18th April 2017, 10:16 | #3262 | Link |
https://sourceforge.net/projects/ope...20and%20Win64/
But 1.78 is included in the usual avisynth+ binary package. |
18th April 2017, 13:26 | #3265 | Link |
Just a thought... why not have the Info() function return everything as a string instead of overlaying it onto a clip, with potential problems involving the clip resolution and text size. The user could then modify it and manually subtitle it into the video using more easily visible styling or colors.
You could add a bool parameter "return_string" or something, false by default. |
18th April 2017, 15:01 | #3266 | Link | |
yup. |
18th April 2017, 15:17 | #3268 | Link | |
EDIT: Further request, how about allowing YUV color of eg $008080 for both LetterBox and Addborders. (for masks)
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 18th April 2017 at 18:04. |
18th April 2017, 17:51 | #3270 | Link | |
19th April 2017, 11:24 | #3271 | Link | |
ConvertToYV24() works with the old logo size of 90x 55px, perfect. For the rest I don't know what what happened, feeling silly, probably mixed up some stuff or messed up somewhere when copying old avs parts of code i used before, had in mind it always worked before but nope, don't know what happened with my brain. Thanks again. |
19th April 2017, 12:33 | #3272 | Link | |
Also, it still doesn't let you modify the info string, which I find unnecessary and feels like an easy fix (could be wrong, not a programming guru). |
19th April 2017, 23:51 | #3273 | Link | ||
Retried Guesser
Oct 2016 Avisynth Plus Quick reference guide Nov 2016 New functions Apr 2017 AVS 2.60 vs. AVS+ r2455 (Are there other good resources? I'd like to know about them.) Reel.Deel said he was starting a new documentation site; I don't know what's happening with it. Quote:
20th April 2017, 04:27 | #3274 | Link |
Soul Architect
There isn't just an issue with ScriptClip, but also with ConditionalFilter
vid = AviSource("file") vid_blur = vid.Blur(1.5) ConditionalFilter(vid, vid_blur, vid, "AverageLuma()", "lessthan", "20") Prefetch(2) Since these are purely internal filters, nothing prevents you from having AverageLuma as a local function called by ConditionalFilter instead of trying to handle it as a separate special plugin.
FrameRateConverter | AvisynthShader | AvsFilterNet | Natural Grounding Player with Yin Media Encoder, 432hz Player, Powerliminals Player and Audio Video Muxer Last edited by MysteryX; 20th April 2017 at 05:09. |
20th April 2017, 08:04 | #3275 | Link | |
I was already practicing a bit on editing things on avisynth wiki pages, I have updated the masktools sections, worked a bit on mvtools and other references of my plugin updates. But I still need help on the new function pages, at least to have a good hierarchy and dummy skeleton article pages to be fill up. At the moment Avisynth+ has only one dedicated page on wiki. I'd better not put all the readme stuff there as a flat section. Nor I want to edit the filter section of the classic Avisynth pages. If someone would create a good (even dummy) layout for the new functions, it would help a lot on bringing the knowledge base online. |
20th April 2017, 08:33 | #3276 | Link |
Retried Guesser
Personally, I'd like to see an AVS+ Infobox on each classic filter page, explaining the differences in some standardized form. Something similar in appearance to the "Abstract" box currently seen on external filter pages like MaskTools2.
>If someone would create a good (even dummy) layout for the new functions, it would help a lot on bringing the knowledge base online. I really don't feel like working on a site that is about to be made obsolescent by a fork site. (If you didn't know, I have been one of the very few active content contributors there - I have made hundreds of edits, maybe thousands. The only other users that active are Reel.Deel and Wilbert, the administrator of the site. So that 'someone' would probably be me.) EDIT okay, I'm reconsidering my position. Whatever Reel.Deal does or doesn't do, I will begin (oh god) the rather large task of documenting AVS+ on the mainstream Avisynth wiki, as time permits. Crudely at first, as you describe. And as always, subject to Wilbert's approval. Last edited by raffriff42; 21st April 2017 at 14:14. |
22nd April 2017, 05:01 | #3277 | Link |
Soul Architect
When I build Avisynth+ from the Pinterf's source, I get this error when opening a script:
Avisynth open failure: Script error: There is no function named 'Prefetch'. What's going on here? btw, there is code here that doesn't compile (Visual Studio 2017) because of 'y' being defined several times. It's easy to fix, you just have to rename the 2nd 'y'. focus.cpp - af_horizontal_yuy2_c |
22nd April 2017, 17:40 | #3279 | Link | |
22nd April 2017, 17:49 | #3280 | Link |
Btw, I have to mention another news from the past weeks; with the patient help of qyot27, we were able to successfully compile the project with gcc (under Linux but not for Linux, which was a nightmare and a hard learning curve for me, thanks again qyot27). I don't know if this is good or not, we are by far not on par with Vapoursynth's multiplatform design and I guess we'll never be.
