Old 29th September 2018, 15:15   #341  |  Link
mood
gpower2, 2.3.0 language track detect on file name not work, example: now its [eng], not _eng_
the _eng_ not detect by mkvtoolnix 27 only [eng]
example 1: music_track1_chi_DELAY 30ms.aac not detect language
example 2: music_track1_[chi]_DELAY 30ms.aac language is detected
mood is offline   Reply With Quote
Old 29th September 2018, 16:00   #342  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
You can change the regular expression MKVToolNix uses for recognizing track languages in the file name in MKVToolNix GUI's preferences. The following should recognize _xxx_, too:
[[({.+=#_-](<ISO_639_1_CODES>|<ISO_639_2_CODES>|<LANGUAGE_NAMES>)[])}.+=#_-]
Latest MKVToolNix is v83.0
Mosu is offline   Reply With Quote
Old 29th September 2018, 16:04   #343  |  Link
gpower2
gMKVExtractGUI author
gpower2's Avatar
It's not a recent change in gMKVExtractGUI, I guess that it never really worked in MKVToolNix and no one ever bothered to report it! :P
It's an easy and quick fix, I'll have it ready for the next version.
Thanks for the feedback!
gpower2 is offline   Reply With Quote
Old 12th October 2018, 12:02   #344  |  Link
gaak
2.3.0 Problem
Version 2.3.0 doesn't appear to produce .ogm.txt files. You get the success message but no file.
gaak is offline   Reply With Quote
Old 12th October 2018, 16:27   #345  |  Link
manolito
manolito's Avatar
Cannot reproduce your issue here.
Maybe your MKV has problems. What happens after you import your MKV into the current version of MKVToolNix and remux it?
Cheers
manolito
Old 12th October 2018, 23:49   #346  |  Link
gaak
It was an MKV produced with Handbrake 1.1.2. gMKVExtractGUI version 2.2.0 worked. I guess I'll stay with 2.2.0 because most of my work requires the use of Handbrake and I don't want to go through having to remux everytime. Thanks for your help.
Old 13th October 2018, 01:59   #347  |  Link
manolito
manolito's Avatar
Tried to reproduce the issue with an MKV created by Handbrake 1.1.2, but I couldn't...
gMKVExtractGUI 2.3.0 created OGG chapters just fine, maybe you should upload an MKV which shows the problem...
Old 13th October 2018, 03:55   #348  |  Link
x3inspire
Hi im using gMKVExtractGUI, currently the sub output is like this:
SubName S01E01_track3_und
Where can i setting to make the output only display SubName S01E01 without "_track3_und" or subtitle output same as video name?
x3inspire is offline   Reply With Quote
Old 13th October 2018, 14:14   #349  |  Link
gaak
I found it. It's not putting it in the source directory that I have checked or selected, it's putting it in "C:\gMKVExtractGUI\Files" under where the execs are. What size am I limited to for the upload?
Old 13th October 2018, 15:01   #350  |  Link
manolito
manolito's Avatar
You should not use forum attachments as it can take ages until they get approved. Use a file hoster like SendSpace instead...
Old 14th October 2018, 04:15   #351  |  Link
x3inspire
Hi, any answer please?
Old 14th October 2018, 19:07   #352  |  Link
videoh
Useful n00b
Settings are described in the documentation. You can check the documentation to see if your requirement is supported.
Old 14th October 2018, 23:26   #353  |  Link
manolito
manolito's Avatar
I can reproduce the issue. It only happens if the target folder has some special characters like spaces in its name. Looks like gpower2 forgot to enclose the target folder with double quotes...
By videoh:
Looks like this software comes without any documentation...
Not every software developer is as thorough as you are when it comes to writing proper documentation...
Cheers
manolito
Old 15th October 2018, 08:18   #354  |  Link
x3inspire
Wilbert
Where is the setting? The output still display include "_track3_eng"
Old 15th October 2018, 12:40   #355  |  Link
hello_hello
It's better that it does, otherwise if you extracted multiple subtitles from the same MKV, they'd have the same name.
MKVCleaver lets you modify the extracted file names, but if you don't use settings that allow each extracted stream to have a unique name, the first stream of a particular type will probably be over-written when the next one is extracted, if they're extracted together.
Old 15th October 2018, 13:48   #356  |  Link
hello_hello
Back when suggesting MKVToolNix apply languages codes was evidence of a mental condition, I thought it'd be a nice idea for everyone to get together and decide on a format for writing and reading language names/codes. Zathor kindly modified MeGUI so it'd write delays MKVToolNix could understand, and I think he added an ability pick up 3 letter language codes when muxing raw streams, and the author of MKVCleaver made the extracted file names configurable, but it's still a bit messy.
There's not exactly hundreds of freeware programs for extracting/muxing MKVs, so I would've thought it'd be easy to settle on a format that everyone understands, and supporting others would be at the discretion of the software author. I still think some sort of standard for writing language names/codes would be a good thing.
Old 15th October 2018, 16:45   #357  |  Link
gpower2
gpower2's Avatar
Wow guys, haven't had this many comments in years!
Sorry for not answering earlier, but real life is quite busy for me.
I'll look into this matter as soon as possible. It's definitely not the file's fault...
Cheers
manolito
I don't think that this software requires any kind of documentation, it's just a GUI for a CLI tool...
It's a feature that is not supported and that is the reason that you can't find any relevant option for it.
It may or may not be supported in future versions...
This issue is already resolved in trunk, since the problem was the "[]" characters and not the language code itself.
Old 15th October 2018, 18:46   #358  |  Link
videoh
Useful n00b
My bad.
BTW, I have decoded my first frame from an MKV in DGIndex. Lots more work to do though.
Old 15th October 2018, 19:30   #359  |  Link
manolito
manolito's Avatar
Old 19th October 2018, 02:29   #360  |  Link
Intervencion
Also having the chapters' issue with files with spaces.
Thanks for your work
Intervencion is offline   Reply With Quote
extractor, gmkvextractgui, matroska, mkv, mkv extract, mkvextract, mkvextractgui
