23rd March 2009, 11:45 | #81 | Link |
HDConvertToX author
update to HDConvertToX_0.3.49.597
changelog update manual added working dir added ifo support (beta) fixed priority of encoding fixed fonts size fixed/added tooltips fixed normalize audio added "remove all jobs button" added "save batch queue button" and please, read the manual BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
23rd March 2009, 16:58 | #82 | Link |
HDConvertToX author
update the same full package (but build is now 0.3.56.638)
added a LOT better support for WMV encoding BHH
24th March 2009, 00:16 | #83 | Link |
Rodoga
Nice !
Hi I use AutoMKV all the time and I think it's great. Thought I would try this program but everytime I get an error message when pressing "analyze file" button. x264.exe "cannot find procedure entry point av_crc04C11DB7 in DLL file avutil-49.dll".
Anyone knows why? One feature I always wanted in AutoMKV is to be able to remux DVD to MKV without encoding. Even remuxing TS files with subtitles into MKV would be great. Please consider this feature. |
24th March 2009, 03:23 | #84 | Link |
Trying XViD+MP4 but I never had the final MP4 file muxed. Only the the video (as avi) and audio (as mp4).
Rodoga, remuxing DVD to MKV is very very easy with MakeMKV. Make some search. enjoy, Mtz Last edited by Mtz; 24th March 2009 at 03:28. |
24th March 2009, 06:22 | #85 | Link |
HDConvertToX author
@Rodoga
what OS you use ? have you installed all required applications (as first post) ? @Mtz add the job to queue, use save queue button AND post here the batch BHH
24th March 2009, 08:19 | #86 | Link |
HDConvertToX author
update HDConverToX (download the full package , then update with single exe)
disable audio options when copy audio is selected (thanks to Echelon for suggesting) added support for wmv encoding via wmcmd.vbs added avi to list of support media type added tags to HDConvertToX.exe fixed muxing mp4/mkv with more then one audio fixed use of strange characters in output file name BHH
24th March 2009, 13:14 | #88 | Link |
HDConvertToX author
@Mtz
thanks, fixed update to 0.4.63 build added compression test added deinterlace test both options are on "Utilities and Path" panel BHH
24th March 2009, 14:17 | #90 | Link |
HDConvertToX author
av-util is used by eac3to
please launch from dos prompt eac3to.exe yourfile is reporting errors ? BHH
24th March 2009, 16:58 | #91 | Link |
Life's clearer in 4K UHD
Hi Buzz,
I've just tried generating an encode from a short (1270 frame) MPEG-2 (.MPG) source, and noticed that there's a difference between the quantity of frames listed in the "GUI" and the "Console Window": - Cheers
24th March 2009, 17:14 | #92 | Link |
HDConvertToX author
i will try to explain
i got the frame count from avisynth AND for avi -> i open input file with ffmpegsource for d2v -> i open input file with mpeg2source for dga-> i open input file with avcsource for all other (mpeg too) -> i use directshowsource x264 will show a number detected by mpeg2source, since before encoding i will "dgindex" (or dgavcdec) the source file thanks SMD for testing my application! BHH
25th March 2009, 00:55 | #93 | Link |
Rodoga
Testing
D:\HDConvertToX\applications>eac3to.exe H:\VIDEO_TS\VTS_01_1.VOB VOB, 1 video track, 2 audio tracks, 1 subtitle track, 0:28:14 1: MPEG2, 480p24 /1.001 (16:9) with pulldown flags 2: AC3, 5.1 channels, 448kbps, 48khz, dialnorm: -27dB 3: AC3, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB 4: Subtitle (DVD) no errors |
25th March 2009, 06:31 | #94 | Link |
HDConvertToX author
@Rodoga
could you please post a screenshot of error ? (both hdconverttox and error) MORE IMPORTANT is H:\VIDEO_TS\VTS_01_1.VOB a dvd-rom unit or a ripped dvd ? as i say in manual hdconverttox is unable to process non-ripped dvd BHH
25th March 2009, 13:54 | #95 | Link |
HDConvertToX author
update to 0.5.75.751 NEW FULL PACKAGE
fixed NMT profile added support for m2ts fixed update manual fixed faster deinterlace analysis added at launch HDConvertToX will delete temporary files present in its folder BHH
25th March 2009, 21:13 | #96 | Link |
Just tried the latest full package, i receive a MSDXM.OCX error when hitting preview, it's a fresh vista install, need components are installed...any ideas? when i manually add the file into the applications folder, nothin happens when i hit preview,mplayer.exe is not even listed in the task manager.
regards |
26th March 2009, 08:30 | #97 | Link |
HDConvertToX author
update HDConvertToX
added aac to list of supported copy audio for m2ts added support for language audio tag (mkv/mp4/m2ts) @spida_singh fixed in next update PLEASE put media player classic in \applications folder BHH
26th March 2009, 17:03 | #98 | Link |
HDConvertToX author
update
fixed audio encoding only for wma fixed update manual added button to open manual added support for hidden options: shutdown.txt, reboot.txt, suspend.txt fixed DAR value is read only since editing it is useless fixed H264 codec in TS files BHH
27th March 2009, 05:42 | #100 | Link | |
HDConvertToX author
simply don't resize and don't crop version mumbering is quite easy: 0.5.88.818 0.5 mayor release 88 build release 818 current release the newer.. the better the biggest number, the better BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 Last edited by buzzqw; 27th March 2009 at 06:41. |
bluray, hdc, hdconverttox, m2ts, network media tank, playstation, x264 gui |
