16th June 2011, 17:07 | #21 | Link | |
Debanding does a quite good job. Andrew Last edited by kolak; 16th June 2011 at 17:09. |
16th June 2011, 17:48 | #22 | Link | |
typo lover
I heard that the original author(AviUtl version) is a professional who is working in an authoring studio as you.
my repositories |
18th June 2011, 15:02 | #29 | Link |
flash3kyuu_deband in high precision mode has the job very well done, indeed. And it is fast. Congratulations to you and to the author of the original filter.
BTW, GradFun3 current default settings are a bit on the conservative side, therefore to get comparable results you should add mask=0 to your tests.
dither 1.28.1 for AviSynth | avstp 1.0.4 for AviSynth development | fmtconv r30 for Vapoursynth & Avs+ | trimx264opt segmented encoding |
19th June 2011, 05:44 | #30 | Link | |
19th June 2011, 13:31 | #31 | Link |
yup definitely one of the optimized quality/speed ones here great work
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 |
19th June 2011, 15:20 | #32 | Link |
Thanks for your great work SAPikachu.
What abut YUY2 support? There seams to be quite a lot work going on around dithering/debanding. Is there a solution, which would dither 10bit (or higher) source to 8bit output? As far as I understand this tool is for debanding and designed to remove existing banding on 8bit sources. What about dithering eg. v210 source- can it do this? Andrew Last edited by kolak; 19th June 2011 at 15:23. |
20th June 2011, 02:15 | #33 | Link | |
Actually, the high precision mode will upsample pixels to 14bit first, and downsample to 8bit after processing. Dithering occurs in downsampling. The dither algorithm are well-known ones (Floyd-Steinberg dithering and Ordered dithering). But since AviSynth does not support higher bit-depth natively, it may be difficult to import the video source. If it can be loaded, it shouldn't be very hard to add support for it. |
20th June 2011, 13:04 | #34 | Link |
There were some attemps to import v210 Qt into avisynth- not sure if it's working and compatible with your work.
http://forum.doom9.org/showthread.ph...highlight=v210 Andrew |
21st June 2011, 06:28 | #36 | Link | |
21st June 2011, 10:38 | #40 | Link |
I have used this filter in combination with MDegrain for several sources and I'm very happy with the results.
I also played around with the "diff_seed" parameter but can't really see any difference (apart from the fact that "diff_seed = true" is quite a bit slower). Do you have any more info on the usefulness of that parameter? |
avisynth, deband |
