24th July 2018, 00:28 | #6264 | Link |
Zathor,
I tried outputting an MP4 due to a question in another thread, and discovered when the aspect ratio is 15:11, or when 10:11 is set as the SAR in the encoder configuration (and the resolution is 720x480), MeGUI uses 8:9 as the PAR when muxing. Here's an example encoder command line followed by the muxing job from MeGUI's log file: "C:\Program Files\MeGUI\tools\x264\x264.exe" --keyint 300 --sar 10:11 --frames 201 --output "D:\test.264" "D:\test.avs" "C:\Program Files\MeGUI\tools\mp4box\mp4box.exe" -add "D:\test.264#trackID=1:fps=29.97:par=8:9:name=" -tmp "D:" -new "D:\test.mp4" As a quick test I tried 64:45 for a SAR and it was also used for muxing, but when I set 20:11 as the display aspect ratio for anamorphic encoding, a SAR of 40:33 was correctly used for encoding, but the generic par of 32:27 was used when muxing. "C:\Program Files\MeGUI\tools\x264\x264.exe" --keyint 300 --sar 40:33 --frames 201 --output "D:\test.264" "D:\test.avs" "C:\Program Files\MeGUI\tools\mp4box\mp4box.exe" -add "D:\test.264#trackID=1:fps=29.97:par=32:27:name=" -tmp "D:" -new "D:\test.mp4" I tried a couple of non-standard aspect ratios and the SAR used for encoding and the PAR used for muxing were fairly close. To a couple of decimal places. All of the above tests were for a video with a 720x480 resolution. Last edited by hello_hello; 24th July 2018 at 00:48. |
29th July 2018, 13:47 | #6267 | Link |
Have you tried the suggestions found here?
https://forum.doom9.org/showthread.p...78#post1845778 In any case I need more details = your log file. |
3rd August 2018, 15:44 | #6270 | Link |
Was there a reason for the change in the "File Indexer" that the output file directory no longer updates according to the input file directory?
When I was doing a series, I broke up each episode into their own sub directory so that each episode's work files were all separate. So when I wanted to load a bunch of episodes into the indexer, I would load the input, hit queue, load the next input, hit queue, rinse and repeat. Now, when I want to load a series, I have to make sure the output file is set to where the input file is and it adds in a bunch of tedious steps. I liked it better before it was changed, when the output would update itself each time I loaded the input file. |
4th August 2018, 16:28 | #6271 | Link |
21 years and counting...
Hi.
Any chance the GUI to the x265 encoder will get more options to set? Right now I have to set qpfiles manually to the command line. Would love to have an option to do this just with a few clicks. |
12th August 2018, 17:22 | #6274 | Link | |
i have avisynth 2.6 on my system and all plugins work when i use avisynth the things is that like the msg is with not comprehensive caracters i can't find the problem |
12th August 2018, 17:29 | #6275 | Link |
Finally, useful details: apparently, LoadPlugin got an utterly wrong plugin name string ... and now please also publish the log file of this job, so we can inspect more details.
By the way: To get a screenshot of only the active window, press Alt-PrtScr. Last edited by LigH; 12th August 2018 at 17:36. |
12th August 2018, 19:05 | #6276 | Link |
Preliminary log file only. During closing of MeGUI the well formed log file will be written.
-[Information] Versions --[Information] MeGUI: 2836 x86 --[Information] Update Check: stable update server -[Information] Operating System: Windows 7 Professional x64 SP1 (6.1.65536.7601) -[Information] .NET Framework: 4.0 (4.0.0.0) -[Information] .NET Framework: 4.7 (4.7.03062) -[Information] DPI: 100% (96/96) -[Information] Resolution: 1600x900 -[Information] Primary Screen: True -[Information] Monitor 1 --[Information] System Information -[Information] Update detection -[Information] Haali Media Splitter: 1.13.138.14 (14-04-2013) -[Information] Haali DSS2: not installed -[Information] ICSharpCode.SharpZipLib: 0.85.5.452 (07-08-2008) -[Information] MediaInfo: 18.03.1.0 (26-03-2018) -[Information] SevenZipSharp: 0.64.3890.29348 (02-01-2011) -[Information] 7z: 9.20 (18-11-2010) --[Information] Component Information --[Information] [12/08/2018 18:18:42] Using cached update config and server: http://megui.org/auto/stable/ -[Information] Version: 1.0.2721.0 -[Information] Date: 29-04-2017 -[Information] Interface: 3 -[Information] AviSynth Wrapper -[Information] File Version: 2.6.0.6 -[Information] Date: 31-03-2015 -[Information] Name: Avisynth 2.6 --[Information] [12/08/2018 18:18:42] No package requires an update -[Information] Version: AviSynth 2.60, build:Mar 31 2015 [16:38:54] -[Information] AviSynth+: false -[Information] MT: false -[Information] Status: active -[Information] AviSynth -[Information] File Version: 0.1 -[Information] Date: 28-03-2018 -[Information] Name: AviSynth+ 0.1 (r2664, MT, i386) -[Information] Status: inactive -[Information] AviSynth portable --[Information] AviSynth Information -[Information] AVS Script Creator -[Error] Unhandled error --[Information] [12/08/2018 18:20:19] Exception message: Object reference not set to an instance of an object. -[NoImage] at MeGUI.AviSynthWindow.finishedAnalysis(SourceInfo info, Boolean error, String errorMessage) -[NoImage] at MeGUI.SourceDetector.finishProcessing() -[NoImage] at MeGUI.SourceDetector.Process(String scriptBlock) -[NoImage] at MeGUI.SourceDetector.<>c__DisplayClass29_0.<runScript>b__0() -[NoImage] at System.Threading.ThreadHelper.ThreadStart_Context(Object state) -[NoImage] at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) -[NoImage] at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) -[NoImage] at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) -[NoImage] at System.Threading.ThreadHelper.ThreadStart() --[Information] [12/08/2018 18:20:19] Stacktrace --[Information] [12/08/2018 18:20:19] Inner exception: null |
12th August 2018, 19:45 | #6277 | Link |
Please read the first line of this log file. The required workflow is as follows: Start MeGUI. Provoke this bug. Close all dialogs and MeGUI. Then post the log file when it is finished after closing MeGUI.
Optional: If you are able to find the generated *.avs script which was used to test for interlacing but failed, provide it as well; but I guess it may have been deleted by MeGUI right after. Please use a CODE block to separate the log from the normal posting, and to format it with a monospaced font (or use an external "pastebin" service for very long logs). |
12th August 2018, 20:17 | #6278 | Link |
i open megui load the d2v, then click sur analysis but as i have two error window (those i show before), then i can't close megui it crash himself so it's all i have, it's been few weeks i have this error,
the best i get is that , no avs, nothing Code:
[Error] Log -[Information] Versions --[Information] MeGUI: 2836 x86 --[Information] Update Check: stable update server --[Information] System Information ---[Information] Operating System: Windows 7 Professional x64 SP1 (6.1.65536.7601) ---[Information] .NET Framework: 4.0 (4.0.0.0) ---[Information] .NET Framework: 4.7 (4.7.03062) ---[Information] DPI: 100% (96/96) ---[Information] Monitor 1 ----[Information] Resolution: 1600x900 ----[Information] Primary Screen: True --[Information] Component Information ---[Information] Haali Media Splitter: 1.13.138.14 (14-04-2013) ---[Information] Haali DSS2: not installed ---[Information] ICSharpCode.SharpZipLib: 0.85.5.452 (07-08-2008) ---[Information] MediaInfo: 18.03.1.0 (26-03-2018) ---[Information] SevenZipSharp: 0.64.3890.29348 (02-01-2011) ---[Information] 7z: 9.20 (18-11-2010) --[Information] AviSynth Information ---[Information] AviSynth Wrapper ----[Information] Version: 1.0.2721.0 ----[Information] Date: 29-04-2017 ----[Information] Interface: 3 ---[Information] AviSynth ----[Information] File Version: 2.6.0.6 ----[Information] Date: 31-03-2015 ----[Information] Name: Avisynth 2.6 ----[Information] Version: AviSynth 2.60, build:Mar 31 2015 [16:38:54] ----[Information] AviSynth+: false ----[Information] MT: false ----[Information] Status: active ---[Information] AviSynth portable ----[Information] File Version: 0.1 ----[Information] Date: 28-03-2018 ----[Information] Name: AviSynth+ 0.1 (r2664, MT, i386) ----[Information] Status: inactive -[Information] Update detection --[Information] [12/08/2018 21:16:30] Using cached update config and server: http://megui.org/auto/stable/ --[Information] [12/08/2018 21:16:30] No package requires an update -[Information] AVS Script Creator -[Error] Unhandled error --[Information] [12/08/2018 21:16:57] Exception message: Object reference not set to an instance of an object. --[Information] [12/08/2018 21:16:57] Stacktrace ---[NoImage] at MeGUI.AviSynthWindow.finishedAnalysis(SourceInfo info, Boolean error, String errorMessage) ---[NoImage] at MeGUI.SourceDetector.finishProcessing() ---[NoImage] at MeGUI.SourceDetector.Process(String scriptBlock) ---[NoImage] at MeGUI.SourceDetector.<>c__DisplayClass29_0.<runScript>b__0() ---[NoImage] at System.Threading.ThreadHelper.ThreadStart_Context(Object state) ---[NoImage] at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) ---[NoImage] at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) ---[NoImage] at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) ---[NoImage] at System.Threading.ThreadHelper.ThreadStart() --[Information] [12/08/2018 21:16:57] Inner exception: null |
13th August 2018, 05:29 | #6280 | Link | |
Select the preset you want to rename, click the "new" button, give it a new name and click okay. It'll save with the existing settings and then you can select the old preset and delete it. |
