Old 11th August 2019, 21:53   #28701  |  Link
Michi
I have problems with the UHD Mary Queen of Scots:
[08.11.19] BD Rebuilder v0.60.20
[19:00:44] Source: MARYQUEENOFSCOTS_UPK2
- Input BD size: 89,97 GB
- Approximate total content: [02:37:33.068]
- Target BD size: 46,26 GB
- Windows Version: 6.2 [9200]
- Quality: Good (Fastest, BD-25+), ABR
- Decoding/Frame serving: FFMPEG
- Audio Settings: AC3=0 DTS=0 HD=1 Kbs=448
[19:00:45] PHASE ONE, Encoding
- [19:00:45] Processing: VID_00000 (1 of 8)
- [19:00:45] Extracting A/V streams [VID_00000]
- [19:00:54] Reencoding video [VID_00000]
- Source Video: HEVC, 3840x2160
- Rate/Length: 23,976fps, 5.725 frames
- Bitrate: 21.614 Kbs
- [19:00:54] Reencoding: VID_00000, Pass 1 of 1
- [19:06:41] Video Encode complete
- [19:06:41] Processing audio tracks
- [19:06:41] Multiplexing M2TS
- [19:07:00] Processing: VID_00001 (2 of 8)
- [19:07:00] Extracting A/V streams [VID_00001]
- Extracting video streams [VID_00001]
- Extracting secondary video [VID_00001]
- Extracting audio/subtitle streams [VID_00001]
- [19:26:24] Reencoding video [VID_00001]
- Rate/Length: 23,976fps, 178.818 frames
- Bitrate: 35.000 Kbs
- [19:26:24] Reencoding: VID_00001, Pass 1 of 1
- [22:42:56] Video Encode complete
- [22:42:56] Processing audio tracks
- Track 4353 (deu): Keeping original audio
- [22:42:56] Multiplexing M2TS
[22:43:15]PHASE ONE aborted by user request
[08.11.19] BD Rebuilder v0.60.21
[22:44:11] Source: MARYQUEENOFSCOTS_UPK2
- Resuming from previously started job.
[22:44:13] PHASE ONE, Encoding
- [22:44:13] Processing: VID_00001 (2 of 8)
- [22:44:13] Multiplexing M2TS
- Error in attempt to multiplex: MUX_00001.meta
- Bitstream exception Unknown exception. It does not have to be! Please contact application support team for more information.
[22:45:02] - Failed to build structure, aborted
Regards
Michi
Michi is offline   Reply With Quote
Old 11th August 2019, 22:35   #28702  |  Link
cartman0208
Regards
Michi
Did you try to start the whole backup again?
Log says you started with an older version and resumed with a current one.
Just a thought...
Old 12th August 2019, 10:54   #28703  |  Link
Michi
No, the encoding time is over 3 hours.
But all failures are after the encoding and not before.
Old 12th August 2019, 11:33   #28704  |  Link
Michi
The new version 60.21 has a new failure:
[08.12.19] BD Rebuilder v0.60.21
[12:15:10] Source:  MARYQUEENOFSCOTS_UPK2
[12:15:13] PHASE ONE, Encoding
 - [12:15:13] Processing: VID_00000 (1 of 8)
 - [12:15:13] Reencoding video [VID_00000]
 - [12:15:13] Reencoding: VID_00000, Pass 1 of 1
 - [12:20:43] Video Encode complete
 - [12:20:43] Processing audio tracks
 - [12:20:43] Multiplexing M2TS
 - [12:21:02] Processing: VID_00001 (2 of 8)
 - [12:21:02] Extracting A/V streams [VID_00001]
 - Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps. File name: R:\BDMV\STREAM\00001.m2ts
 - Error in attempt to extract video.
[12:22:38] - Failed to retrieve audio, aborted
This Dolby Vision Disc works:
[22:53:43] Source:  DONT.LOOK.NOW.1973.2160P.COMPLETE.UHD.BLURAY-COASTER
  - Input BD size: 81,32 GB
  - Approximate total content: [02:57:02.760]
[22:53:46] PHASE ONE, Encoding
 - [22:53:46] Processing: VID_00000 (1 of 9)
 - [22:53:46] Extracting A/V streams [VID_00000]
 - [22:53:50] Reencoding video [VID_00000]
   - Rate/Length: 24,000fps, 481 frames
   - Bitrate: 34.844 Kbs
 - [22:53:50] Reencoding: VID_00000, Pass 1 of 1
 - [22:54:18] Video Encode complete
 - [22:54:18] Processing audio tracks
   - Track 4352 (und): Keeping original audio
 - [22:54:18] Multiplexing M2TS
 - [22:54:25] Processing: VID_00001 (2 of 9)
 - [22:54:25] Extracting A/V streams [VID_00001]
 - [22:54:28] Reencoding video [VID_00001]
   - Rate/Length: 24,000fps, 261 frames
   - Bitrate: 685 Kbs
 - [22:54:28] Reencoding: VID_00001, Pass 1 of 1
 - [22:54:43] Video Encode complete
 - [22:54:43] Processing audio tracks
 - [22:54:43] Multiplexing M2TS
 - [22:54:51] Processing: VID_00002 (3 of 9)
 - [22:54:51] Extracting A/V streams [VID_00002]
   - Extracting video streams [VID_00002]
   - Extracting secondary video [VID_00002]
   - Extracting audio/subtitle streams [VID_00002]
 - [23:17:36] Reencoding video [VID_00002]
   - Rate/Length: 24,000fps, 158.736 frames
 - [23:17:36] Reencoding: VID_00002, Pass 1 of 1
 - [02:00:45] Video Encode complete
 - [02:00:45] Processing audio tracks
 - [02:00:45] Multiplexing M2TS
 - [02:13:23] Processing: VID_00009 (4 of 9)
 - [02:13:24] Extracting A/V streams [VID_00009]
 - [02:13:43] Reencoding video [VID_00009]
   - Rate/Length: 24,000fps, 60.349 frames
   - Bitrate: 5.388 Kbs
 - [02:13:43] Reencoding: VID_00009, Pass 1 of 1
 - [02:24:10] Video Encode complete
 - [02:24:10] Processing audio tracks
 - [02:24:10] Multiplexing M2TS
 - [02:24:16] Processing: VID_00010 (5 of 9)
 - [02:24:16] Extracting A/V streams [VID_00010]
 - [02:24:26] Reencoding video [VID_00010]
   - Rate/Length: 24,000fps, 22.052 frames
   - Bitrate: 6.474 Kbs
 - [02:24:27] Reencoding: VID_00010, Pass 1 of 1
 - [02:28:55] Video Encode complete
 - [02:28:55] Processing audio tracks
 - [02:28:55] Multiplexing M2TS
 - [02:28:59] Processing: VID_00011 (6 of 9)
 - [02:28:59] Extracting A/V streams [VID_00011]
 - [02:29:09] Reencoding video [VID_00011]
   - Rate/Length: 24,000fps, 9.027 frames
   - Bitrate: 15.755 Kbs
 - [02:29:09] Reencoding: VID_00011, Pass 1 of 1
 - [02:32:05] Video Encode complete
 - [02:32:05] Processing audio tracks
 - [02:32:06] Multiplexing M2TS
 - [02:32:10] Processing: VID_00012 (7 of 9)
 - [02:32:10] Extracting A/V streams [VID_00012]
 - [02:32:13] Reencoding video [VID_00012]
   - Rate/Length: 24,000fps, 626 frames
   - Bitrate: 1.142 Kbs
 - [02:32:13] Reencoding: VID_00012, Pass 1 of 1
 - [02:32:48] Video Encode complete
 - [02:32:48] Processing audio tracks
 - [02:32:48] Multiplexing M2TS
 - [02:32:51] Processing: VID_00013 (8 of 9)
 - [02:32:51] Extracting A/V streams [VID_00013]
 - [02:32:55] Reencoding video [VID_00013]
   - Rate/Length: 24,000fps, 121 frames
   - Bitrate: 2.127 Kbs
 - [02:32:55] Reencoding: VID_00013, Pass 1 of 1
 - [02:33:02] Video Encode complete
 - [02:33:02] Processing audio tracks
 - [02:33:02] Multiplexing M2TS
 - [02:33:09] Processing: VID_00016 (9 of 9)
 - [02:33:09] Extracting A/V streams [VID_00016]
 - [02:33:13] Reencoding video [VID_00016]
   - Rate/Length: 24,000fps, 181 frames
   - Bitrate: 500 Kbs
 - [02:33:13] Reencoding: VID_00016, Pass 1 of 1
 - [02:33:23] Video Encode complete
 - [02:33:23] Processing audio tracks
 - [02:33:23] Multiplexing M2TS
[02:33:27]PHASE ONE complete
[02:33:27]PHASE TWO - Rebuild Started
 - [02:33:27] Rebuilding BD file Structure
[02:33:32] - Encode and Rebuild complete
[02:33:32] Writing BD structure to ISO file
 - ImgBurn completed successfully
 - DONT.LOOK.NOW.1973.2160P.COMPLETE.UHD.BLURAY-COASTER folder removed.
 - WORKFILES folder removed.
[02:34:19] JOB: DONT.LOOK.NOW.1973.2160P.COMPLETE.UHD.BLURAY-COASTER finished.
Old 12th August 2019, 11:45   #28705  |  Link
@Michi
Unfortunately that is a TSMUXER error. In the past all reports of that buffer overflow have been the result of a corrupt source. That may or may not be the case when it is handling UHD, I'll have to wait and see. But, the best I can do in this situation is try to find a way around it.
Is "Mary Queen of Scots" a Dolby Vision source? The fact that BD-RB reverted to extracting the video independently means it is already trying to bypass an error by extracting video separately from audio and subtitles. I could make it go one step further and extract the base video first and then the Dolby Vision track. I'd done that in the past with other types of secondary video, but I thought it wasn't necessary for the Dolby Vision track (it almost doubles the extraction time).
Could you post the contents of the "MUX_00001.meta" file at the point at which the demux failed?
Old 12th August 2019, 12:05   #28706  |  Link
@Michi
Try downloading this v0.60.22 BDRB.exe executable, and replacing the one that was provided with v0.60.21. Please report if it fixes the issue you had with "Mary Queen of Scots". If so, I'll put together another zip file and update the download links.
Looking at the code I realized that one of the changes I made probably wasn't one of the smartest things I've done recently.
Old 12th August 2019, 16:16   #28707  |  Link
Ch3vr0n
damn @jdobbs, first no updates in nearly a year (good reason for that though), now over half a dozen in a matter of weeks. You're on a roll!
Old 12th August 2019, 16:18   #28708  |  Link
Michi
Extracting with 60.22 works, but same failure at remux:
[08.12.19] BD Rebuilder v0.60.22
[13:28:01] Source:  MARYQUEENOFSCOTS_UPK2
[13:28:03] PHASE ONE, Encoding
 - [13:28:03] Processing: VID_00001 (2 of 8)
 - [13:28:03] Extracting A/V streams [VID_00001]
 - [13:48:00] Reencoding video [VID_00001]
   - Bitrate: 31.821 Kbs
 - [13:48:00] Reencoding: VID_00001, Pass 1 of 1
 - [16:52:37] Video Encode complete
 - [16:52:37] Processing audio tracks
 - [16:52:37] Multiplexing M2TS
[16:53:25] - Failed to build structure, aborted
The contents of the MUX_00001.meta
MUXOPT --no-pcr-on-video-pid --new-audio-pes --blu-ray --vbr --auto-chapters=5 --vbv-len=500 --start-time=27000000
V_MPEGH/ISO/HEVC, "Q:\4K\WORKFILES\VID_00001.AVS.hevc", fps=23.976, insertSEI, contSPS
V_MPEGH/ISO/HEVC, "Q:\4K\WORKFILES\00001.track_4117.hevc", fps=23.976, secondary, contSPS
A_AC3, "Q:\4K\WORKFILES\00001.track_4353.AC3", timeshift=-1ms, lang=deu
S_HDMV/PGS, "Q:\4K\WORKFILES\00001.track_4769.sup",lang=deu
S_HDMV/PGS, "Q:\4K\WORKFILES\00001.track_4773.sup",lang=deu
S_HDMV/PGS, "Q:\4K\WORKFILES\00001.track_4776.sup",lang=deu
Old 12th August 2019, 19:38   #28709  |  Link
I'm getting that same error on one of the discs I'm currrently testing. It's coming from TSMUXER -- and I haven't been able to find a workaround yet.
Old 12th August 2019, 21:05   #28710  |  Link
I just wanted to get the UHD working... and I figured as long as I had my head in the code I might as well fix everything I can.
Old 12th August 2019, 21:12   #28711  |  Link
I've updated the first post of this thread with a link to the latest release of BD Rebuider (v0.60.22). Changes for this release:
- Corrected an error introduced in v0.60.21
  that could cause failure during video
  extraction on Dolby Vision or other sources
  that might have secondary video tracks.
- Updated the included version of X264 to the
  latest stable release (r2984).
- Updated the included versions of X265 to
  v3.1.2 10 bit version.
Old 12th August 2019, 22:13   #28712  |  Link
Ch3vr0n
@jdobbs Any chance you forgot to update (Settings)? Just for giggles i ran inspect after updating to .22. Havent changed anything, yet it's reporting x264 & x265 as wrong version
Old 12th August 2019, 22:51   #28713  |  Link
I forgot to update the checksum in INSPECT. That's what happens when you go a while without doing updates. I'll correct it in the next release.
Old 13th August 2019, 13:32   #28714  |  Link
Michi
Bd-Rebuilder reencode the disc "Now you see me" over 100%.
08.13.19] BD Rebuilder v0.60.22
[10:31:53] Source:  DIE.UNFASSBAREN.NOW.YOU.SEE.ME.2013
  - Input BD size: 72,65 GB
  - Approximate total content: [03:08:39.683]
[10:31:53] PHASE ONE, Encoding
 - [10:31:53] Processing: VID_00000 (1 of 12)
 - [10:31:53] Extracting A/V streams [VID_00000]
   - Extracting video streams [VID_00000]
   - Extracting audio/subtitle streams [VID_00000]
 - [10:44:05] Reencoding video [VID_00000]
   - Rate/Length: 23,976fps, 166.462 frames
 - [10:44:05] Reencoding: VID_00000, Pass 1 of 1
Old 13th August 2019, 16:54   #28715  |  Link
jankosek
Will this speed quality degrade the image? 3-4h on this quality, time depends on the equipment of course , this will be good image quality UHD ?
On default i got 1day+
jankosek is offline   Reply With Quote
Old 13th August 2019, 16:56   #28716  |  Link
inge70
Error on Inspect version 0.60.22
Checking System Settings
- BD-Rebuilder v0.60.22
- Working Path Free Space: 182,40GB
- AVISYNTH Version: 2.6.0.6, Ok
- LAVFILTERS: Ok
- X264: Wrong version found
- X265: Wrong version found
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
- FRIMEncode: Ok
- FRIMDecode: Ok
Apparently, the new x264 and x265 version is integrated but is recognized as the "wrong version".
I copied the x264.exe + x264-64.exe, x264L.exe + x264L-64.exe and x265.exe + x265-64.exe from version 0.60.19 into the current version
and "Inspect" shows at "x264" and "x265" again "ok"
[08.13.19] Checking System Settings
- Working Path Free Space: 182,56GB
- LAVFILTERS: Ok
- X264: Ok (copy from v. 0.60.19)
- X265: Ok (copy from v. 0.60.19)
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
- FRIMEncode: Ok
- FRIMDecode: Ok
[08.13.19] Systems Settings Check complete
inge70 is offline   Reply With Quote
Old 13th August 2019, 17:49   #28717  |  Link
Ch3vr0n
I literally posted that 3 posts above yours. Reading helps The "Wrong version" is normal. jdobbs forgot to update the "inspect" hashes it relies on to report ok or wrong version. It'll get fixed in the next update
Old 13th August 2019, 23:45   #28718  |  Link
That's a recommendation for testing, simply to save time. If you're concerned about quality, stay with the defaults.
But, honestly, at the bitrates used for BD-25 and BD-50, you're unlikely to notice much difference. I've been pretty impressed with the quality on the ones I've done using Good/ABR.
By the way -- on my system even Good/ABR takes 13-15h to encode, so I'm envious of your 3-4h.
Old 13th August 2019, 23:57   #28719  |  Link
BD Rebuilder v0.60.23
I've updated the first post of this thread with a link to the latest release of BD-RB (v0.60.23). Changes for this version:
- Corrected a problem in which Dolby Vision
  sources that are reencoded would oversize
  during muxing as a result of superfluous
  information being kept in the M2TS file.
- Fixed the erroneous "Wrong Version" report
  in INSPECT for the new versions of X264 and
  X265.
Not a lot of changes -- but I thought the first one deserved posting as soon as possible, as no one wants to spend a lot of time encoding a disc, just to find it oversized and may not fit on your target disc. BTW, if you still have a Dolby Vision job on your hard drive that oversized, just rebuilding with this new version may get it to within your target.
My thanks again to cartman0208 for hosting these downloads.
Old 14th August 2019, 00:50   #28720  |  Link
You may want to try rerunning that job with the new version. With the disc upon which I got that error, the issue went away with the BD-RB update to X265.
