31st May 2013, 15:29 | #17361 | Link | |
31st May 2013, 16:33 | #17363 | Link | |
Bit of a fanboy comment, but I currently trust PC power and cooling, Corsair, and Seasonic. A much larger list to stay away from LOL! I'm currently employing a Corsair. Zero hiccups.
31st May 2013, 19:23 | #17364 | Link | |
So, for some reason BD-RB figured 85 minutes was enough. There's no mention of anomalies in the log, however. Except... main feature is 00005.m2ts which consists of a single video track, two DTS-HD MA tracks and a single subtitle track - and it's 29.7GB. And yet the log reads: - [02:34:04] Processing: VID_00005 (2 of 12) - [02:34:04] Extracting A/V streams [VID_00005] - [03:28:48] Reencoding video [VID_00005] - [03:28:49] Keeping original video (no reencode) - [03:28:49] Processing audio tracks - Track 4353 (eng): Keeping original audio - [03:28:49] Multiplexing M2TS There are 21 other m2ts files in the directory, for a total of 1.25GB. To debug a bit, I'm re-ripping this for another go. This time I'll be encoding from a BD directory structure instead of a mounted ISO. Last edited by colinhunt; 31st May 2013 at 21:32. |
31st May 2013, 23:42 | #17365 | Link |
Target size is too small
Trying to rebuild The Last Stand and am getting the error "Target is too small to continue." Have tried direct from original disc and from rip. Have tried different target drives that have 87GB and 112GB free space respectively. Have tried BD9 and BD25 output sizes and still receive the error. Any ideas? Thanks for any help/suggestions...
- Windows Version: 6.1 [7601] - AVISYNTH Version: [2.5.8.0], Ok - HAALI Splitter: [1.9.42.1], Ok - FFDSHOW: [4422], Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - AnyDVD settings check: Ok. - BD Rebuilder v0.44.0.9, Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok ---------------------- [05/31/13] BD Rebuilder v0.44.09 (beta) [12:26:36] Source: THE_LAST_STAND - Input BD size: 47.21 GB - Approximate total content: [02:07:41.194] - Target BD size: 7.84 GB - Windows Version: 6.1 [7601] - MOVIE and MENUS mode enabled - SHUTDOWN at completion enabled - Auto Quality: High Quality (Default), Two Pass - Decoding/Frame serving: DGDecNV [4-way] - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 - Target too small. Encode stopped. ---------------------- [05/31/13] BD Rebuilder v0.44.09 (beta) [12:27:01] Source: THE_LAST_STAND - Input BD size: 47.21 GB - Approximate total content: [02:07:41.194] - Target BD size: 22.95 GB - Windows Version: 6.1 [7601] - MOVIE and MENUS mode enabled - SHUTDOWN at completion enabled - Auto Quality: Good (Very Fast), ABR - Decoding/Frame serving: DGDecNV [4-way] - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 - Target too small. Encode stopped. [Options] VERSION=0.44.0.9 MODE=1 ENCODE_QUALITY=2 ONEPASS_ENCODING=0 AUTO_QUALITY=1 TARGET_SIZE=8032 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=eng; SD_CONVERT=0 OPEN_GOP=0 RESIZE_1080=0 RESIZE_1440=0 DEINTERLACE=1 SD_TO_1080=0 CONVERT_WIDE=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=0 AVCHD=1 REMOVE_WORKFILES=1 MOVIE_ONLY_LOOP=1 REMOVE_OUTPUT=1 USE_FILTERS=0 BDMV_CERT_ONLY=1 USE_LAVF=0 IVTC_PULLDOWN=0 ASSUME_DVD_PAL=0 UNMASK_CHAPTER=0 COMPLETION_BEEP=1 DGDECNV=1 OUTPUT_3D=0 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=23500 ENABLE_TEST=1 DTSX_ENABLE=1 ENABLE_BLANKING=1 BLANK_THRESHOLD=1800 AUTO_BIAS=3 MULTIPROCESS=1 IMPORT_FOLDER=E:\IMPORTS\ BEEP_SOUNDFILE=C:\Windows\Media\tada.wav [Paths] DGIndexNV=C:\Users\eM\Downloads\BD_Rebuilder\dgdecnv2045\DGIndexNV.exe DGDecNV=C:\Users\eM\Downloads\BD_Rebuilder\dgdecnv2045\DGDecodeNV.dll DirectShowMVCSource=C:\Users\eM\Downloads\BD_Rebuilder\BD3D2MK3D\toolset\stereoplayer.exe\DirectShowMVCSource.dll SOURCE_PATH=G:\ WORKING_PATH=E:\BLU-RAY\THE_LAST_STAND_BD9\ |
1st June 2013, 00:16 | #17366 | Link | |
http://forum.doom9.org/showthread.php?t=167942 Last edited by gonca; 1st June 2013 at 00:18. |
1st June 2013, 05:03 | #17368 | Link |
The Karate Kid
I've found what looks to be a bug. Submitted for you to check.
Picture 1 BD-RB shows it recognizes the 2nd DTS for the PiP. Picture 2, the processing doesn't include the 2nd DTS when it goes on to the rest of the process. Picture 3, are the list of files. No blank files, the Secondary DTS doesn't get extracted. Log: Code:
[05/31/13] BD Rebuilder v0.44.09 (beta) [19:19:18] Source: KARATE_KID - Input BD size: 43.24 GB - Approximate total content: [03:56:11.705] - Target BD size: 22.95 GB - Windows Version: 6.1 [7601] - Quality: High-Speed Option (BD-25), Two Pass - Output folder: H:\!Blu-ray\ - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=640 [19:19:20] PHASE ONE, Encoding - [19:19:20] Processing: VID_00011 (1 of 14) - [19:19:20] Extracting A/V streams [VID_00011] - [19:28:09] Reencoding video [VID_00011] - [19:28:09] Keeping original video (no reencode) - [19:28:09] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... - Track 6656 (eng): Keeping original audio - Track 4356 (eng): Keeping original audio - [19:31:08] Multiplexing M2TS - [19:47:16] Remuxing DTSX/IGS stream(s) - [20:14:08] Processing: VID_00081 (2 of 14) - [20:14:08] Extracting A/V streams [VID_00081] - [20:14:16] Reencoding video [VID_00081] - [20:14:16] Keeping original video (no reencode) - [20:14:16] Processing audio tracks - [20:14:16] Multiplexing M2TS - [20:14:25] Processing: VID_00101 (3 of 14) - [20:14:25] Extracting A/V streams [VID_00101] - [20:14:30] Reencoding video [VID_00101] - [20:14:30] Keeping original video (no reencode) - [20:14:30] Processing audio tracks - Track 4352 (eng): Keeping original audio - [20:14:30] Multiplexing M2TS - [20:14:37] Processing: VID_00104 (4 of 14) - [20:14:37] Extracting A/V streams [VID_00104] - [20:14:43] Reencoding video [VID_00104] - [20:14:43] Keeping original video (no reencode) - [20:14:43] Processing audio tracks - Track 4352 (eng): Keeping original audio - [20:14:43] Multiplexing M2TS - [20:14:50] Processing: VID_00105 (5 of 14) - [20:14:50] Extracting A/V streams [VID_00105] - [20:15:26] Reencoding video [VID_00105] - [20:15:26] Keeping original video (no reencode) - [20:15:26] Processing audio tracks - Track 4352 (eng): Keeping original audio - [20:15:26] Multiplexing M2TS - [20:15:47] Processing: VID_00106 (6 of 14) - [20:15:47] Extracting A/V streams [VID_00106] - [20:16:20] Reencoding video [VID_00106] - [20:16:20] Keeping original video (no reencode) - [20:16:20] Processing audio tracks - Track 4352 (eng): Keeping original audio - [20:16:20] Multiplexing M2TS - [20:16:39] Processing: VID_00107 (7 of 14) - [20:16:39] Extracting A/V streams [VID_00107] - [20:17:03] Reencoding video [VID_00107] - [20:17:03] Keeping original video (no reencode) - [20:17:03] Processing audio tracks - Track 4352 (eng): Keeping original audio - [20:17:03] Multiplexing M2TS - [20:17:16] Processing: VID_00108 (8 of 14) - [20:17:16] Extracting A/V streams [VID_00108] - [20:17:32] Reencoding video [VID_00108] - [20:17:32] Keeping original video (no reencode) - [20:17:32] Processing audio tracks - Track 4352 (eng): Keeping original audio - [20:17:32] Multiplexing M2TS - [20:17:41] Processing: VID_00109 (9 of 14) - [20:17:41] Extracting A/V streams [VID_00109] - [20:17:58] Reencoding video [VID_00109] - [20:17:58] Keeping original video (no reencode) - [20:17:58] Processing audio tracks - Track 4352 (eng): Keeping original audio - [20:17:58] Multiplexing M2TS - [20:18:09] Processing: VID_00111 (10 of 14) - [20:18:09] Extracting A/V streams [VID_00111] - [20:18:18] Reencoding video [VID_00111] - [20:18:18] Keeping original video (no reencode) - [20:18:18] Processing audio tracks - Track 4352 (eng): Keeping original audio - [20:18:18] Multiplexing M2TS - [20:18:24] Processing: VID_00112 (11 of 14) - [20:18:24] Extracting A/V streams [VID_00112] - [20:18:33] Reencoding video [VID_00112] - [20:18:33] Keeping original video (no reencode) - [20:18:33] Processing audio tracks - Track 4352 (eng): Keeping original audio - [20:18:33] Multiplexing M2TS - [20:18:47] Processing: VID_00115 (12 of 14) - [20:18:47] Extracting A/V streams [VID_00115] - [20:18:56] Reencoding video [VID_00115] - [20:18:56] Keeping original video (no reencode) - [20:18:56] Processing audio tracks - Track 4352 (eng): Keeping original audio - [20:18:57] Multiplexing M2TS - [20:19:13] Processing: VID_00116 (13 of 14) - [20:19:13] Extracting A/V streams [VID_00116] - [20:19:24] Reencoding video [VID_00116] - [20:19:24] Keeping original video (no reencode) - [20:19:24] Processing audio tracks - Track 4352 (eng): Keeping original audio - [20:19:24] Multiplexing M2TS - [20:19:43] Processing: VID_00118 (14 of 14) - [20:19:43] Extracting A/V streams [VID_00118] - [20:19:53] Reencoding video [VID_00118] - [20:19:53] Keeping original video (no reencode) - [20:19:53] Processing audio tracks - Track 4352 (eng): Keeping original audio - [20:19:53] Multiplexing M2TS [20:20:10]PHASE ONE complete [20:20:10]PHASE TWO - Rebuild Started - [20:20:10] Rebuilding BD file Structure [20:42:24] - Encode and Rebuild complete [20:42:24] JOB: KARATE_KID finished. Code:
[Options] VERSION=0.44.0.9 MULTIPROCESS=0 ENABLE_TEST=1 DTSX_ENABLE=1 FORCE_NOENCODE=1 MKV_MUXSUPS=1 MODE=0 ENCODE_QUALITY=5 ONEPASS_ENCODING=0 AUTO_QUALITY=0 TARGET_SIZE=23500 MOVIEONLY_TYPE=28 ALTCRF=20 ALTMETHOD=0 ALT_TARGET=1024 ALTAUTOCROP=0 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=eng; SD_CONVERT=0 OPEN_GOP=0 RESIZE_1080=0 RESIZE_1440=0 DEINTERLACE=1 SD_TO_1080=0 CONVERT_WIDE=0 DTS_REENCODE=1 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=0 AVCHD=1 REMOVE_WORKFILES=0 MOVIE_ONLY_LOOP=1 REMOVE_OUTPUT=0 USE_FILTERS=0 BDMV_CERT_ONLY=0 USE_LAVF=0 IVTC_PULLDOWN=1 ASSUME_DVD_PAL=0 UNMASK_CHAPTER=0 COMPLETION_BEEP=0 DGDECNV=0 OUTPUT_3D=0 AUDIO_TRACK_LIMIT=0 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=23500 QUICK_EXTRAS=0 ENABLE_BLANKING=1 OUTPUT_FOLDER=H:\!Blu-ray [Paths] SOURCE_PATH=T:\BLU-RAY RIPS\KARATE_KID\ WORKING_PATH=E:\BLU-RAY\REBUILDER\
1st June 2013, 09:08 | #17369 | Link | |||
Swallowed in the Sea
When I use MP4 as alternative output + MP4_CHAPTERS=1 switch in hiddenopts.txt file, I got no chapters in my output :
- why using a such old mp4box version ? - which command line is used to create mp4 file ? - why using faac as audio encoder ? Are you insane ? - why target size is selected in the menu whereas I selected CRF value ? - Is there a way to change the x264 preset ? - Why not putting a warning or something else when we select PGS streams as input and choose MP4 as output ? it's not supported... Last edited by Kurtnoise; 1st June 2013 at 09:13. |
1st June 2013, 13:10 | #17370 | Link | |
1st June 2013, 17:53 | #17371 | Link | |||||||
1st June 2013, 22:04 | #17372 | Link | |
Image 2 is showing what's not there after the process.
2nd June 2013, 03:45 | #17373 | Link |
Well I can't speak for MKVMERGE GUI or how it works, but I do PiP backups with DTS Express all the time and the audio always there when I watch it back. But I'll take a look at it again. I especially want to look at it with MKVMERGE GUI to see if it sees it. As you may know, there are some issues on certain players (like the Sony S360) with the remuxed DTS Express playback. It could be the whatever that is (I've been looking for it for a long time) may somehow be related to MKVMERGE not seeing it.
2nd June 2013, 06:50 | #17374 | Link | |||||||
There are some others aac encoder that meets your requirements : fdk-aac and qaac. Quote:
So, my question was : why the target size is still selected in the menu whereas I choose a CRF value for alternative output...my goal is to have a certain output quality not a target file size. Last edited by Kurtnoise; 2nd June 2013 at 08:04. |
2nd June 2013, 13:20 | #17375 | Link | |
With FORCE_ENCODE=1 option, it seems to work. Is it possible to change resize filter ? Lanczos instead of Bilinear ? Thanks ! Last edited by Nico8583; 2nd June 2013 at 13:38. |
2nd June 2013, 15:16 | #17376 | Link | ||||||
And... you should take a few minutes to read the FAAC and GNU agreement (which is, by the way, included in the BD-RB package -- as required) and you'd see you are incorrect: Quote:
3rd June 2013, 08:25 | #17377 | Link | |||
From the official website :
And from wikipedia : Quote:
You have tested only with Video/Audio streams but did you test also with subtitles and/or chapters ? Doesn't seem so... Last edited by Kurtnoise; 3rd June 2013 at 08:30. |
3rd June 2013, 14:06 | #17378 | Link |
@Kurtnoise
How about we let me make the decisions about my software, and you make the decisions about yours. This is a bug reporting thread, not an opportunity for folks to express "how they'd do it" or a debating club... so let's get back on topic. As I said, I will look at the MP4 chaptering. MP4 subtitles aren't likely to change, since BD-RB uses a BD as its source, and the only subtitles typically available are PGS -- and most OCR conversion methods require too much manual interaction. Last edited by jdobbs; 3rd June 2013 at 14:14. |
6th June 2013, 10:39 | #17379 | Link |
Forced subtitles.
I'm new to this forum but have been using BDRebuilder for a while now with complete success (Fab product - when will it be available to buy?) Recently I noticed (movie only) the right-click “Turn on” is no longer an option to force subtitles. Has it been removed? The option is also not available when importing several MKV files (each containing subs). Last edited by Barcoed; 6th June 2013 at 11:16. Reason: Extra info. |
6th June 2013, 13:59 | #17380 | Link | |
