8th February 2020, 01:14 | #7121 | Link | |
https://yadi.sk/d/YEYTL-UjXed24g
8th February 2020, 06:54 | #7122 | Link |
@huhn
I added more debugging information to MPCVideoRenderer v0.4.0.1129. PS: You can use https://pastebin.com/ for large logs.
8th February 2020, 08:14 | #7124 | Link |
If you use a DXVA2 decoder and D3D11 mode, then MPC VR will give a high load. If you do not like it, then use the D3D9 mode.
8th February 2020, 10:01 | #7125 | Link |
here you go:
https://pastebin.com/Dupfh0ih |
8th February 2020, 10:22 | #7126 | Link | |
Maybe devs might look on it? |
8th February 2020, 12:09 | #7128 | Link |
that's why it doesn't work in windows media player but in this "video app" thingy.
so this is clearly not a bug just a feature here is a proof look at it still properly encoding a VP9 video for playback: https://abload.de/img/amdefknb.png i'm calling them again monday and tell them this if i didn't loose my mind before... it's so sad. edit: well i guess i just lay back for while instead. Last edited by huhn; 8th February 2020 at 12:13. |
8th February 2020, 15:15 | #7130 | Link | |
8th February 2020, 20:08 | #7133 | Link |
I will try to explain what the D3D9 and D3D11 modes mean in MPC-VR.
Direct3D 9 mode All stages of image processing using only D3D9. DXVA VideoDecoder, DXVA VideoProcesso and shader processing also use D3D9. Direct3D 11 mode Most stages of image processing using D3D11. DXVA VideoProcessor is completely replaced with D3D11 VideoProcessor. Shader processing now uses D3D11. But... 1. DXVA VideoDecoder can be replaced with D3D11 VideoDecoder (LAV). But we had to leave support for DXVA decoders. To do this, we have to copy from the D3D9 video surface to the D3D11 texture, which loads the memory bus (system memory is used). 2. We also have to use the shared D3D9-D3D11 texture so that we can draw subtitles and OSD on it. It turned out a little suboptimal. If anyone can implement the analogs of ISubRenderCallback and CDX9SubPic, then subtitles and OSD can be output as quickly as in D3D9 mode. In the current state, the effect of the dependencies on D3D9 on the D3D11 mode is as minimal as possible (as far as we succeeded).
9th February 2020, 04:38 | #7134 | Link |
Show screenshot from DXVAChecker to check support or not standart "VP9 Profile 0" mode. Check playback "VP9 Profile 0" in MPC-BE using internal filters/decoders with EVR-CP - show screenshot with Statistics(Ctrl+J). About crash using LAV Video + MPC VR - it's can try to understand this only locally using the debugger. If you can provide remote access to your computer, I can try to do it. If so - write in PM.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 Last edited by Aleksoid1978; 9th February 2020 at 04:55. |
9th February 2020, 11:05 | #7135 | Link |
DXVA: https://abload.de/img/dxvacheckere7ja4.png
MPC-BE working hardware decoding: https://abload.de/img/mpc-be4sjys.png BTW. EVR CP triggers freesync and that in a very inconsistent way. it is really worth the time to look deeper into it? |
9th February 2020, 11:46 | #7136 | Link | |
9th February 2020, 21:35 | #7138 | Link |
The DXVA documentation says that the flag should be 1 on decoders which accept a raw bitstream. If the AMD driver doesn't set it, its just broken. Not that this is a big surprise about AMD.
Technically there is no other mode for VP9, so I suppose I could add a special exemption to allow it anyway, but regardless their shit is broke. I can very specifically quote the DXVA VP9 specification which states that "ConfigBitstreamRaw" should always be 1 for VP8/9, AMD violates that apparently.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 10th February 2020 at 00:36. |
10th February 2020, 07:41 | #7139 | Link |
First release MPC Image Source Filter v0.1.0.29.
Description. Added: The filter allows you to open graphics image files using the Windows Imaging Component (WIC). The level of support depends on the version of Windows and installed updates. By default, the filter will open PNG, JPEG, BMP, TIFF, HD Photo (JPEG XR) and, if you have fresh Windows10, then also WebP, HEIF. By default, ImageSourceFilter will not be able to open JPEG and BMP formats in older versions of MPC-BE and MPC-HC. This is because the system "Generate Still Video" filter will receive a higher priority. This issue has been fixed in MPC-BE 1.5.5.5064. To open any formats supported by WIC, you need to add ImageSourceFilter to external filters and set the priority to "Prefer". Last edited by v0lt; 10th February 2020 at 09:10. |
10th February 2020, 07:45 | #7140 | Link |
MPC Video Renderer v0.4.1.1130.
Description. Changes: Fixed freezing during frequent timeline navigation. Added support for "post scale" shaders. Some changes in statistics. Fixed some memory leaks. Added support for D3D11 mode for Windows 7 SP1. Added support for the ARGB64 format (BRA[64]). Fixed playback of Y8 and Y800 formats with an odd width. Recommended version of MPC-BE v1.5.5.5044 or later. |
