Old 17th October 2017, 14:21   #26561  |  Link
BD Rebuilder v0.50.25
I have updated the first post of this thread with a link to the most recent version (v0.50.25) of BD Rebuilder. Changes for this release:
- Fixed an issue that could cause CRF value
  prediction to jump dramatically on the
  final value when using One-Pass CRF.
- Added a fix that prevents encoding from
  failing when attempting to encode multipart
  sources to ALTERNATE HEVC that have the
  ATCDelta flag asserted.
- Modified the file import mechanism so it
  fixes MKV inconsistencies caused by oddball
  muxing engines.  It "prepares" (remuxes)
  MKV files before attemping import. This
  fixes occasional sync issues with audio
  during imports of MKV. This can be disabled
  via the "Import/Quick-Play Settings" dialog
  from the SETTINGS menu (to save time).
- Added a new IMPORT_CONVERT_FORCE hidden
  setting.  Forces imports to be reencoded
  (to AVC) during import (even when it isn't
  required).
- Added IMPORT_VFR_DISABLE as a hidden option
  When set to "1", BD-RB ignores indicators
  to the contrary, and assumes constant frame
  rate.
- Corrected a rare issue that could occur
  when performing file imports that require
  conversion to AVC or VFR reencoding.
- Fixed an error in which ALTERNATE resizing
  may not occur as specified on certain files
  that have been imported into a pseudo-BD
  structure.
- Updated the included version of X264.EXE to
  the latest release (r2851).
- Updated the included version of X264-64.EXE
  to  the latest release (r2851).
Old 17th October 2017, 15:00   #26562  |  Link
Originally Posted by zorro101 View Post
i have try tsmuxer with input .m2ts uhd (from bd uhd) and:
dont create Blu-ray folder
can create .m2ts
I also noticed that a start code of x000001E0 is used in TSMUXER HEVC M2TS streams I've tested... while it appears UHD M2TS files use x000001E1 (at least on the one disc I have for testing). That means the entire output M2TS would likely have to be scanned and start codes rewritten. It's easy enough to do -- but certainly time consuming. It might be possible to patch TSMUXER, but I'm not sure if that's even allowable under its freeware license agreement.
If you use a 2160p source to mux, TSMUXER will accept it and write a BD structure, but flags it as 1080p in the MPLS and CLPI files. The headers on the the files (MPLS, CLPI, etc) would all have to be updated to version 3 as well.
Old 17th October 2017, 15:37   #26563  |  Link
Mark_Venture
That's just one application. How about that family video you created with your UHD camera? Even the iPhone records UHD now.
Ahh yeah... I never thought about using BD Rebuilder for my phone videos...
Old 17th October 2017, 16:42   #26564  |  Link
Ch3vr0n
@jdobbs: can't download latest version. Asking for dl credentials
Old 17th October 2017, 17:04   #26565  |  Link
kufo
kufo's Avatar
Canīt download file too. Page wants a special login, also im still logged in
authentication required ?
There ist still 0.50.24 on the fist page, but download link is correct.
kufo is offline   Reply With Quote
Old 17th October 2017, 17:15   #26566  |  Link
DrinkLyeAndDie
DrinkLyeAndDie's Avatar
Likewise.
DrinkLyeAndDie is offline   Reply With Quote
Old 17th October 2017, 18:49   #26567  |  Link
MrVideo
MrVideo's Avatar
  rate.
Old 17th October 2017, 20:34   #26568  |  Link
Lathe
Lathe's Avatar
Old 17th October 2017, 20:37   #26569  |  Link
Lathe
Lathe's Avatar
And, a big, sincere 'THANK YOU' for the new version JD!
And, when I'm done with my current avid hobby of being POOR, I will send you something. Of course, I could EASILY afford a monthly subscription of $5.99!
Old 17th October 2017, 22:32   #26570  |  Link
Originally Posted by DrinkLyeAndDie View Post
Likewise.
Argghhh... Sorry about that. Fixing it now -- it was a rights issue. Should be available in a few minutes.
Old 18th October 2017, 00:07   #26571  |  Link
Lathe
Lathe's Avatar
Old 18th October 2017, 03:31   #26572  |  Link
soneca
Thanks for the new version!
Old 18th October 2017, 04:38   #26573  |  Link
kufo
kufo's Avatar
Tahanks jdobbs for the new version and fixing the download bug.
Old 18th October 2017, 07:29   #26574  |  Link
zorro101
I don't know, but it would be nice!!
on my experiment with tsmuxer with 2160p hevc it was impossible produce Blu-ray (error: unsupported or similar)
only .m2ts output it works
this night i retry
zorro101 is offline   Reply With Quote
Old 18th October 2017, 08:39   #26575  |  Link
Sharc
I have updated the first post of this thread with a link to the most recent version (v0.50.25) of BD Rebuilder. Changes for this release: ........
Thank you for the new version.
The --sar bug reported here seems to have happily survived in 0.50.25, right?
Old 18th October 2017, 09:00   #26576  |  Link
varekai
And, when I'm done with my current avid hobby of being POOR...
Old 18th October 2017, 13:19   #26577  |  Link
MrVideo
MrVideo's Avatar
Of course it was impossible to produce a Blu-ray structured ISO file, or BD layout. HEVC is not supported on Blu-ray. No player would play it.
It would have to be recoded to H.264 and tsmuxer doesn't do encoding.
You can retry until you are blue-in-the-face. It ain't gonna happen.
Old 18th October 2017, 13:26   #26578  |  Link
Well... not with the old Blu-Ray standards. But with the new standard that supports UHD playback, HEVC is supported.
Old 18th October 2017, 17:14   #26579  |  Link
DrinkLyeAndDie
It would be nice to see BD Rebuilder add support for UHD be it size reduction, UHD to BD, UHD to DVD, or UHD to alternate movie-only output. Obviously, this requires work. It would be wonderful if a "Pro" version weren't necessary but there are obvious reasons why it would have to be. Count me as one of those interested.
Regardless of whether or not this path is gone down your hard work is always appreciated, jdobbs.
Old 18th October 2017, 17:38   #26580  |  Link
MrVideo
MrVideo's Avatar
Right, only if you purchased a new UHD/4K player. I knew I should have stipulated 1080p H.264 (best video ) Blu-ray players. The Blu-ray term is very confusing, since both players use Blu-ray media, but even the 4K BD media is a little different. Just that they both use the Blu-ray laser.
