Old 2nd June 2016, 11:09   #24301  |  Link
Tenker
Originally Posted by Tenker View Post
@jdobbs
I find your software super
and want for converting video files into one * .H264 fixed bit rate of
- 10000 kbps avg Bitrate
- and without creating the BD structure
So I need at the end of the conversion ONLY * .H264 file.
Can I edit something to achieve this?
Thank you and best regards
tenker
FOUND -> but how do I change the bit rate to 10000 kbps?
Found -> ...\BD_Rebuilder\Misc\alternate.txt
Still, I have a question.
When set
° "Automatically crop black borders"
My video was cut to 1920 x 600 instead of 1920 x 800th
How to manually change the setting so that the result of 1920 x 800?
tenker
Tenker is offline   Reply With Quote
Old 2nd June 2016, 15:12   #24302  |  Link
varekai
Originally Posted by gamete View Post
But jdobbs write
"If you installed HAALI/FFDSHOW< Setup VC-1 decoding in the same way you did MPEG-2 in step 2B. For Vista or Windows 7+ using "Video Decoder Configuration" -- select "wmv9".
So for win7 i must set VC1 "libavcodec" like a mpeg2 or wm9 ?
THANKS
Set VC1 to wmv9!
Old 2nd June 2016, 18:54   #24303  |  Link
mparade
When set
tenker
Do not use "Automatically crop black borders" if it does not work for you.
Use this one in the avs filter editor and the job is done, but please make sure your source does not have an alternate aspect ratio like e.g. Interstellar, otherwise you will cut off the video where you do not want to.
Crop(0, 140, -0, -140)
P.S.
and do not forget to delete from the avs editor after the encode is complete otherwise you will cut off your future encodes as well....
Old 3rd June 2016, 02:55   #24304  |  Link
MrVideo
MrVideo's Avatar
Dbut please make sure your source does not have an alternate aspect ratio like e.g. Interstellar, otherwise you will cut off the video where you do not want to.
In case this is mis-understood, this mostly applies to movies specifically released for IMAX, where a portion of the movie is shot with IMAX aspect ratio equipment and that IMAX aspect ratio is kept in the IMAX Blu-ray edition.
A little off topic, but IMHO, IMAX is not really IMAX anymore. When they were projecting 70mm-15perf, the perceived pixel width was in the order of 12K. The digital projectors are only 4K. They should be at least 8K. That still presents an issue since the highest digital cameras used for movie recording is 6K (Gods of Egypt).
There are times when I am watching an IMAX movie at an IMAX theater, I can see the pixels. And I do not sit close to the screen. Some of you reading this might not know that IMAX screens used to be larger. I call today's IMAX screens, minIMAX.
Old 3rd June 2016, 07:39   #24305  |  Link
gamete
Originally Posted by varekai View Post
Set VC1 to wmv9!
Ok thanks
Mpe2 is correct in libavcodec ?
gamete is offline   Reply With Quote
Old 3rd June 2016, 08:04   #24306  |  Link
varekai
Ok thanks
Yes, correct!
Old 3rd June 2016, 08:05   #24307  |  Link
gamete
Yes, correct!
Old 6th June 2016, 21:19   #24308  |  Link
q90g0H5R
Different Backup Modes
I'm quite new around here, but I played a little bit with BD Rebuilder lately, and stumbled across some oddities, which I can't classify if they are bugs, or by design...
First:
Different Backup Modes use completely different parameter sets.
What do do I mean?
If I select Movie-Only Backup, then the DTS tracks are reencoded although the DTS_REENCODE=0 option is set.
If I select Movie&Menus, then the algorithm which is controlled by the MIN_M2TS_SIZE option is not triggered at all. It looks like if the option was set to MIN_M2TS_SIZE=0.
Another very odd thing about Backup-Modes is, that the mode is not saved with a project (.epr file): If I set up a project as full backup, save it, change the backup mode to Movie&Menus and reload the saved project, then the resulting selection list is a complete mess.
q90g0H5R is offline   Reply With Quote
Old 6th June 2016, 22:28   #24309  |  Link
mparade
Braveheart
Has anyone an idea what can cause this?:
[06.06.16] BD Rebuilder v0.50.14
[22:40:29] Source: BRAVEHEART_F4
- Input BD size: 37,12 GB
- Approximate total content: [03:04:01.697]
- Target BD size: 46,26 GB
- Windows Version: 6.2 [9200]
- Quality: Ultra-High (Extremely Slow), Two Pass
- X264 Tweak(s) enabled
- Output folder: D:\OUTPUT\
- Decoding/Frame serving: FRIMSource
- Audio Settings: AC3=1 DTS=1 HD=0 Kbs=192
[22:40:29] PHASE ONE, Encoding
- [22:40:29] Processing: VID_00007 (1 of 5)
- [22:40:29] Extracting A/V streams [VID_00007]
- [22:40:34] Reencoding video [VID_00007]
- Rate/Length: 23,976fps, 24 frames
- [22:40:34] Reencoding: VID_00007, Pass 1 of 1
- [22:40:36] Video Encode complete
- [22:40:36] Processing audio tracks
- [22:40:36] Multiplexing M2TS
- [22:40:40] Processing: VID_00004 (2 of 5)
- [22:40:40] Extracting A/V streams [VID_00004]
- [22:40:44] Reencoding video [VID_00004]
- [22:40:44] Reencoding: VID_00004, Pass 1 of 1
- [22:40:45] Video Encode complete
- [22:40:45] Processing audio tracks
- [22:40:45] Multiplexing M2TS
- [22:40:49] Processing: VID_00006 (3 of 5)
- [22:40:49] Extracting A/V streams [VID_00006]
- [22:40:53] Reencoding video [VID_00006]
- Rate/Length: 23,976fps, 168 frames
- [22:40:53] Reencoding: VID_00006, Pass 1 of 1
- [22:40:55] Video Encode complete
- [22:40:55] Processing audio tracks
- [22:40:55] Multiplexing M2TS
- [22:40:59] Processing: VID_00005 (4 of 5)
- [22:40:59] Extracting A/V streams [VID_00005]
- [22:41:03] Reencoding video [VID_00005]
- Rate/Length: 23,976fps, 192 frames
- [22:41:03] Reencoding: VID_00005, Pass 1 of 1
- [22:41:24] Video Encode complete
- [22:41:24] Processing audio tracks
- [22:41:25] Multiplexing M2TS
- [22:41:28] Processing: VID_00003 (5 of 5)
- [22:41:28] Extracting A/V streams [VID_00003]
- Extracting video streams [VID_00003]
- Extracting secondary video [VID_00003]
- Extracting audio streams [VID_00003]
- Error in attempt to extract audio/subs.
- Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps. File name: D:\BD-50\2D\BRAVEHEART_F4\BDMV\STREAM\00003.m2ts
[22:48:51] - Failed to retrieve audio, aborted
Old 6th June 2016, 23:23   #24310  |  Link
gonca
@mparade
Bad (corrupt) source
Try re-ripping,cleaning etc
Old 6th June 2016, 23:28   #24311  |  Link
mparade
@mparade
I will try it and let you know the results, THX.
Old 7th June 2016, 00:04   #24312  |  Link
q90g0H5R
The times you got dizzy because of the sheer height of screen and the steep of the rows... dreaming...
Old 7th June 2016, 00:48   #24313  |  Link
Originally Posted by q90g0H5R View Post
First:
What do do I mean?
Read the BD-RB FAQ (second post) for more information on audio logic.
Old 7th June 2016, 01:25   #24314  |  Link
q90g0H5R
Thanks; thought I read it - but missed the OVERRIDE_AVCHD_AUDIO_LIMIT=1
... one riddle solved, two to go...
Old 7th June 2016, 04:06   #24315  |  Link
Lathe
Lathe's Avatar
That specific part is what I come across when I try using TSMuxer on a file where if you carefully check the FPS of the Video track, it usually shows a weird number like '90,000' FPS. When that happens, I click the dropdown menu for the Video track and 'change FPS' to what it SHOULD be (24000-0001, etc)
I don't know if that applies to the rip you have...
Old 8th June 2016, 01:54   #24316  |  Link
MrVideo
MrVideo's Avatar
As mentioned, the minIMAX screen are not a large. It was nice when they were really big.
Old 8th June 2016, 01:55   #24317  |  Link
MrVideo
MrVideo's Avatar
I hope you really mean 24000/1001.
Old 8th June 2016, 02:44   #24318  |  Link
Lathe
Lathe's Avatar
Yeah, yeah...
Old 8th June 2016, 02:58   #24319  |  Link
AmigaFuture
AmigaFuture's Avatar
I have just sacrificed a virgin, and am now casting the Summoning Spell to bring back Toilet Duck...
You do realize that incorrect understanding of Pagan traditions? On the Other hand....WHY?! WHY!? Give her to ME!! Teehee...Oh, damn, then I have to train her.. Never mind, have at. (Snnnicker!)
You're a mess, Lathe. Glad you're here!
Old 8th June 2016, 05:18   #24320  |  Link
Lathe
Lathe's Avatar
Originally Posted by amigafuture View Post
you do realize that incorrect understanding of pagan traditions? On the other hand....why?! Why!? Give her to me!! Teehee...oh, damn, then i have to train her.. Never mind, have at. (snnnicker!)
you're a mess, lathe. Glad you're here!
