10th December 2009, 03:27 | #6281 | Link |
I'm trying to rip blu-rays down to a size that I can live with. I've found that is in the 8-12 gb range per file. So far both 2 pass with 8 gb limit and CQ 20 usually meets that for me.
Can someone explain the main differences is between these two other than a hard limit with the 2pass? |
10th December 2009, 14:37 | #6283 | Link | |
Acid fr0g
@turment on Telegram |
10th December 2009, 17:33 | #6285 | Link | ||
10th December 2009, 18:04 | #6286 | Link |
@Atak
Well the reality is that I will be getting myself a Core i7 eXtreme come April or Max May 2010 ... Hope that will help a bit .. Now getting ready to encode Baraka ... Last night was a test on NBK (Natural Born Killers) ... And I must say I can't tell Original from encoded one ... BTW is it useful to use Trellis Enhanced or there is no difference ? Please answer me b4 I start 15 hour encode ... |
10th December 2009, 18:10 | #6287 | Link | |
11th December 2009, 15:01 | #6291 | Link | |
11th December 2009, 19:36 | #6292 | Link |
6 Channel Audio Fix
Atak,
I noticed that I was able to convert my X-men 3 Blu-ray and select 5.1 AC3 when using the new version of RipBot. Just finished converting the movie and the sound has come out all tinny. Picture is perfect but something happened with the conversion to 5.1 channel 640kbps AC3. Any ideas? Thanks |
11th December 2009, 22:37 | #6293 | Link | ||
12th December 2009, 05:39 | #6294 | Link |
Thanks Atak
Question for the Gurus: I've been encoding a lot of movies recently using Constant Quality (CQ). Why are the output results always so different for similar length movies. I've noticed that some movies create a 5gb 720p file on CQ 15 while others create a 9gb file on CQ 18? It's like some movies just compress MUCH better than others? Is there anything I can check beforehand to detect which ones will need a lower or higher CQ because I find myself re-encoding the same movie a lot using this option. I'm aiming for a 6GB 720 file. All my movies have a 640kbps audio track Thanks Last edited by jacksback; 12th December 2009 at 05:47. |
12th December 2009, 06:03 | #6295 | Link | |
1. The presence of many high-motion scenes, indicating an action film, versus other film genres. Think "The Matrix" versus your run-of-the-mill chick flick 2. Tricky source material, e.g. noisy/grainy picture. Think Darren Aronofsky's "Pi"! 3. Not exactly having to do with compressibility per se, but definitely affecting the file size you are targeting: Different video duration. You wouldn't expect encoding the extended cut of, say "The Return Of The King" to result in the same filesize with the normal cut, when using the same CQ value. There's a 50min difference
My hardware: +5 Holy Avenger 4.5ft overclocked@5.5ft, +2 mithril chainmail. Last edited by parsifal; 12th December 2009 at 06:06. |
12th December 2009, 07:03 | #6296 | Link | |
I might just go back to 2-pass then to guarantee output size |
12th December 2009, 08:11 | #6297 | Link |
all jobs finished
Hi
When I try to create a mkv file from a .264 file and one ac3 file using ripbot 1.14.5, I get a "All jobs finished" message imidiatly, but no file is produced. Why is that, and how do I fix it? I have also tried the latest version 1.14.6, but i get the same error. heres my job1_EncodeVideoPass1.cmd "E:\Apps\Rip BD To MKV\RipBot264v1.14.5\tools\x264\x264_x86.exe" "E:\temp\RipBot264temp\job1\job1.avs" --pass 1 --bitrate 8192 --stats "E:\temp\RipBot264temp\job1\job1.stats" --fps 24000/1001 --min-keyint 24 --keyint 240 --sar 1:1 --level 4.0 --aud --nal-hrd --vbv-bufsize 25000 --vbv-maxrate 25000 --filter 0,0 --ref 3 --bframes 3 --b-adapt 1 --direct auto --subme 7 --aq-mode 1 --trellis 1 --partitions all --me umh --output "E:\temp\RipBot264temp\video.264" job1_EncodeVideoPass2.cmd "E:\Apps\Rip BD To MKV\RipBot264v1.14.5\tools\x264\x264_x86.exe" "E:\temp\RipBot264temp\job1\job1.avs" --pass 2 --bitrate 8192 --stats "E:\temp\RipBot264temp\job1\job1.stats" --fps 24000/1001 --min-keyint 24 --keyint 240 --sar 1:1 --level 4.0 --aud --nal-hrd --vbv-bufsize 25000 --vbv-maxrate 25000 --filter 0,0 --ref 3 --bframes 3 --b-adapt 1 --direct auto --subme 7 --aq-mode 1 --trellis 1 --partitions all --me umh --output "E:\temp\RipBot264temp\video.264" job1_MuxFiles.cmd "E:\Apps\Rip BD To MKV\RipBot264v1.14.5\tools\mkvtoolnix\mkvmerge.exe" -o "E:\IceAge3.mkv" --title "IceAge3" --default-duration 0:24000/1001fps -d 0 -A -S "E:\temp\RipBot264temp\video.264" --language 0:und --sync 0:0 -a 0 -D -S "E:\iceage3demux\00386+00364.track_4360.dts" log file... E:\>"E:\Apps\Rip BD To MKV\RipBot264v1.14.6\tools\x264\x264_x86.exe" "E:\temp\RipBot264temp\job1\job1.avs" --pass 1 --bitrate 8192 --stats "E:\temp\RipBot264temp\job1\job1.stats" --fps 24000/1001 --min-keyint 24 --keyint 240 --sar 1:1 --level 4.0 --aud --nal-hrd --vbv-bufsize 25000 --vbv-maxrate 25000 --filter 0,0 --ref 3 --bframes 3 --b-adapt 1 --direct auto --subme 7 --aq-mode 1 --trellis 1 --partitions all --me umh --output "E:\temp\RipBot264temp\video.264" avis [error]: unsupported input format (DIB ) x264 [error]: could not open input file `E:\temp\RipBot264temp\job1\job1.avs' E:\>"E:\Apps\Rip BD To MKV\RipBot264v1.14.6\tools\x264\x264_x86.exe" "E:\temp\RipBot264temp\job1\job1.avs" --pass 2 --bitrate 8192 --stats "E:\temp\RipBot264temp\job1\job1.stats" --fps 24000/1001 --min-keyint 24 --keyint 240 --sar 1:1 --level 4.0 --aud --nal-hrd --vbv-bufsize 25000 --vbv-maxrate 25000 --filter 0,0 --ref 3 --bframes 3 --b-adapt 1 --direct auto --subme 7 --aq-mode 1 --trellis 1 --partitions all --me umh --output "E:\temp\RipBot264temp\video.264" avis [error]: unsupported input format (DIB ) x264 [error]: could not open input file `E:\temp\RipBot264temp\job1\job1.avs' E:\>"E:\Apps\Rip BD To MKV\RipBot264v1.14.6\tools\mkvtoolnix\mkvmerge.exe" -o "E:\IceAge3.mkv" --title "IceAge3" --default-duration 0:24000/1001fps -d 0 -A -S "E:\temp\RipBot264temp\video.264" --language 0:und --sync 0:0 -a 0 -D -S "E:\iceage3demux\00386+00364.track_4360.dts" mkvmerge v2.9.9 ('Tutu') built on Nov 25 2009 21:13:31 Error: The file 'E:\temp\RipBot264temp\video.264' has unknown type. Please have a look at the supported file types ('mkvmerge --list-types') and contact the author Moritz Bunkus <moritz@bunkus.org> if your file type is supported but not recognized properly. ------------------------- Elapsed Time: 00h:00m:02s please let me know if this information is enought to analyze what might be wrong. Last edited by magmo; 12th December 2009 at 14:59. Reason: new information added |
12th December 2009, 15:05 | #6298 | Link | |
@magmo use latest and show me also script
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 12th December 2009 at 15:07. |
12th December 2009, 15:28 | #6299 | Link |
7.1 -> 5.1 FLAC Audio
I use PS3 Media Server for streaming MKVs to my PS3. Unfortuntely, PS3 Media Server does not handle 7.1 correctly and mixes the channels up on playback. Is there a way to convert 7.1 to 5.1 FLAC?
Thanks. |
12th December 2009, 15:29 | #6300 | Link |
Hi Atak
Here's the log from the latest version... E:\>"E:\Apps\Rip BD To MKV\RipBot264v1.14.6\tools\x264\x264_x86.exe" "E:\temp\RipBot264temp\job1\job1.avs" --pass 1 --bitrate 8192 --stats "E:\temp\RipBot264temp\job1\job1.stats" --fps 24000/1001 --min-keyint 24 --keyint 240 --sar 1:1 --level 4.0 --aud --nal-hrd --vbv-bufsize 25000 --vbv-maxrate 25000 --filter 0,0 --ref 3 --bframes 3 --b-adapt 1 --direct auto --subme 7 --aq-mode 1 --trellis 1 --partitions all --me umh --output "E:\temp\RipBot264temp\video.264" avis [error]: unsupported input format (DIB ) x264 [error]: could not open input file `E:\temp\RipBot264temp\job1\job1.avs' E:\>"E:\Apps\Rip BD To MKV\RipBot264v1.14.6\tools\x264\x264_x86.exe" "E:\temp\RipBot264temp\job1\job1.avs" --pass 2 --bitrate 8192 --stats "E:\temp\RipBot264temp\job1\job1.stats" --fps 24000/1001 --min-keyint 24 --keyint 240 --sar 1:1 --level 4.0 --aud --nal-hrd --vbv-bufsize 25000 --vbv-maxrate 25000 --filter 0,0 --ref 3 --bframes 3 --b-adapt 1 --direct auto --subme 7 --aq-mode 1 --trellis 1 --partitions all --me umh --output "E:\temp\RipBot264temp\video.264" avis [error]: unsupported input format (DIB ) x264 [error]: could not open input file `E:\temp\RipBot264temp\job1\job1.avs' E:\>"E:\Apps\Rip BD To MKV\RipBot264v1.14.6\tools\mkvtoolnix\mkvmerge.exe" -o "E:\IceAge3.mkv" --title "IceAge3" --default-duration 0:24000/1001fps -d 0 -A -S "E:\temp\RipBot264temp\video.264" --language 0:und --sync 0:0 -a 0 -D -S "E:\iceage3demux\00386+00364.track_4360.dts" mkvmerge v2.9.9 ('Tutu') built on Nov 25 2009 21:13:31 Error: The file 'E:\temp\RipBot264temp\video.264' has unknown type. Please have a look at the supported file types ('mkvmerge --list-types') and contact the author Moritz Bunkus <moritz@bunkus.org> if your file type is supported but not recognized properly. ------------------------- Elapsed Time: 00h:00m:01s |
