30th October 2018, 13:11 | #62 | Link |
I am maddo saientisto!
First thing I did was modify line 99 in CMakeList.txt from
if( UNIX ) to if( NOT MSVC ) which is the same thing aom does to set the compiler flags for GCC/ICC/Clang. Then I had to add add_compile_options( "-mavx2" ) right below add_compile_options( "-msse4.1" ) All the above BEFORE the "cmake -G "MSYS Makefiles" -DBUILD_STATIC=ON -DCMAKE_BUILD_TYPE=Release .." command of course However! This triggers something in GCC and the compilation process bugs out on IntraPrediction.cpp because of some -Wmaybe-uninitialized which appears ONLY when compiling with -mavx2 So what I do is, make -j6 until it bugs out, then make VERBOSE=1 to intercept the "bad" compilation command, remove -mavx2 from it, run that command, reposition myself at the top of the build directory, then resume building normally. Gotta do the same thing twice because IntraPrediction.cpp is used in a couple of libraries, so the object file ends up in different directories each time. Not the most straightforward way, but everything seems to work fine afterwards Last edited by SmilingWolf; 30th October 2018 at 13:15. |
30th October 2018, 13:37 | #63 | Link |
Too much manual meddling for me as autobuild suite user...
I made it an official issue and hope it will be taken seriously. At least it has a future. Unlike mencoder which may already be dead. |
30th October 2018, 14:02 | #64 | Link |
Well I did all that to stay on the "safe" side of things.
However one could modify line 75 in CMakeLists.txt from bb_enable_warnings( gcc warnings-as-errors -Wno-sign-compare -Wno-class-memaccess ) to bb_enable_warnings( gcc warnings-as-errors -Wno-sign-compare -Wno-class-memaccess -Wno-maybe-uninitialized ) along with the other CMakeLists.txt described above to enable SSE4.1 and AVX2. It compiles fine without manual intervention, altough I haven't tested yet the encoder built this way (just finished compiling). There shouldn't be any problem though, -Wmaybe-uninitialized is known to be overzealous at times Also, it's always strange to see my nick in quotes like 'SmilingWolf' or 'lupo...'. Makes me feel kinda like a shady character lol Note that I don't mean anything by this. I'm merely too used to considering it my first name when I'm online EDIT: summing up, a git diff ready to apply to the repo looks like this: Code:
diff --git a/CMakeLists.txt b/CMakeLists.txt index 2d59e74..3c3430c 100644 --- a/CMakeLists.txt +++ b/CMakeLists.txt @@ -72,7 +72,7 @@ endif() # bb_enable_warnings( gcc -Wno-unused-variable ) # bb_enable_warnings( gcc-4.8 warnings-as-errors -Wno-unused-variable ) # for gcc 8.2: -bb_enable_warnings( gcc warnings-as-errors -Wno-sign-compare -Wno-class-memaccess) +bb_enable_warnings( gcc warnings-as-errors -Wno-sign-compare -Wno-class-memaccess -Wno-maybe-uninitialized ) if( XCODE ) bb_enable_warnings( clang warnings-as-errors @@ -96,8 +96,9 @@ endif() bb_enable_warnings( msvc warnings-as-errors "/wd4996" ) # enable sse4.1 build for all source files for gcc and clang -if( UNIX ) +if( NOT MSVC ) add_compile_options( "-msse4.1" ) + add_compile_options( "-mavx2" ) endif() # enable parallel build for Visual Studio Last edited by SmilingWolf; 30th October 2018 at 14:10. |
3rd November 2018, 11:04 | #66 | Link | |
64bits single-threaded binaries only (MSYS2/GCC 8.2): VVCSoftware_VTM-2.2-156-g0326358: https://mega.nz/#!k4w3iQJI!0zN4oMEP2...rhoPcxcwzJ4RP8 |
10th November 2018, 15:08 | #67 | Link |
VVCSoftware_VTM-3.0rc1: https://mega.nz/#!klR2xAqI!-6CgrU7UI...WRHNtmK38xAO6o |
12th November 2018, 22:16 | #68 | Link |
I will add commands for the 8bit codec. They still need to work on decoding.
EncoderApp.exe -i image_21447.yuv -b video.vvc -wdt 1920 -hgt 1080 --InputBitDepth=8 --InputChromaFormat=420 --QP=0 --SEIDecodedPictureHash=0 --Verbosity --FramesToBeEncoded=1 --ConformanceWindowMode=0 --FrameRate=25 --QuadtreeTULog2MaxSize=5 --QuadtreeTUMaxDepthIntra=4 --QuadtreeTUMaxDepthInter=4 --Profile=next --IntraPeriod=1 --GOPSize=1 --TransformSkip=1 --TransformSkipFast=1 --SEIDecodedPictureHash=3 --QTBT=1 --CTUSize=32 DecoderApp.exe -b video.vvc -o output.yuv --SEIDecodedPictureHash=0 --OutputBitDepth=8 https://www.sendspace.com/file/7ho3k5 |
12th November 2018, 22:31 | #69 | Link |
The official testing guidelines actually suggest using the config files already included in the repo, so the cmdline should look more like:
bin/EncoderApp.exe -c cfg/encoder_randomaccess_vtm.cfg --InputFile=orig.i420.yuv --ReconFile=vvc.qp31.3.0rc1.yuv --BitstreamFile=vvc.qp31.3.0rc1.bin --FrameRate=24000/1001 --FramesToBeEncoded=2159 --SourceWidth=320 --SourceHeight=240 --InputBitDepth=8 --OutputBitDepth=8 --InternalBitDepth=8 --QP=31 Last edited by SmilingWolf; 12th November 2018 at 22:35. |
19th November 2018, 07:25 | #70 | Link | ||
VVC Test Model 1.0 New block partitioning • 128x128 Coding Tree Units (CTU) • Recursive quadtree partitioning (QT) • Nested recursive multi-type tree partitioning (MTT) with binary or ternary split Oh, but it means more precision as well as a computer adapted to 8K movies. Otherwise, the film is processed four times longer than JCTVC using the parameters from the official test. Last edited by Jamaika; 19th November 2018 at 07:29. |
23rd November 2018, 22:58 | #71 | Link | |
I might take a whack at some test VVC encodes for my codec challenge over the long weekend. |
24th November 2018, 00:47 | #72 | Link |
Helenium(Easter)
https://vcgit.hhi.fraunhofer.de/jvet...tware_VTM/tags
More like a change log, but this is the only one I can find.
Monochrome Anomaly |
29th November 2018, 00:00 | #73 | Link |
There is a new cmake-update branch to fix the lack of CMake support in MSYS2/MinGW. The project compiles now with both MinGW32 (GCC 7.3.0) and MinGW64 (GCC 8.2.0), despite some persisting BBuildEnv warnings.
Unfortunately, the created apps crash with an external exception c000001d (illegal instruction) on an AMD Phenom-II; I assume they require more than just SSE2 to run at all. Will test tomorrow on an FX CPU. __ P.S.: Code:
--SIMD SIMD extension to use (SCALAR, SSE41, SSE42, AVX, AVX2, AVX512), default: the highest supported extension I noticed that the MinGW32 build (GCC 7.3.0) reports [SIMD=SSE42], but the MinGW64 build (GCC 8.2.0) reports [SIMD=AVX] on an AMD FX-5600. VVCSoftware_VTM-2.2 cmake-update 67208da2 BTW, is it correct that the current VTM encoder does not even support Y4M, only raw YUV? Last edited by LigH; 29th November 2018 at 10:09. |
29th November 2018, 21:25 | #74 | Link | |
If true then output 10-bit and 12-bit YUV data as 5-byte and 3-byte (respectively) packed YUV data. Ignored for interlaced output. |
29th November 2018, 21:55 | #75 | Link | |
Btw, thanks everybody who share builds here. I really appreciate it. |
4th December 2018, 19:51 | #77 | Link |
The cmake-update patch has been merged. Compilation with MinGW+GCC now works from the master branch.
VVCSoftware_VTM-3.0 14a70bbb Last edited by LigH; 4th December 2018 at 21:46. |
9th December 2018, 04:13 | #79 | Link |
Broadcast Encoder
Thanks for the binary.
I wanted to play a bit with it and I know that it can open .yuv files, so I tried to open Avisynth via ffmpeg and pipe it to vvc.exe via yuv4mpegpipe, but it seems that it can't open it, 'cause it doesn't like yuv4mpeg: Code:
ffmpeg.exe -i "\\VBOXSVR\Share_Windows_Linux\Production\AVS\test.avs" -strict -1 -an -f yuv4mpegpipe - | vvc.exe -i - --Profile=next --FrameRate=24000/1001 --InputBitDepth=8 --OutputBitDepth=8 --InternalBitDepth=8 --QP=31 --FramesToBeEncoded=21 --QuadtreeTULog2MaxSize=5 --QuadtreeTUMaxDepthIntra=4 --QuadtreeTUMaxDepthInter=4 --GOPSize=1 --IntraPeriod=1 --CTUSize=32 --BitstreamFile=vvc.bitsteam -o "\\VBOXSVR\Share_Windows_Linux\raw_video.vvc" pause If I try to use "--y4m -" like in x265, instead, it gives "command not found". I then tried to use "rawvideo" as pipe, but it still says "impossible to open -". Code:
ffmpeg.exe -i "\\VBOXSVR\Share_Windows_Linux\Production\AVS\test.avs" -strict -1 -an -f rawvideo - | vvc.exe -i - --Profile=next --FrameRate=24000/1001 --InputBitDepth=8 --OutputBitDepth=8 --InternalBitDepth=8 --QP=31 --FramesToBeEncoded=21 --QuadtreeTULog2MaxSize=5 --QuadtreeTUMaxDepthIntra=4 --QuadtreeTUMaxDepthInter=4 --GOPSize=1 --IntraPeriod=1 --CTUSize=32 --BitstreamFile=vvc.bitsteam -o "\\VBOXSVR\Share_Windows_Linux\raw_video.vvc" pause |
9th December 2018, 07:16 | #80 | Link |
The command line syntax of VVC is definitely different and a lot more complex than the one of x265 or even x264. And it is not compatible (and there is no reason why it should). Due to the complexity, it is recommended to use configuration files. A bunch of them are available from their source repository.
Only support for raw YUV is documented. But they may support Y4M too, I heard from other testers. Yet, I don't know whether it supports pipes or not. All configuration examples I saw referred to files. The error message "impossible to open -" suggests that it assumes "-" to be a file name, not understanding it means "read from a pipe". |
