24th January 2018, 16:22 | #15461 | Link |
Does the same problem appear if you map shared folder on some PC?
24th January 2018, 16:26 | #15463 | Link |
1) share some folder. for example C:\temp\ripbot264temp
2) map that location to drive letter like you did before 3) check if you see mapped location in ripbot
24th January 2018, 17:34 | #15466 | Link |
M$ has implemented some weird behaviour in win10. If application is run as administrator then mapped location is hidden. If you run the same .exe as regular user then mapped network location shows up!
Application run as administrator Application run normally
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 24th January 2018 at 17:41. |
24th January 2018, 19:53 | #15469 | Link | |
https://www.easeus.com/storage-media...t-showing.html Reboot after changing the key. I suspect that some programs are affected by this based on what tools/libraries they where compiled with. I also have a machine that boots so fast, that I need to open up windows explorer and click on my drives before Ripbot264 will see them. |
24th January 2018, 21:40 | #15470 | Link | |
If you are a user and not THE administrator, then when you run a job as administrator, then you only see the mapped network drives, that was mapped with the user Administrator. So let say you have created a user that is not the admin, but have admin rights. Then when you Run As Administrator it sees the network drived mapped when the administrator was logged in and not the current user. I dont know if this was the intention by M$ as its pretty wierd. Solution: log in as the administrator and map the drive and then log in as your user and use the run as administrator, then you should see the network drive. At better solution is just BE the administrator if you are the only user on the computer then you dont have to use the Run As option. |
25th January 2018, 11:59 | #15472 | Link | |
Single threaded resizer (Spline36Resize) replaced with multithreaded Spline36ResizeMT. My tests https://forum.doom9.org/showthread.p...60#post1831560
25th January 2018, 23:03 | #15473 | Link | |
28th January 2018, 15:15 | #15475 | Link |
10bit Hardcode Subtitltes
So I've been working Atak to find some kind of solution to hardcode/render subtitles for 10bit video. Unfortunately I have not found anything yet that will work. Someone posted that it works with Staxrip so I was going to go through and find out how they are doing it.
The recommendation by some were to render the subtitles using vsfilter's MaskSub property. From what I understand sot far, I would have to create the full movie length render sub over alpha and then do another encode and lay it over the film that I'm encoding. My avisynth knowledge is very poor and I've only been digging into this stuff lately. From what I gather, avisynth+ has better support for 10bit but it is not a drop in replacement and it would probably take Atak a lot of work to implement (maybe for version 1.3?) I'm wondering if anyone else has ideas on how to render subtitles for 10bit video that I have not discovered yet. |
28th January 2018, 20:52 | #15476 | Link | |
added support for hardcoded subtitles using VapourSynth for srt, ass, idx/vobsub, sup/pgs I'll dig into that and see if that can be plugged into the avisynth script. From what I've just briefly read, it seems that VapourSynth is a replacement for avisynth. |
29th January 2018, 15:59 | #15477 | Link | |
Version 1.21 and 1.22 and windows 10
Will you please try your latest versions on windows 10. Version 1.20 works fine, but 1.21 and 1.22 refuse to encode mpeg2 video on any windows 10 machine. All I get is green video. I have tried it on 5 win10 machines. Even using windows7 compatibility mode does not work. Since version 1.20 works fine, it must be a problem with the newer versions and not a problem with Windows 10. Please fix this. |
29th January 2018, 20:02 | #15478 | Link | |
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 29th January 2018 at 20:15. |
29th January 2018, 20:55 | #15479 | Link | |
30th January 2018, 17:25 | #15480 | Link | |
Silent Reader
@Atak_Snajpera:
I have a strange problem since some encodes. Muxing fails, because there is no audio file. Quote:
When encoding to *.mkv with other codecs, all is fine. BUT! While encoding, AAC-File is created. And while RB still encodes Video, AAC (ready encoded) still exists and can be played without issues. After muxing (with error) there is no AAC-File anymore. So it must be deleted after encoding of audio and before shutdown (after job is finished). Last encode I enabled write-protection after AAC-encode finished and this time muxing completed without errors. I haven't changed anything at running system except automated CU of Windows10. Other possible cause could be update of RB. Edit: Now am encoding a film with dtsma (preconverted to flac with ripbot) and destination mp4 with aac: flac-file is there and plays fine, but this time no aac is created, no aac-encoding task in taskmanager. Last edited by Wishbringer; 30th January 2018 at 17:41. |
