Old 14th January 2019, 05:39   #6021  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Originally Posted by P.J View Post
Actually, MPC-BE cuts only from the bottom and doesn't care about the crop values.
Hope you can fix it to read the values correctly
Very strange. In this file, clap atom contain:
apertureHeight - 480
vertOff - 13
I don't know how we can have top - 29 and bottom - 3...
Old 14th January 2019, 10:11   #6022  |  Link
P.J
Δ
vertOff - 13
Yes, v0lt was posted a screenshot from MP4 Inspector before too.
But I'm sure the right pixel value for top is 29 not 13.
Let's see if I can find more clues about it =/
https://developer.apple.com/library/...9-CH205-125850
P.J is offline   Reply With Quote
Old 14th January 2019, 10:33   #6023  |  Link
Aleksoid1978
There is no other information how handle this value - stay it question opened
Old 14th January 2019, 15:41   #6024  |  Link
v0lt
Data from the 'clap' atom.
Old 14th January 2019, 15:42   #6025  |  Link
P.J
Δ
vertOff - 13
Aleksoid1978, think I found the formula This is about to find the top/bottom numbers:
First, we need to calculate the cropped vertical pixels: 512-480=32 (cropped pixels)
Then check the "vertOff_D (denominator)", it's fine if it was 2 but if it was 1, multiply "vertOff_N (numerator)" by 2.
So we can find the right offset from the center of video.
In that sample, "vertOff_D (denominator)" is 1, so we should multiply "vertOff_N (numerator)" by 2: 13*2=26 (real offset)
But if "vertOff_D (denominator)" was 2: "vertOff_N (numerator)" = real offset
Note: "vertOff_N (numerator)" or real offset can be negative too.
Now we just need to solve this equation to find top and bottom numbers:
top+bottom=32
top-bottom=26
top=29 / bottom=3
I'm sure that same can be applied to the left/right numbers too
Old 14th January 2019, 19:16   #6026  |  Link
v0lt
@P.J
Fixed in r4329.
Old 14th January 2019, 20:20   #6027  |  Link
Megalith
I see this (for one second) whenever I try to open a video, even a low-resolution file that should begin playback immediately.
It's as if MPC-BE loads its skin, but then reloads it before playback begins. The result is that opening a file, even on a non-busy hard drive, feels laggy.
I don't think there's anything to fix but was just curious if anyone had the same experience.
Megalith is offline   Reply With Quote
Old 16th January 2019, 02:56   #6028  |  Link
peter0815x
hi
i just tested latest version
1.5.3.4322
and the bug with high res audio files
and wasapi exclusiv is still there
(files above 192k will be downsampled to 192k)
it was fixed with the latest test build from Aleksoid1978
https://yadi.sk/d/H3GEZ5vu4O0StA
but seems fix didn't make it into 1.5.3.
peter0815x is offline   Reply With Quote
Old 16th January 2019, 03:07   #6029  |  Link
Aleksoid1978
Originally Posted by peter0815x View Post
hi
1.5.3.4322
Check this setting "Do not check format support".
Old 16th January 2019, 17:28   #6030  |  Link
peter0815x
thx its working
Old 17th January 2019, 17:53   #6031  |  Link
tormento
Acid fr0g
tormento's Avatar
Can I ask you to have a "delete key" support to delete files while playing videos of a folder?
Sometimes it comes useful when scrubbing old directories.
@turment on Telegram
Old 17th January 2019, 22:35   #6032  |  Link
P.J
Δ
Originally Posted by v0lt View Post
@P.J
Fixed in r4329.
Old 18th January 2019, 20:03   #6033  |  Link
hubi73
Another Youtube problem, but it is not playlist related like the last one that I reported. Youtube-dl was also affected, but they fixed it in the last release.
https://www.youtube.com/watch?v=GcvBnhq0lFA
https://www.youtube.com/watch?v=9GuUbziASwE
https://www.youtube.com/watch?v=yFnQu0kmCuY
None of these links will play with internal web parser, but with the youtube-dl support and version 2019.01.17.
hubi73 is offline   Reply With Quote
Old 19th January 2019, 00:50   #6034  |  Link
Aleksoid1978
Thanks - fixed.
Old 19th January 2019, 01:18   #6035  |  Link
hubi73
Thanks for fixing.
Old 19th January 2019, 13:52   #6036  |  Link
wanezhiling
https://www.sendspace.com/file/g53tnz
can't play the clip with internal hevc dxva decoder, happens on nvidia platform only
Old 19th January 2019, 15:34   #6037  |  Link
v0lt
@wanezhiling
I do not confirm. GTX 950 plays fine.
Old 19th January 2019, 21:07   #6038  |  Link
yonta
mpc-be plays this video at around 15 fps when it is actually a 29.970fps video. I tried mpc-hc and mpv and they played it @29.970 just fine.
Format                                   : MPEG-4
Format profile                           : Base Media
Codec ID                                 : isom (isom/iso2/avc1/mp41)
File size                                : 61.9 MiB
Duration                                 : 1 min 5 s
Overall bit rate                         : 7 980 kb/s
Writing application                      : Lavf58.26.100
Video
Format                                   : AVC
Format profile                           : Main@L4
Format settings                          : CABAC / 3 Ref Frames
Format settings, CABAC                   : Yes
Format settings, RefFrames               : 3 frames
Codec ID                                 : avc1
Codec ID/Info                            : Advanced Video Coding
Bit rate                                 : 7 846 kb/s
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Frame rate                               : 29.970 (30000/1001) FPS
Bits/(Pixel*Frame)                       : 0.126
Stream size                              : 60.9 MiB (98%)
Title                                    : h264@GPAC0.7.2-DEV-rev989-g637a1d0b-master
Codec configuration box                  : avcC
Audio
Format                                   : AAC LC
Format/Info                              : Advanced Audio Codec Low Complexity
Codec ID                                 : mp4a-40-2
Bit rate                                 : 125 kb/s
Channel layout                           : L R
Sampling rate                            : 48.0 kHz
Frame rate                               : 46.875 FPS (1024 SPF)
Stream size                              : 995 KiB (2%)
Title                                    : aac@GPAC0.7.2-DEV-rev989-g637a1d0b-master
Alternate group                          : 1
yonta is offline   Reply With Quote
Old 20th January 2019, 02:16   #6039  |  Link
wanezhiling
@wanezhiling
i tried with 1050ti and 1060, no luck.
Old 20th January 2019, 03:48   #6040  |  Link
Aleksoid1978
It's support HEVC 10 bit, check in DXVACheker. Check with LAVVideo Decoder.
