.com/v/npIfi1d3/file.html
