Old 27th June 2007, 11:18   #21  |  Link
SealTooGreat
buzzqw, what is mp4creator's cmd line for muxing raw h264 -> mp4?
SealTooGreat is offline   Reply With Quote
Old 27th June 2007, 12:25   #22  |  Link
buzzqw
HDConvertToX author
first of all mencoder create an avi file with h264 and aac
then mplayer is invoked to demux
mplayer.exe movie.avi -dumpaudio -dumpfile audio.aac
mplayer.exe movie.avi -dumpvideo -dumpfile video.h264
then mp4creator is used
mp4creator.exe create=audio.aac audio.mp4
mp4creator.exe create=video.h264 -rate=framerate_of_file audio.mp4
the audio.mp4 is now the full file remuxed, i renamed it to movie.mp4
BHH
HDConvertToX: your tool for BD backup
MultiX264: The quick gui for x264
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
buzzqw is offline   Reply With Quote
Old 27th June 2007, 12:49   #23  |  Link
SealTooGreat
I was asking cause "-h" switch gives:
-create=<input-file>    Create track from <input-file>
    input files can be of type: .263 .aac .amr .mp3 .divx .mp4v .m4v .cmp .xvid
I wasn't sure if h264/raw is even supported.
buzz, thanx!
Old 27th June 2007, 21:51   #24  |  Link
DIEGO7-5
Hi buzz!
I really like this tool! Does mencoder have native deinterlacing and if so will AutoMEN support it in a future version?
DIEGO7-5 is offline   Reply With Quote
Old 28th June 2007, 08:09   #25  |  Link
buzzqw
HDConvertToX author
mencoder have a lots of deinterlacer /itvc ... cababilities..
the main problem is the detection
i could add a simple list and user select the deinterlace pattern... but i want a better solution.. if any
BHH
Old 28th June 2007, 10:35   #26  |  Link
buzzqw
HDConvertToX author
http://www.64k.it/andres/data/a/AutoMen04.exe
added deinterlacer selection (user choice)
fixed ffhuffy encoding
change the behavior of P button, now play the queue or just the dragged&dropped input file, it also play it with the requested width/autocrop and also apply the deinteralcer requested (for better analysis)
BHH
Old 28th June 2007, 11:11   #27  |  Link
DIEGO7-5
WOW That was fast!
Thank you very much :-)
Old 28th June 2007, 23:21   #28  |  Link
Hyper_Thread
Hyper_Thread's Avatar
little issue with format's tooltips
Thanks a lot for this useful app.
Hyper_Thread is offline   Reply With Quote
Old 29th June 2007, 06:44   #29  |  Link
buzzqw
HDConvertToX author
ops.. you are right!
http://www.64k.it/andres/data/a/AutoMen05.exe
thanks!
BHH
Old 29th June 2007, 17:41   #30  |  Link
buzzqw
HDConvertToX author
update 0.6
fixed mov->mpeg2 conversion when dealing with ntsc source
BHH
Old 11th July 2007, 07:24   #31  |  Link
DIEGO7-5
Hi buzz!
When i set final file size to 175MB (encoding to XVID) i get a final size of 195MB every time. Is the audio not taken into filesize calculation?
Thanks for your time.
Old 11th July 2007, 07:31   #32  |  Link
buzzqw
HDConvertToX author
audio bitrate is valuated but is encoded in ABR mode...
are you using 2 pass profile ?
BHH
Old 11th July 2007, 07:40   #33  |  Link
DIEGO7-5
Yes i am, using the highest quality preset and i have set the audio bitrate to 128. When i drop the final file on gSpot, the video is 173MB and the audio is 18MB.
I suppose i can not edit the commandline automen is passing to mencoder because the xvids i create with it dont play well with my standalone player. I need to set packed bistream & adaptive quantization but thatīs another question.
Old 11th July 2007, 08:05   #34  |  Link
buzzqw
HDConvertToX author
launch encoding... then stop it at start
open xvid.bat and edit it...
BUT here the new version http://www.64k.it/andres/data/a/AutoMen07.exe
changelog:
added: volume normalization
added: new resize method (secret fuction)
fixed: removed nopacked from xvid (obsolete)
fixed: some tweak to xvid bitrate
BHH
Old 13th July 2007, 00:14   #35  |  Link
dansus
Hey nice work, you just made my life that little bit easier.
I look forward to future revisions.
dansus is offline   Reply With Quote
Old 13th July 2007, 17:29   #36  |  Link
buzzqw
HDConvertToX author
well.. the project is open to suggestions
feel free to post ideas
BHH
Old 13th July 2007, 20:32   #37  |  Link
dansus
Dont know much about mencoder but custom matrices if it applies. I encode motor racing (mpeg2>x264), so a fast motion option would be good for me at least.
Priority changer.
Also auto res at 688 is showing 688x376, which isnt divisible by 16. Its telling me that compression will suffer.
Old 13th July 2007, 21:28   #38  |  Link
buzzqw
HDConvertToX author
the resize is computed by mencoder and guarantee the exact AR
376 is MOD8.. so is good enough
priority ?.. i will look!
about matrix... isn't so automatic... i will think about
BHH
Old 14th July 2007, 18:12   #39  |  Link
CruNcher
CruNcher's Avatar
Nice project, how about self defineable presets
maybe you shuld rename the options selections like this H.264 (AVI),H264 (MP4), H.264 (PSP), XviD (AVI),XviD (MP4) or first the Video Encoder,Audio Encoder and then the Container format that would work for the combination (mencoders restrictions as smart dropdowns) chosen by the user and maybe even make the user aware of the choices he has for a given combination (comon sense decissioning) and then select/editable profiles for the Encoder tools, so something like SUPER but more advanced (and with a cleaner interface)
It is about Time
Old 14th July 2007, 19:58   #40  |  Link
buzzqw
HDConvertToX author
well.. nice suggestions.. but for a new program !
this project will be as simple as is now
maybe in summer's holiday i will get time for a more complete gui
BHH
automen, ffmpeg, handbrake, mencoder, x264
