Old 2nd January 2010, 06:41   #6461  |  Link
Blackwalker
Blackwalker's Avatar
thx a lot atak for the new version!
and happy new year!
Blackwalker is offline   Reply With Quote
Old 2nd January 2010, 08:57   #6462  |  Link
Clownzer
Originally Posted by pacaveli211 View Post
what is your end goal clownzer? if you're going to be playing it on a bluray player you need to keep full 1280x720 or 1920x1080
pacaveli,
My end result would be a 720P compliant video that I would stream to my tv using my WDTV. I probably will never burn these movies per say but if the option did come up I would like to be able to.
I noticed that if I did crop the borders the resolution does drop, then if I use the resize settings the borders are readded, is this by design?
Clownzer
Clownzer is offline   Reply With Quote
Old 2nd January 2010, 15:33   #6463  |  Link
lecatpuke
Hmm... on my first attempt with 1.15.0, I noticed a much different result than 1.14.6:
1. I use eac3to to demux BD video and audio into .mkv and .dts.
2. If the video is AVC, I use mkvtoolnix to merge them into an mkv.
3. If the video is VC-1, I use RipBot264 to re-encode the video to AVC with a COPY STREAM of the audio, muxed into an mkv.
Normally RipBot264 with a CQ=18 will produce a near 1:1 size/bitrate and quality copy of the video. With 1.15, however, it decreased the bitrate from 21.2Mbps to 4.2Mbps. Same 4.0 profile, same CQ=18, same stream copy for audio. What's changed?
Edit--Here's my attached EncodeVideoPass1.cmd:
"D:\Download\DVD\BLURAY\RipBot264\tools\avs2yuv\pipebuf.exe"
"D:\Download\DVD\BLURAY\RipBot264\tools\avs2yuv\avs2yuv.exe"
"F:\temp\RipBot264temp\job1\job1.avs" -raw - :
"D:\Download\DVD\BLURAY\RipBot264\tools\x264\x264_x64.exe"
--crf 18 --stats "F:\temp\RipBot264temp\job1\job1.stats"
--fps 24000/1001 --min-keyint 24 --keyint 240 --frames 140624
--sar 1:1 --level 4.0 --aud --nal-hrd --vbv-bufsize 25000
--vbv-maxrate 25000 --filter 0,0 --ref 3  --bframes 3
--b-adapt 1  --direct auto --subme 7 --aq-mode 1 --trellis 1
--partitions all --me umh
--output "F:\temp\RipBot264temp\video.264" - 1920x1080 : 2
lecatpuke is offline   Reply With Quote
Old 2nd January 2010, 15:52   #6464  |  Link
Balthazar2k4
Since changing to 1.15 the automatic crop option is no longer working. Has anyone else noticed this or did I do something to my configuration by accident?
Balthazar2k4 is offline   Reply With Quote
Old 2nd January 2010, 16:08   #6465  |  Link
soneca
Here is working as before.
Old 2nd January 2010, 16:16   #6466  |  Link
Balthazar2k4
Hmmm, thanks, I guess I have done something to break it....
Old 2nd January 2010, 16:55   #6467  |  Link
pacaveli211
Originally Posted by Clownzer View Post
pacaveli,
Clownzer
yes, the resize auto adds the borders to preserve the AR (you wouldn't want to stretch a 2.35 to 1.78). if you want to crop and resize you may want to see if you can use the custom resize. I'm re-encoding right now so I can't check any of those options to see if it might work =\. Keep in mind if you do crop the letterbox bars off that it won't be compliant with bluray players and will have to be readded if you want to burn it as a bluray / avchd. if it doesn't seem to properly allow you to do the custom resize with the crop you may have to run it through twice to achieve the desired results
pacaveli211 is offline   Reply With Quote
Old 2nd January 2010, 18:12   #6468  |  Link
Furiousflea
Hi there...
Could we have an option to NOT downmix to 16bit all audio streams?
The Popcorn Hour C-200 can player 24bit FLAC, at the moment I'm using eac3to on the audio to get a 24bit FLAC audio track and then muxing the video output of Ripbot264.
I know I asked before but this was before the Popcorn Hour C-200 was upgraded with FLAC audio support, it's becoming quite popular standalone player so would make sense imo.
Furiousflea is offline   Reply With Quote
Old 3rd January 2010, 19:02   #6469  |  Link
mark133
No "X COPY STREAM" anymore Help!
Hi all,
I have built a new Win 7 64 bit machine and now I never get the option of "X COPY STREAM" on the audio just the "AFTEN 5.1" the "DTS-MA" was extracted of the disk.
Always used to get the "X COPY STREAM" on my vista build.
Any Ideas
mark133 is offline   Reply With Quote
Old 3rd January 2010, 19:14   #6470  |  Link
pacaveli211
I've run 7 x64 for months and I always have the copy option
Old 3rd January 2010, 19:21   #6471  |  Link
mark133
Originally Posted by mark133 View Post
Hi all,
Any Ideas
I installed the latest ripbot and was wondering if there was something else i hadnt installed that allows the "X COPY STREAM" to be availble as an option?
Cheers
Old 3rd January 2010, 22:31   #6472  |  Link
gohamstergo
What type of audio is present? You said someting about DTS-MA earlier. you cant copy stream that (at least its never worked for me). Has to be flac or downmixed to 5.1 DTS
gohamstergo is offline   Reply With Quote
Old 4th January 2010, 00:10   #6473  |  Link
DOWNFALL
i have found the bit rate is alot lower on version 1.15 vs 1.14. this is using profile 4.0 cq18, i normal expect a file about 12gb but im getting then about 4-6gb??
Another i just read a few posts ago that another user has had this same issue, is this meant to be the case?? or is this an error of some description??
DOWNFALL is offline   Reply With Quote
Old 4th January 2010, 01:58   #6474  |  Link
Adub
Fighting spam with a fish
Adub's Avatar
This is probably due to the update in the X264 executable. X264 had some internal changes that affected the way CRF values are applied. All you have to do is lower your CRF value until you reach a form of quality that is comparable to your older encodes.
FAQs:Bond's AVC/H.264 FAQ
Site:Adubvideo
Adub is offline   Reply With Quote
Old 4th January 2010, 02:12   #6475  |  Link
lecatpuke
I posted with the same issue earlier. Originally I used CRF=18 to get close to a 1:1 bitrate from VC-1 to AVC, but until someone hashes out the change to x264, I'm going to use 2-pass settings with the desired bitrate set to the original bitrate.
Old 4th January 2010, 07:38   #6476  |  Link
archer75
Is ripbot able to grab just the forced subs and build those in the image?
It would also be nice to get 24bit FLAC. I don't understand the reason for downmixing it to 16bit?
archer75 is offline   Reply With Quote
Old 4th January 2010, 07:49   #6477  |  Link
sifulee
Hi I'm having a problem with mkv's and ac3 audio. I'm converting some tru-blood eps to mp4 to play on my ipod and everything goes great with no errors. The problem is that i have no sound after the first 50 secs or so. After its shows what happened on the previous episode I get no sound. I don't know what the problem is but the original works find in mpc.
In the ripbot temp folder it has the audio.acc file which is the same way. There is a 2_audio_Undeterminded.ac3 file in the job1 folder. I'm assuming thats the ac3 file that was demuxed from the original mkv. I'm using the latest ripbot. I've tried several eps and have the same problem with all of them. Can someone anyone help? I've search for answers but not having any luck. I've been trying to figure this out for days now. I'm not sure what I need to post so that you can understand whats going on but here are a couple of files.
Here is the job1.ini:
[JobSettings]
VideoFile=E:\Backup\Movies\True BloodS02 MKV\True.Blood.S02E08.720p.HDTV.X264-DIMENSION.mkv
VideoCodec=h264
VideoWidth=1280
VideoHeight=720
VideoAspectRatio=16:9
VideoProfile=[BASE 1.3] Custom
SourceFPS=23.976
MovieFPS=23.976
FPSinGUI=23.976
SourceNumberOfFrames=77917
SourceMovieLength=3249.79145812479
CurrentMovieLength=3249.79145812479
SourceAudioLength=3249.856
Frames=77917
Duration=0:54:9.791
Mode=CQ
kbps=18
AudioFile=E:\temp\RipBot264temp\job1\2_audio_Undetermined.ac3
AudioFileSize=155993088
AudioCodec=ac3
AudioBPS=384000
AudioProfile=2.0 CT AAC-LC 128 kbps [abr]
Frequency=48000
Channels=2
DurationAudio=0:54:9.856
Normalize=200%
AudioDelay=0
AudioLang=Undetermined [und]
Output=C:\Users\SiFu Lee\Desktop\TB0208.mp4
Container=mp4
LockSize=0
Size=447
Deinterlace=Do not deinterlace
Crop=Do not crop
CropTop=0
CropBottom=0
CropLeft=0
CropRight=0
Resize=iPOD 320x240 [1,78:1]
ResX=320
ResY=180
Decimate=Do not decimate
Colors=Do not change colors
hue=0
sat=1
bright=0
cont=1
subtitles=Do not use subtitles
subtitleFileSize=0
path=
Denoise=Do not denoise
AssumeFPS=Do not change
Here is the mkvinfo.txt:
+ EBML head
|+ Doc type: matroska
|+ Doc type version: 1
|+ Doc type read version: 1
+ Segment, size 1565476934
|+ Seek head (subentries will be skipped)
|+ EbmlVoid (size: 4027)
|+ Segment information
| + Timecode scale: 1000000
| + Muxing application: libebml v0.7.8 + libmatroska v0.8.1
| + Writing application: mkvmerge v2.4.0 ('Fumbling Towards Ecstasy') built on Nov 7 2008 17:24:23
| + Duration: 3249.856s (00:54:09.856)
| + Date: Mon Aug 10 03:45:01 2009 UTC
| + Segment UID: 0x5e 0x7c 0xfd 0xa0 0xf2 0x23 0xf4 0xec 0x5b 0xc4 0xf2 0x14 0xa2 0x5b 0xe9 0x0c
|+ Segment tracks
| + A track
| + Track number: 1
| + Track UID: 1
| + Track type: video
| + Enabled: 1
| + Default flag: 1
| + Forced flag: 0
| + Lacing flag: 0
| + MinCache: 1
| + Timecode scale: 1
| + Max BlockAddition ID: 0
| + Codec ID: V_MPEG4/ISO/AVC
| + Codec decode all: 1
| + CodecPrivate, length 40
| + Default duration: 41.708ms (23.976 fps for a video track)
| + Language: eng
| + Video track
| + Pixel width: 1280
| + Pixel height: 720
| + Interlaced: 0
| + Display width: 16
| + Display height: 9
| + A track
| + Track number: 2
| + Track UID: 3250602745
| + Track type: audio
| + Enabled: 1
| + Default flag: 1
| + Forced flag: 0
| + Lacing flag: 1
| + MinCache: 0
| + Timecode scale: 1
| + Codec ID: A_AC3
| + Default duration: 32.000ms (31.250 fps for a video track)
| + Language: und
| + Audio track
| + Sampling frequency: 48000
| + Channels: 2
|+ EbmlVoid (size: 1024)
|+ Cluster
I'm using Windows 7 64 bit. I tried this in Xp and have the same problem. I'm able to upload the original mkv if needed.
Thanks for any help.
sifulee is offline   Reply With Quote
Old 4th January 2010, 07:53   #6478  |  Link
pacaveli211
it can build subtitles into a picture
Old 4th January 2010, 08:01   #6479  |  Link
archer75
Yes, I know that. But will it, when it rips the movie and processes the subs with bdsup2sub, grab just the FORCED subs and build those in?
Forced subs we need. All the rest of the english subs(for english speaking people) we don't need.
Typically I rip with eac3to and then I take all the english subs I ripped and open them in bdsup2sub. It tells you if there are any forced. If there are then you export just the forced and import the idx file into mkvmerge(or build them in the image with ripbot). Then you get just the forced and none of the other subs you don't need.
Old 4th January 2010, 09:46   #6480  |  Link
Ajax_Undone
I dont care so should you
Ajax_Undone's Avatar
OK the installer has been updated. you can catch it in my signature...
My Installer's ||
Ajax_Undone is offline   Reply With Quote
