Old 25th January 2018, 17:25   #41  |  Link
age
I've taken the formula for decomposing rgb to luma and come back(it gives different result from a classic rgb->yuv->rgb and it is faster) from here:https://www.google.it/amp/s/imdoingi...-blacks-3/amp/
The jhon hable tonemapping from here:http://filmicworlds.com/blog/filmic-...ing-operators/
age is offline   Reply With Quote
Old 25th January 2018, 19:36   #42  |  Link
jpsdr
... I'm still unable to see the whole mathematical formula path .
I also don't see any formula with exposed_bias in your links...
I have no idea what is the mathematical results of such things
tm = core.std.Expr(c, expr="x  {exposure_bias} * 0.15 x  {exposure_bias} * * 0.05 + * 0.004 + x  {exposure_bias} * 0.15 x  {exposure_bias} * * 0.50 + * 0.06 + / 0.02 0.30 / -  ".format(exposure_bias=exposure_bias),format=vs.RGBS)#12=1200 nits / 100 nits
w = core.std.Expr(c, expr="{exposure_bias} 0.15 {exposure_bias} * 0.05 + * 0.004 + {exposure_bias} 0.15 {exposure_bias} * 0.50 + * 0.06 + / 0.02 0.30 / -  ".format(exposure_bias=exposure_bias),format=vs.RGBS)#
c = core.std.Expr(clips=[tm,w], expr=" x  1 y  / *  ",format=vs.RGBS)
This is why, a "unrolled" explicit mathematical formula would be wonderfull...
I mean... Your script result in several mathematic formulas apllied step by step.
Is it possible to have the formula of each step ?
Old 25th January 2018, 21:56   #43  |  Link
ifb
I haven't looked at his script, but what you've quoted is the Hable operator from earlier in the thread. You can look at the VS plugin or ffmpeg if you want to see a C version.
https://github.com/ifb/vapoursynth-t.../tonemap.c#L44
ifb is offline   Reply With Quote
Old 26th January 2018, 09:55   #44  |  Link
jpsdr
Ok, i'll try to figure out things with all i have for now.
Old 27th January 2018, 10:40   #45  |  Link
jpsdr
I've tried to read again the BT.2100 and BT.2390.
I'm still confused.
I'm unable to relate the formulas of OETF, EOTF, OOTF functions with the formulas of the tonemap functions you've all provided in your links. Where from the BT.2100 and BT.2390 did you get the formulas of the tonemap functions (what page, chapter ) ?
I'm still unable to figure out where the "white max" information is involved in the OETF, EOTF, OOTF functions...
Old 27th January 2018, 19:40   #46  |  Link
age
EOTF and tonemapping are two different things, you could read about the st2084 formula in the official documentation or in the zimg code or elsewhere.
I've founded an interesting pdf about hdr and tonemapping
http://www.eusipco2016.org/documents...R_tutorial.pdf
at page 119 the EOTF formula.
At pages 100-107 some methods for the correction of the saturation.
From the first one I've done a vapoursynth function with only two parameters,(clip and source_peak)it's simple but at my eyes is better then my previous attempt
https://filebin.net/7c6kocrmxxnat1cp
import vapoursynth as vs
import tmsimple
core = vs.get_core()
c = core.ffms2.Source(source  = 'C:/.../testhdr.mkv')
c=core.resize.Bicubic(clip=c, format=vs.RGBS,filter_param_a=0.0,filter_param_b=0.75, range_in_s="limited", matrix_in_s="2020ncl", primaries_in_s="2020", primaries_s="2020", transfer_in_s="st2084", transfer_s="linear",dither_type="none", nominal_luminance=1000)
c=tmsimple.tm(clip=c,source_peak=1000)
c=core.resize.Bicubic(clip=c, format=vs.YUV420P8, filter_param_a=0.0, filter_param_b=0.75, matrix_s="709", primaries_in_s="2020", primaries_s="709", transfer_in_s="linear", transfer_s="709",dither_type="ordered")
c.set_output()
Old 28th January 2018, 14:18   #47  |  Link
jpsdr
Ok thanks, i'll read it.
Old 14th April 2018, 22:59   #48  |  Link
jkilez
Originally Posted by Magik Mark View Post
Is there a way to convert this to avisynth+?
There is now a tone-mapping plug-in for avisynth+: http://rationalqm.us/DGTonemap.rar
It supports both Hable and Reinhard methods.
jkilez is offline   Reply With Quote
Old 16th April 2018, 20:32   #49  |  Link
MonoS
Some times ago i wrote a c++ implementation of the hable implementation in tmap, i don't remeber how much faster it is, but IIRC about 2x .
It only works for float input with mod8 resolution video and AVX CPU, i didn't bother writing an SSE implementation due to the high amount of FMAD instruction used.
The static buffer optimization only work on windows right now.
If i see any interest in this i'll try to add some functionality like the debug views, non mod8 support, etc
Here the repo https://github.com/MonoS/tmap-vapoursynth/tree/V1
MonoS is offline   Reply With Quote
Old 2nd January 2019, 06:31   #50  |  Link
lansing
Japanese television recently launched their 4k/8k broadcasting last month, here's a same frame comparison between a 1080p HD version and the 4k HDR version:
1080p:
4K HDR:
note: delete the last letter ("h") on the image name to get the original size.
None of the three methods in the tonemap plugin I've tested can map the 4k one to look like 1080 one. They all failed on the color mapping.
Old 2nd January 2019, 07:27   #51  |  Link
poisondeathray
@lansing - does the original stream have metadata and parameters listed ? That can help guide what settings to use (or at least as a starting point)
Old 2nd January 2019, 08:58   #52  |  Link
lansing
Here's the sample clip, there's no metadata with the stream.
script I've tested:
rgb_clip = core.resize.Bicubic(clip, height=1080, width=1920, matrix_in_s="709", format=vs.RGBS)
# hable
tonemap_clip = core.tonemap.Hable(rgb_clip, exposure=7.0, a=0.10, b=0.50, c=0.10, d=0.20, e=0.01, f=0.08, w=5.2)
# mobius
tonemap_clip = core.tonemap.Mobius(rgb_clip, exposure=1.5, transition=0.9, peak=1.0)
#reinhard
tonemap_clip = core.tonemap.Reinhard(rgb_clip, exposure=1.5, contrast=0.5, peak=1.0)
The hable method is the only one that came close, but color are still off. The other two failed completely, as they have nothing to tweak.
Old 7th January 2019, 20:19   #53  |  Link
ifb
tonemap requires linear input and you still need to convert from 2020 to 709.
<edit>
I'm pretty sure it's HLG but with Rec.709 color, which is weird but I suppose they are worried about backward compatibility.
This is with zero tweaking, just copied from the tonemap examples:
c = core.ffms2.Source(source  = "4kbs_trim.mp4")
c = core.resize.Lanczos(clip=c, format=vs.RGBS,
                        width=1920, height=1080,
                        matrix_in_s="709",
                        transfer_in_s="std-b67", transfer_s="linear",
c = core.tonemap.Mobius(clip=c, exposure=4)
c = core.resize.Lanczos(clip=c, format=vs.YUV420P10, matrix_s="709",
                        primaries_in_s="709",  primaries_s="709",
                        transfer_in_s="linear", transfer_s="709")
Old 8th January 2019, 03:44   #54  |  Link
poisondeathray
It seems that the stream is actually SDR rather than HDR even though the resolution is 4K. By definition, HDR video should have at least 10-bit color depth. And the stream is encoded in AVC, not HEVC. AVC-encoded HDR video is very uncommon.
^ this
If the goal was to "match" the other version, I'd probably just use normal color manipulation filters .
Old 8th January 2019, 17:59   #55  |  Link
age
Hi :-)
I would like to use normal color manipulation filters too for this video.
I've made a.cube file for the sdr match.
https://filebin.net/uu8l2zh4xso2gqd2
c = core.lsmas.LibavSMASHSource(source= "C:/Users/..../4kbs_trim.mp4")
c=core.resize.Bicubic(clip=c, format=vs.RGB48, chromaloc_in_s="left", chromaloc_s="center", filter_param_a=0.0, filter_param_b=0.75, matrix_in_s="2020ncl",  range_in_s="limited",dither_type="none")
c=core.timecube.Cube(c, cube="C:/..../Videos/4kbshdr.cube")
c=core.resize.Bicubic(clip=c, format=vs.YUV420P8, chromaloc_in_s="center", chromaloc_s="left",matrix_s="709", filter_param_a=0.0, filter_param_b=0.75, range_in_s="full", range_s="limited",dither_type="none")
c.set_output()
Old 8th January 2019, 21:05   #56  |  Link
ifb
HLG has a different look ("natural" to use BBC/BT.2408 terminology) versus the "traditional" look of SDR. To convert, you need to do a scene-referred conversion, which is not exposed in z.lib/vapoursynth. You can patch z.lib and build your own custom vapoursynth.dll, but really you're just better off using a LUT like shown.
The BBC has some official .cube files they provide for doing this sort of thing.
Old 8th January 2019, 22:11   #57  |  Link
age
That video doesn't look hdr, but more like an hdr video converted to rec709 without tonemapping
for example with hable tonemapping for 1000 nits
c = core.lsmas.LibavSMASHSource(source= "C:/Users//Desktop/4kbs_trim.mp4")
c=core.resize.Bicubic(clip=c, format=vs.RGBS,filter_param_a=0.0,filter_param_b=0.75, range_in_s="limited", matrix_in_s="2020ncl",  chromaloc_in_s="left", chromaloc_s="center", transfer_in_s="709", transfer_s="linear",dither_type="none")
#insert here tonemapping 1000nits
#exposure_bias=10
#tm = core.std.Expr(c, expr="x  {exposure_bias} * 0.15 x  {exposure_bias} * * 0.05 + * 0.004 + x  {exposure_bias} * 0.15 x  {exposure_bias} * * 0.50 + * 0.06 + / 0.02 0.30 / -  ".format(exposure_bias=exposure_bias))
#w=((exposure_bias*(0.15*exposure_bias+0.10*0.50)+0.20*0.02)/(exposure_bias*(0.15*exposure_bias+0.50)+0.20*0.30))-0.02/0.30
#tm = core.std.Expr(clips=[tm,c], expr="x  1 {w}  / * ".format(exposure_bias=exposure_bias,w=w))
c=core.resize.Bicubic(clip=c, format=vs.RGBS, transfer_in_s="linear", transfer_s="709",dither_type="none")
c=core.resize.Bicubic(clip=c, format=vs.YUV420P8, chromaloc_in_s="center", chromaloc_s="left", filter_param_a=0.0, filter_param_b=0.75, range_in_s="full", range_s="limited", matrix_s="709",dither_type="none")
c.set_output()
it gives me this
Old 9th January 2019, 09:05   #58  |  Link
lansing
I think you're right, it turns out that the recorder has an older model 4K TV that doesn't support HDR, and the tv just converted it into something else.
Old 10th January 2019, 19:08   #59  |  Link
lansing
Ok after reading the hable reference article from ifb's tonemap page, I just realized that hable is not for 4k hdr tv to sdr conversion. It was created for images and SDR games to make them looks HDR. So this whole approach to use it for "4K HDR TV content -> SDR" is just wrong. The right tool for this in vapoursynth is DGHDRtoSDR.
Old 10th January 2019, 19:20   #60  |  Link
asarian
So, maybe you know a solution to my problem too. See: DGHDRtoSDR lacking in contrast
Which also makes me wonder, would there be a way for DGHDRtoSDR to extract values like 'Max luminance: 1000' from the metadata itself?
hdr, sdr
