6th September 2016, 08:58 | #24861 | Link |
Your initial mp4 muxing failure is most probably due to the fact that .dts audio is not officially supported in mp4 container, means one has to re-encode the .dts audio to ac3 or AAC, i.e. one cannot leave the source .dts audio intact for the mp4 container.
8th September 2016, 10:55 | #24862 | Link |
how to get higher performance in X265? .please a good tweak for 6 core / 12 threads.
http://x265.readthedocs.io/en/default/cli.html |
9th September 2016, 14:18 | #24864 | Link |
I looked it up. It says there is a subscript out of range at location 2408 (a progress indicator I created for debugging) as it is processing secondary video tracks. That is very old code (it hasn't changed in years). I suspect you have a corrupted source.
What disc are you processing? |
9th September 2016, 14:25 | #24865 | Link | |
http://www.blu-ray.com/movies/Whats-...lu-ray/128616/ |
13th September 2016, 18:39 | #24875 | Link |
BD Rebuilder process fails every time
I hope this is the proper forum for this.
It seems I've broken BD Rebuilder. It worked previously but now It fails every time. Not sure if it's related but I recently installed Handbrake to shrink an MKV file. Not satisfied with the result I uninstalled it. It was about that time that BD Rebuilder began to fail. I'm hoping someone may spot something in the logs that I am missing. Any assistance is greatly appreciated. Thanks BD Rebuilder log: ---------------------- [09/05/16] BD Rebuilder v0.50.16 [10:16:35] Source: SOME_MOVIE - Input BD size: 27.00 GB - Approximate total content: [01:40:04.248] - Target BD size: 23.83 GB - Windows Version: 6.2 [9200] - Quality: Highest (Very Slow), Two Pass - X264 Tweak(s) enabled - Decoding/Frame serving: X264/LAVF - Audio Settings: AC3=1 DTS=1 HD=1 Kbs=640 [10:16:35] PHASE ONE, Encoding - [10:16:35] Processing: VID_00000 (1 of 1) - [10:16:35] Extracting A/V streams [VID_00000] - [10:20:28] Reencoding video [VID_00000] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 143,958 frames - Bitrate: 29,703 Kbs - [10:20:28] Reencoding: VID_00000, Pass 1 of 2 - Encode failed. Aborting. - BD-Rebuilder v0.50.16 - Windows Version: 6.2 [9200] - Working Path Free Space: 95.19GB - AVISYNTH Version: 2.6.0.6, Ok - LAVFILTERS: Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [11:12:22] - Failed video encode, aborted Windows Event Viewer Log: ---------------------- + System - Provider [ Name] Windows Error Reporting - EventID 1001 [ Qualifiers] 0 Level 4 Task 0 Keywords 0x80000000000000 - TimeCreated [ SystemTime] 2016-09-05T15:12:22.046248400Z EventRecordID 16606 Channel Application Computer HTPC Security - EventData 120537450342 4 APPCRASH Not available 0 x264-64.exe 0.148.2705.0 576f9adc x264-64.exe 0.148.2705.0 576f9adc c0000005 000000000091cdff C:\Users\Johnny\AppData\Local\Temp\WERBF2.tmp.WERInternalMetadata.xml C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCrash_x264-64.exe_9aad892177b7c08477676f6e20ccac69f991473_e446d3cd_37811be9 0 01208a6e-0cad-4a33-8dcc-b6ba9843d32b 0 6f1a9ecb78749acaff4819408aeda8ac SOME_MOVIE.INF: ---------------------- [Status] LABEL=SOME_MOVIE VERSION=v0.50.18 SOURCE_SIZE=28993344520 SOURCE_VIDEO_SIZE=28993259520 TARGET_SIZE=24641536000 REDUCTION=.849902750085824 RESIZE_1080=0 RESIZE_1440=0 AUDIO_TO_KEEP=eng; KEEP_HD_AUDIO=-1 SUBS_TO_KEEP=eng; BACKUP_MODE=0 MOVIEONLY_TYPE=0 USE_LAVF=-1 INSTANCES=1 DGDECNV=0 DGDECIM=0 FRIMSOURCE=0 FFMS2=0 SSIF_MODE=0 QUICK=0 ENCODE_STEP=2 [00000] AUDIO=1 PGS=1 APULLDOWN=0 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=24641451000 RATE=28534 SPLITS=1 |
13th September 2016, 19:39 | #24876 | Link |
@ Rad10act1v3 RE: I hope this is the proper forum for this.
It seems I've broken BD Rebuilder. I can't think of any other forum to go to either. IF you search this forum you will see countless times this has happened to others. Unfortunately the only solution that is always recommended is to completely uninstall BD_Rebuilder and then do the reinstall using the "First Page" instructions. I wish there was a simpler way to do all that but this does usually give you a working BD_Rebuilder again. |
13th September 2016, 21:37 | #24878 | Link | |
Not exactly. Neither of you both seem to have caught that he modified the log
14th September 2016, 15:24 | #24879 | Link | |
For clarification
First of all, thanks so much for the quick responses, but it seems I didn't provide enough info. I used "SOME_MOVIE" as as a generic term encompassing many attempts with many different movies, all of which play with TMT 5 or PowerDVD 12, as either an ISO or when extracted to a folder.
I have uninstalled/reinstalled everything related to BD Rebuilder, video and audio, including my drivers. I have deleted the BD_Rebuilder folder, downgraded to a previous (50.16) version and still it fails. I can't remember if I downgraded AVISynth from 2.60 to 2.57 so I guess I'll give that a try. I'm using the Quote:
I've tried everything and am now considering reinstalling Windows. I can post DXdiag info if needed. I was hoping I just had setting conflict. Again, thanks for the support. |
14th September 2016, 16:27 | #24880 | Link | |
