Old 16th September 2019, 09:50   #7021  |  Link
Possibly best choice to report a bug: x265 developer mailing list.
I forwarded your report, redbtn.
Old 16th September 2019, 13:11   #7022  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Using the latest VS2019 AVX build (3.1+19-c4b098f) from here: http://msystem.waw.pl/x265/ crashes the encoder in the beginning. Does anyone else have the same issue? I'm using a Ryzen 1800X with AVX2 disabled in the x265 command line.
Old 17th September 2019, 10:26   #7023  |  Link
benwaggoner
Originally Posted by redbtn View Post
What about new option --selective-sao? Anybody knows should i disable it, like --no-sao earlier?
https://bitbucket.org/multicoreware/...f47?at=default
The broader question is what are the psychovisual and compression efficiency impact of the different modes. The documentation is tragically light on the "why" of this feature. SAO is fast enough that I don't see any direct perf advantage of this, although perhaps it might help parallelization in some esoteric way to only do SAO on non-predicted frames or something.
But if SAO detail loss varies somewhat by frame type, only using it on intra stuff might enhance detail with less of a compression efficiency hit than turning it off outright.
Ben Waggoner
My Compression Book
Old 18th September 2019, 12:59   #7024  |  Link
The media-autobuild suite now introduced experimental support for ccache.
About at the same time, I have issues building a multilib x265 encoder with the manually fiddled build script which usually worked for years already. But building in MABS passes without error.
I am not sure if I have too many linking flags which may interfere with either ccache or with the current development state of x265. It fails linking the DLL:
[ 84%] Linking CXX shared library libx265.dll
E:/MABS/msys64/mingw32/bin/../lib/gcc/i686-w64-mingw32/9.2.0/../../../../i686-w64-mingw32/bin/ld.exe: CMakeFiles/x265-shared.dir/objects.a(vec-primitives.cpp.obj):vec-primitives.cpp:(.text+0x2c): undefined reference to `x265::setupIntrinsicDCT_sse3(x265::EncoderPrimitives&)'
E:/MABS/msys64/mingw32/bin/../lib/gcc/i686-w64-mingw32/9.2.0/../../../../i686-w64-mingw32/bin/ld.exe: CMakeFiles/x265-shared.dir/objects.a(vec-primitives.cpp.obj):vec-primitives.cpp:(.text+0x39): undefined reference to `x265::setupIntrinsicDCT_ssse3(x265::EncoderPrimitives&)'
E:/MABS/msys64/mingw32/bin/../lib/gcc/i686-w64-mingw32/9.2.0/../../../../i686-w64-mingw32/bin/ld.exe: CMakeFiles/x265-shared.dir/objects.a(vec-primitives.cpp.obj):vec-primitives.cpp:(.text+0x4f): undefined reference to `x265::setupIntrinsicDCT_sse41(x265::EncoderPrimitives&)'
collect2.exe: error: ld returned 1 exit status
For a Win32 build, it fails only for the 8 bit precision library where assembler is used at all. For the Win64 build, it fails for all precisions as they all use assembler code.
Old 19th September 2019, 06:35   #7025  |  Link
aymanalz
Is it normal that x265 is about 20% slower on a Zen+ CPU than a Haswell, even though the Zen+ has a higher clock speed? I remember comments here about the AVX2 in AMD being only half as fast (?) as that in Intel, or something to that effect. Could that be the reason? Or could it be that the x265 developers haven't optimized the code for AMD as much as they have for Intel? It is a bit surprising, because this Zen+ architecture is from late 2018, a good few years later than Haswell.
aymanalz is offline   Reply With Quote
Old 19th September 2019, 08:46   #7026  |  Link
Yes, the lack of full speed AVX2 is definitely a big factor, x265 uses a lot of it. Zen2 of course "solved" that shortcoming.
Old 19th September 2019, 16:20   #7027  |  Link
NikosD
Right on both.
Zen+ has a slower implementation of AVX2 than Haswell onwards, but x265 is also optimized for Intel and favors Intel vs AMD.
Actually, Intel published a paper along with x265 developers working together for AVX-512 optimizations (Intel-only) but they didn't manage to succeed in this, AVX-512 is so ineffective for x265 that most of the times you have to disable it according to Intel, not me.
x265 is an Intel-friendly project but Zen 2 architecture and Ryzen 3000 series managed to be a lot faster in x265 and beat Intel in its own favorite H.265 encoder.
HEVC decoding benchmarks
H.264 DXVA Benchmarks for all
Old 19th September 2019, 20:14   #7028  |  Link
filler56789
SuperVirus
filler56789's Avatar
x265.exe 3.2_RC1+1-00d8df1b3bc6
(x64, multilib, GCC 9.2.0, upxed)
http://www.mediafire.com/file/k72pa2...b3bc6.rar/file
Old 20th September 2019, 13:52   #7029  |  Link
I borrowed the toolchain files from the CMake call in MABS, now it builds again.
Old 20th September 2019, 19:10   #7030  |  Link
mini-moose
The quotes on solved means they didn't solve it at all?
mini-moose is offline   Reply With Quote
Old 20th September 2019, 20:10   #7031  |  Link
Natty
Noob
no changelog for 3.2?
Natty is offline   Reply With Quote
Old 20th September 2019, 21:18   #7032  |  Link
MeteorRain
結城有紀
Means it wasn't really an issue. So usually you say they improved the performance.
Projects
x265 - Yuuki-Asuna-mod Download / GitHub
TS - ADTS AAC Splitter | LATM AAC Splitter | BS4K-ASS
Neo AviSynth+ filters - F3KDB | FFT3D | DFTTest | MiniDeen | Temporal Median
MeteorRain is offline   Reply With Quote
Old 20th September 2019, 22:50   #7033  |  Link
Stereodude
They made a huge improvement in performance. I don't know why he used the quotes.
Old 21st September 2019, 09:56   #7034  |  Link
Improvements in Zen2 architecture are huge!
Old 21st September 2019, 13:21   #7035  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Very interesting chart indeed.
Is there another one which includes AVX512 as well?
Old 22nd September 2019, 19:02   #7036  |  Link
RanmaCanada
AVX512 is currently Intel only, and is "completely useless" for x265 as it produces way too much heat for the results.
https://forum.doom9.org/showthread.php?t=175476
https://www.reddit.com/r/programming...wn_your_cpu_a/
RanmaCanada is offline   Reply With Quote
Old 23rd September 2019, 07:59   #7037  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Originally Posted by Boulder View Post
I tested HME some more, and got quite interesting results.
Source 1080p filtered with my standard methods and downsized to 720p, merange 26 and my standard settings in x265. 1000 frames.
umh,umh,umh 2.05 fps / 5313,76 kbps
umh,umh,star 2.24 fps / 5314,31 kbps
umh,star,star 2.00 fps / 5327,91 kbps
star,star,star 2.01 fps / 5316,15 kbps
hex,umh,umh 2.03 fps / 5299,69 kbps
no HME, umh 2.64 fps / 5323,86 kbps
no HME, star 2.79 fps / 5325,69 kbps
I've now upgraded to 3700X and ran a similar test with that. The order of the results is still the same.
Can any of the devs (or anyone else, of course) explain why the combination "umh, umh, star" is clearly the fastest one? Without HME, the star method is clearly faster so I would expect "star, star, star" to be the fastest one with HME.
Old 24th September 2019, 14:56   #7038  |  Link
mini-moose
How is me=3 (star) faster than me=2 (umh)? thought the higher --me is, the slower it's supposed to be, maybe I'm wrong, I'm not expert.
Also, HME, is that a good feature to use?
Old 24th September 2019, 15:22   #7039  |  Link
aymanalz
How is me=3 (star) faster than me=2 (uhm)? thought the higher --me is, the slower it's supposed to be, maybe I'm wrong, I'm not expert.
Based on all user reports I have read, star gives comparable or better quality to umh but is equally fast. I'd like to know the truth of this as well - could any knowledgeable person please tell me if this is right?
Is Star a better method than umh in terms of:
1) Quality
2) Speed
3) Quality and speed
I's also like to take this opportunity to point out that there is a dearth of easily understandable documentation for x265. By that, I mean something for dummies like me. There are so many elementary questions that I cannot find answers to, despite all my googling.
Old 24th September 2019, 18:25   #7040  |  Link
Boulder
Pig on the wing
Boulder's Avatar
There's something broken in the latest versions, I've now tried two different builds but both have the same problem.
y4m [info]: 1920x1080 fps 24000/1001 i420p16 sar 1:1 unknown frame count
raw [info]: output file: f:\temp\captures\testclip.hevc
Error: fwrite() call failed when writing frame: 4, plane: 0, errno: 32
Output 22 frames in 1.66 seconds (13.23 fps)
This is just by loading the source in a Vapoursynth script and feeding it to x265 with vspipe. Many other clips work just fine.
The clip that causes this one can be found here:
https://drive.google.com/open?id=1AU...FwqqFfOZLgNr4M
x265-3.1+14 works fine.
