Old 4th July 2020, 19:28   #14981  |  Link
kdantas
Hi, is there any way (chenge dll, edit registry, etc) to correct the version information of Haali Matrosk Muxer? I already installed the latest version found on the site... MatroskaSplitter23062013, as well as, I installed the latest version of the K-Lite Mega Codec Pack ... v15.5.7. I know it's just a date error, but I would like to see the correct information. Thanks.
Haali Matroska Muxer (2013-04-14) is installed
There's a new version (2013-06-23) available
http://haali.net/mkv
kdantas is offline   Reply With Quote
Old 5th July 2020, 05:03   #14982  |  Link
kdantas
Hi, is there any way to get a progress bar for eac3to running on the Windows command line, like this one below?
Old 6th July 2020, 07:12   #14983  |  Link
Only if madshi would code that. And the console output of eac3to is already a little weird (if you redirect the help output into a text file, its formatting is most peculiar). In case of output redirection, one may not wish the output to contain a frequently updated progress message.
Old 8th July 2020, 08:53   #14984  |  Link
tormento
Acid fr0g
tormento's Avatar
Error while extracting EAC3
Trying to extract eac3 track from Solo A Star Wars story. The mpls combines different m2ts as there are 3 different language scrolling screen at the beginning.
eac3to v3.34
command line: "D:\Eseguibili_x86\Media\eac3to\eac3to.exe" "F:\Raw\Solo A Star wars story" 2) 4:"E:\in\2_14 Solo A Star wars story\2_4_audio.flac" -progressnumbers
M2TS, 1 video track, 3 audio tracks, 8 subtitle tracks, 2:14:47, 24p /1.001
1: Chapters, 50 chapters
2: h264/AVC, 1080p24 /1.001 (16:9)
3: DTS Master Audio, English, 7.1 channels, 24 bits, 48kHz
(core: DTS, 5.1 channels, 1509kbps, 48kHz)
4: E-AC3, Italian, 7.1 channels, 896kbps, 48kHz, dialnorm: -27dB
(core: AC3, 5.1 channels, 512kbps, 48kHz, dialnorm: -27dB)
5: DTS, Spanish, 5.1 channels, 1509kbps, 48kHz
6: Subtitle (PGS), English
7: Subtitle (PGS), Italian
8: Subtitle (PGS), Spanish
9: Subtitle (PGS), Portuguese
10: Subtitle (PGS), Modern Greek
11: Subtitle (PGS), English
12: Subtitle (PGS), Italian
13: Subtitle (PGS), Spanish
[a04] Extracting audio track number 4...
[a04] Removing AC3 dialog normalization...
[a04] Extracting E-AC3 core...
[a04] Decoding with libav/ffmpeg...
[a04] The libav decoder reported error -22 while decoding. <ERROR>
Aborted at file position 1048576. <ERROR>
Never tried to extract tracks from mpls with ffmpeg. Need some help about command line.
@turment on Telegram
Old 8th July 2020, 10:29   #14985  |  Link
Boulder
Pig on the wing
Boulder's Avatar
You are not demuxing but decoding and encoding. To get around the issue, you could try demuxing first to ac3 and then transcode that to FLAC with a recent ffmpeg build.
Old 8th July 2020, 11:34   #14986  |  Link
tebasuna51
tebasuna51's Avatar
Is know than eac3to can't decode eac3 tracks like this.
You can extract it with:
eac3to "D:\Eseguibili_x86\Media\eac3to\eac3to.exe" "F:\Raw\Solo — A Star wars story" 2) 4:"E:\in\2_14 Solo — A Star wars story\2_4_audio.eac3" -keepDialnorm
(when eac3to try to change Dialog Normalization crash)
After that my recomendation is preserve the track as is, recode to flac doesn't make sense for me.
A lossy track when is decoded the output is 32 float (even 64 float) and make a flac with this...
Old 22nd July 2020, 12:12   #14987  |  Link
Thunderbolt8
has anyone tried if this https://github.com/domyd/mlp
is it more accurate than demuxing THD tracks with eac3to (or any other tool)? could this tool be incorporated here as well like other components?
Laptop Acer Aspire V3-772g: i7-4202MQ, 8GB Ram, NVIDIA GTX 760M (+ Intel HD 4600), Windows 8.1 x64, madVR (x64), MPC-HC (x64), LAV Filter (x64), XySubfilter (x64)
Old 22nd July 2020, 23:55   #14988  |  Link
tebasuna51
tebasuna51's Avatar
Here?
Seems madshi don't want make new versions.
I will try to include it to the UsEac3to GUI.
I can't get binary with stream selection, maybe in next release.
Old 25th July 2020, 13:02   #14989  |  Link
planet1
... space nerd ...
planet1's Avatar
Ohh, so there is not much of a point in posting any feature requests here or at http://eac3to.bugs.madshi.net then?
planet1 is offline   Reply With Quote
Old 25th July 2020, 16:11   #14990  |  Link
Thunderbolt8
I hope there still is and that madshi is currently just prioritizing madvr
Old 25th July 2020, 21:25   #14991  |  Link
stax76
madvr is closed source and under-maintained as well I believe, meaning hardly progress for both in the last 2-3 years, or maybe I'm just not well-informed.
Old 3rd August 2020, 11:40   #14992  |  Link
tebasuna51
tebasuna51's Avatar
Included the use of the version than can select the TrueHD stream in UsEac3To
Old 31st August 2020, 09:38   #14993  |  Link
pottzman
Yes, download a program called "attribute changer" https://www.petges.lu/download/ and use it on "splitter.ax" and "splitter64.ax" in the haali media splitter directory to change the creation and modified dates to 2013-06-23. eac3to will not complain anymore.
pottzman is offline   Reply With Quote
Old 11th September 2020, 14:47   #14994  |  Link
Skyrocket
Can anyone please help me. Been trying for a few days to learn how to fix it with no luck.
I am wanting to convert my audio with eac3to to aac. When trying it comes up with the Nero error. I have Nero 7 installed on my computer but dont think its linked with the eac3to. What can or should i do to convert to aac?
Skyrocket is offline   Reply With Quote
Old 11th September 2020, 21:16   #14995  |  Link
tebasuna51
tebasuna51's Avatar
Nero 7 is used to decode AAC, to encode to AAC you need NeroAacEnc.exe from here in the same folder than eac3to
Old 20th September 2020, 09:11   #14996  |  Link
Csimbi
Hi there,
is there any plan to add Atmos to wav conversion?
(with metadata support, not just TrueHD conversion)
Thanks!
Best regards: Csimbi
Csimbi is offline   Reply With Quote
Old 20th September 2020, 10:24   #14997  |  Link
SeeMoreDigital
Life looks better in UHD
SeeMoreDigital's Avatar
Originally Posted by Csimbi View Post
Hi there,
Thanks!
Are you're hoping to encode the 'spatially-coded sub-stream meta-data' for the height/object channels into separate mono PCM streams?
Old 20th September 2020, 12:08   #14998  |  Link
stax76
I would like to request Windows 10 long path support if this app isn't dead. It works via prefix workaround so probably only misses the manifest info.
https://github.com/staxrip/staxrip/w...g-path-support
Old Today, 14:12   #14999  |  Link
pottzman
Originally Posted by heerschop View Post
Let me know if you get it to work.
I am using arcsoft, nero, sonic and surcode with eac3to, all without installing them completely on my system.
If someone knows how to get the sonic decoder working qithout installing it could they post it here. I can get nero, arcsoft and surcode all working without installing them but not the sonic decoder
eac3to
