16th January 2010, 02:55 | #6642 | Link | |
here ya go |
16th January 2010, 04:43 | #6643 | Link |
@Atak_Snajpera
I tried again in other pc and it worked, maybe it's codecs conflict but, i don't use codec packs. After that, i tried each file separately, first I loaded the video and everything was fine, but when i loaded the audio file, ffdshow Video decoder icon appear in systray next to haali media spliter icon and later the OptimFROG.dll message appear. i have installed, Xvid 1.0.3, ffdshow rev3154, QuickTime alternative 3.0.1, Real Media Alternative 2.0.1, Haali Media Splitter 1.9.42.1, Avisynth 2.8 and AC3Filter 1.62b Any sugestion? EDIT: i remaned the file bass_ofr.dll to bass_ofr.dll_ and it worked, but i don't know why... in this link http://forum.doom9.org/archive/index...04686-p-4.html somebody named tebasuna51 said: if you don't need decode OptimFROG encoded files the best solution is delete bass_ofr.dll Last edited by fantasmanegro; 16th January 2010 at 06:14. |
16th January 2010, 08:46 | #6644 | Link |
Small request...
1st of all THANK YOU for this great app!!!
2nd, i have a small request... Could you implement in a future release more options regarding CRF values? For example you could give us a wider range from 16-26 (or even more) in a more detailed manner (like 16,17,18 and so on and not 18,20,22...) - kind of like in Staxrip... For the time being if i want to encode in CRF21 (just an example) i have to edit the .cmd in the job folder - would be nice if these options could be selectable from within the gui... I think that should be not too much trouble for you... Again, thank you for your time!!! |
16th January 2010, 11:50 | #6646 | Link | |
There are two options: - If you need OptimFROG decoder put both files (bass_ofr.dll and OptimFROG.dll) in your AviSynth plugins folder. You can download the last version here. - If you don't need OptimFROG decoder delete bass_ofr.dll, rename to '.dll_' also work because only .dll are loaded, but is useless, you can always download a correct pair bass_ofr.dll and OptimFROG.dll.
16th January 2010, 13:58 | #6647 | Link |
ripbot saving output file bug .
have an issue with the saving file to a hard drive after decoding the film to prepare for encoding
if i choose other drive for the ouput than the one given by the software itself , usually by default c:/ i get no file at all at the end of the encoding .no trace . i had hard drives with bigger spaces than c . and when i choose d drive for example or m drive { my 2 other drives}for saving the file to encode in the output section , and i have a lot of space left , i get 0 files saved and nothing in the folder i saved the file for the encoding at all . i get ripbot has finished encoding .but nothing i was encoding postman in blu-ray ripped last time and i had to leave it to ouput in c drive to get the job done . if not i get nothing in any other drive i choose . that happened in windows xp and 7 . let me know if i don't do something right . cause i can't figure it out . i presume it is a bug that need to be fixed long ago . it happened with previous versions of ripbot as well. |
16th January 2010, 23:48 | #6649 | Link | ||
@crackinhedz Demuxed dts audio seems to be damaged in some weird way. Solution: 1) After demuxing movie go to X:\Temp\RipBot264temp\jobx folder (do not close ripbot!) 2) open Blu-Ray_ExtractStreams.cmd in notepad 3) remove this section from first line Code:
1: "X:\temp\RipBot264temp\jobx\video.mkv" -seekToIFrames Code:
2: "x:\temp\RipBot264temp\job1\audio_Undetermined.flac" 5) Double click on Blu-Ray_ExtractStreams.cmd 6) add .flac file in ripbot @angel40204 You mean temp folder or output folder? Why didn't you show me log?
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 17th January 2010 at 00:39. |
17th January 2010, 01:27 | #6651 | Link |
forget about this
17th January 2010, 04:26 | #6652 | Link |
Hi Atak,
I have an movie MKV audio track has 22s of delay. Did you know how to set an delay of 22sec manually (now only up and down feature) 22seconds could take very long. lol! After conversion, 22sec (24fps to 23.976) audio is out of sync with no delay set. Suggestion #1: Can we have an box choice to enter the digits ? Suggestion #2: Can we have an check box option to copy video tracks into JOB folder (offer if only user check it) because for somebody 6 projects (6 videos tracks) can't take a lot of space. Thanks!
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. |
17th January 2010, 11:37 | #6654 | Link |
bug from output folder
i get no file at all at the end of the encoding .no trace . that is what i said in my previous thread . but i was not clear enough. i meant the output folder by default . if i choose another folder than that . i get ripbot to encode . but no file at the end inside the folder i wanted to save it to . for the log. did not think about it .and i deleted everything from the last job. |
17th January 2010, 19:08 | #6655 | Link |
Problems w/Oppo BDP-83??
Hello,
Just wanted to know if anyone w/an Oppo BDP-83 has experienced any issue w/AVCHD discs lately? I convert a high volume of movies to AVCHD format using RipBot. I generally test before burning if everything is in sync, correct size, etc on my PC usually through Zoom Player or VLC. If everything is good, I then burn using Verbatim or Memorex DVD+R DL discs or BD25s. Never had this problem before & can't figure out when it started (I rarely get a chance to watch the movies I convert & burn for a little while) but when playing anything converted w/RipBot (or BD Rebuilder for that matter) over the last few versions, the movie is constantly "tearing" or breaking up. Regular BDs, DVDs, .avi files, etc still play great on the Oppo. I've upgraded the firmware & still have this problem. What really kills me when trying to figure this out is the movies play perfectly using: PS3, Samsung BDP-1400 or Sony BDP-350. Obviously, the problem is the Oppo but before throwing this at their support team to look into, I wanted to see if I could try to find out what exactly may be the problem. If their is a bunch Oppo BDP-83 users here & no one else is seeing these problems, then maybe its a problem on my unit. The fact that I only get these problems w/encodes & the problem only shows itself on the Oppo is what gets me the most. I've asked this question over in the Oppo owners thread but haven't found anyone thats seen this issue. Will also look into over at the BD-Rebuilder forum here as well. Thanks for your time... Last edited by brogan; 17th January 2010 at 20:13. |
17th January 2010, 21:55 | #6656 | Link | |
@brogan uncheck weighten p-prediction
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 17th January 2010 at 22:11. |
17th January 2010, 23:03 | #6658 | Link |
click on button beside profile
18th January 2010, 03:50 | #6660 | Link | |
I dont care so should you
Read rule 6 And enjoy...
My Installer's || |
