24th April 2010, 20:29 | #7522 | Link |
May I ask about ripbot and different ver of x264
I only use your program atak and sometimes BDRebuilder,BDRebuilder will not let you put anything other than BDMV files and will not let you keep HD audio unless you do a BD-25,but I do get faster encodes with it,the difference is BDrebuild uses me-hex and ripbot uses me-umh,which is best? Everything is the same on default settings except the me-xx above and a couple other things like keyint 24 and keyint min-1 for BDreb and keyint-240 and keyint min-24 in RipBot 1.15.1.Does this have anything to do with time and quality?The only other thing is rc-lookahead ripbot is 40 and BDreb is 24,all these are default settings.
Last night I changed the x264.exe's to the latest ver for both x264_x64.exe and the x264_x86.exe and put them in the tools in ripbot264.Is this OK to do or should I leave the one you put in when you updated ripbot, Atak? I'm wondering if I screwed anything up,I have Windows 7 x64 Ultimate,Phenom II 965BE AM3 cpu oc 3.8 and Corsair DDR3 XMS3 1600 memory 4GB's.Most the time it takes about 5hrs with both programs.When i use yours I only encode the movie file(no audio)then remux the Hd audio back in with tsmuxer.It took me 7.5 hrs last night, this is a couple hrs out of the norm,should I put the x264.exe's you had in there,or does this matter.Thanks for your program,It has helped save loads of room on my hard drives and keep great quality. stin |
24th April 2010, 22:09 | #7523 | Link | |||
keyint 24 and keyint min-1 http://www.mediafire.com/file/ylydyz522mk/24.mkv keyint [fps*10] and keyint [fps] http://www.mediafire.com/file/znm0ht2zznz/240.mkv Quote:
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 24th April 2010 at 22:12. |
24th April 2010, 23:57 | #7524 | Link |
x2, i verry like the simple and great design of ripbot264 program. I have tried a lot of h264 gui and this is the most easier and simple to configure and use.
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. |
25th April 2010, 00:03 | #7526 | Link |
Thank You Atak for your answers
Thanks for the input, and the links for knowledge. I wish I knew how to use x264 from the command line.My Bluray backups always look good.I didn't state that the BDrebuilder back-up I was comparing with was a default BD-5,not sure what it is in BD-9.I had Ripbot set at 7168 bit rate,2 pass because I was going for around 8GB (no audio). The file was 28GB with DTS-MA ,it was 3.47GB.In all I ended with a 11GB HD movie that is as good as the orginal.Thanks!
stin |
25th April 2010, 16:53 | #7530 | Link |
.ini
is there documentation on what all can be pre-selected in the interface by a setting in RipBot264.ini or are the default settings in there the only ones that are recognized? for example would be helpful for me to have automatically pre-selected all subtitles to demux in the bottom pulldown, and after demux automatically set audio to aften 640, set normalize none and crop automatic.
25th April 2010, 21:44 | #7532 | Link | |||
@thebasa whole documentation is in ripbot264.ini Quote:
1) in order to set ffdshow as preffered directshow decoder in windows 7. 2) in order to register missing filters Above tasks could be done by installer (Nevertheless Admin privileges also would be required) but I prefer simpler solutions like .7z file
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 25th April 2010 at 21:46. |
26th April 2010, 17:09 | #7533 | Link |
I hate asking for new features - this is an excellent program and I really appreciate all the effort you've already put into it. I don't want to add to your troubles, but I'd like to ask for something that would be useful.
I wonder if it would be possible to have options to keep the existing audio extract and another option to keep the existing first pass data? My workflow is to usually try a single pass, CQ encode first. I then take a look at it and if it looks good and if it will fit on a DVD, I'll keep it. If it looks bad I'll either go to a 2-pass encode or try a better CQ encode. Every time I rerun a Ripbot job, it goes through the creating audio phase, even when the existing audio is fine. The problem with a 2-pass encode is that it takes a long time. Sometimes I need to shut down my computer in the middle of a 2nd pass. When I restart the computer, I need to go back to the beginning again - wasting an hour or two. I usually get around this 2-pass problem by running the CMD files created in the job directory, but this seems a little unsafe to me. Thanks, Tim |
26th April 2010, 20:46 | #7534 | Link | |
Click
27th April 2010, 04:35 | #7536 | Link |
AppleTV AC3 track
Hi all, just wondering if and how people are encoding 720p content with AAC + AC3 DD for the AppleTV as RipBot doesn't seem to have an option for that that I can find. Do you mux the AC3 track in with some other tool after encoding the h264+AAC with RipBot?
Thanks for any tips.. |
27th April 2010, 10:48 | #7537 | Link |
@TheAncientEvil
RipBot-Folder -> Tools -> tsmuxer -> tsMuxerGUI.exe 1. click on "add" and ADD the finished h264+AAC-file wich RipBot generated 2. click on "add" and ADD the AC3-Track 3. Select the Format on the "Output" and click on "Start Muxing" |
27th April 2010, 16:38 | #7539 | Link |
Problem with VC1 sources
Czesc, Atak!!!
I've been using your tool for a while, and its great, but I have been observing a couple of things that bother me, maybe you can throw me a hand: 1) The PSP profile from 1.14.1 worked for me without problems. But the latest version (1.15.1) has some changes to it that make sometimes the video to "dissolve", like when a codec doesnt have enough bitrate to present the picture, but uglier. Im guessing some x264 option newly introduced (could be even before, 1.14.6) that doesn't always work good on the PSP. Im talking firmware 5.03, you can understand why I wouldnt go higher in this Any option I could turn off? I tried several, but no luck. 2) The second thing bothers me more: Every time I have a VC1 source, I feel a delay in the ripbot generated file. Sometimes its so obvious that is not OK to keep the file. Later I examine the source, and the source goes OK, no delay or anything. The weird thing is, its not constant, its more noticeable in some scenes that others. For example, Nico - Above The Law original UK Bluray: Starts nice, everything in place.About 40 minutes later, you can feel some delay. Around 15 minutes later, a milisecond more. And in the end, everything goes fine again. My setup: Windows 7 64 bit, Ripbot 1.14.1 and 1.15.1 (for testing) ffdshow set to ffmpeg-mt for AVC, set to WMV9 for VC1 MakeMKV for copying from original blurays to HDD. -NOTE: I tried the demo anydvd to see if the untouched M2TS file did the same, and it did, so I dont think its a problem of container. Keep up this great work. Pozdrowienia!!!!!! Last edited by harrystruman; 27th April 2010 at 16:40. |
27th April 2010, 17:31 | #7540 | Link | ||
