29th June 2016, 16:20 | #24381 | Link | ||
SupTitle("D:\WORKING4\WORKFILES\00001.track_9999.sup") [Edit] I've tried every combination I can think of, and I can't repeat the problem you've reported. Last edited by jdobbs; 29th June 2016 at 17:06. |
29th June 2016, 20:19 | #24382 | Link |
Just a quick question. If you have some MKV files encoded to Blu-ray video specifications, can you Import them into BD Rebuilder and have it not re-encode them? Audio is plain AC3. I just want the menu and all of them put into a Blu-ray structure. Total size of input is approximately 11GB.
I tried this, but it started to re-encode them, ignoring the FORCE_NOENCODE=1 line. I admit I didn't keep it running long, so perhaps I jumped the gun? |
29th June 2016, 21:35 | #24383 | Link | ||
Let me try to shed light upon my situation
I really love the feature of BDRB to output movies as MP4, because I mainly stream them from mediaserver to TV via DLNA. That way I cannot use soft subs. I need them hard coded. BDRB 0.50.14 can hard-code the one (9999) that is present after extraction during encode using SUPTITLE() which is nearly perfect. My feature request (and included in intermediate version 0.50.15 --> post: 23864) was the ability to hard-code any other subtitle track via right click [Forced on] for alternate output such as MP4. This is very convinient if none subtitle stream contains forced ones such as extras or streams which have "forced" ones only and therefore are not marked as forced. The alternative would be to add the suptitle lines manually in the AVS Editor: Code:
LoadPlugin("C:\Program Files (x86)\AviSynth 2.5\plugins\SupTitle.dll") SupTitle(....) Quote:
If I do not select any stream I would expect the 9999 file getting hard-coded into the output. I made some tests using 0.50.14/15: source: Death Proof Version: 0.50.14 AVS file for segment 00006 after 00005 has been processed successfully and audio conversion has been finalized: Code:
#Created by BD Rebuilder - v0.50.14 DirectshowSource("C:\USERS\xxx\VIDEOS\BD_ORIGINAL\DEATH_PROOF_BD\BDMV\STREAM\00006.m2ts", fps=23.976, framecount=163504, audio=false) LoadPlugin("C:\Program Files (x86)\AviSynth 2.5\plugins\SupTitle.dll") SupTitle("C:\USERS\xxx\VIDEOS\BD_RB_WORK_3\WORKFILES\00006.track_9999.sup") ConvertToYV12().AssumeFPS(24000,1001) Code:
[06.29.16] BD Rebuilder v0.50.14 [20:44:15] Source: DEATH_PROOF_BD_00021 - Input BD size: 31,61 GB - Approximate total content: [01:53:44.234] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: My MP4 Container, 1920x1080, AutoGOP, AAC-256 - Quality: High Quality (Default) - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [20:44:15] PHASE ONE, Encoding - [20:44:15] Processing: VID_00005 (1 of 2) - [20:44:15] Extracting A/V streams [VID_00005] - [20:55:00] Reencoding video [VID_00005] - Source Video: VC-1, 1920x1080 - Rate/Length: 23,976fps, 114 frames - [20:55:00] Reencoding: VID_00005, Pass 1 of 1 - [20:55:17] Video Encode complete - [20:55:17] Processing audio tracks - Track 4352 (deu): Reencoding audio to AAC... - [21:02:20] Processing: VID_00006 (2 of 2) - [21:02:20] Extracting A/V streams [VID_00006] - [21:14:57] Reencoding video [VID_00006] - Source Video: VC-1, 1920x1080 - Rate/Length: 23,976fps, 163.504 frames - [21:14:57] Reencoding: VID_00006, Pass 1 of 1 [21:16:17]PHASE ONE aborted by user request source: Death Proof Version: 0.50.15 AVS file: Code:
#Created by BD Rebuilder - v0.50.15 DirectshowSource("C:\USERS\xxx\VIDEOS\BD_ORIGINAL\DEATH_PROOF_BD\BDMV\STREAM\00005.m2ts", fps=23.976, framecount=114, audio=false) LoadPlugin("C:\Program Files (x86)\AviSynth 2.5\plugins\SupTitle.dll") Code:
[06.29.16] BD Rebuilder v0.50.15 [21:55:36] Source: DEATH_PROOF_BD_00021 - Input BD size: 31,61 GB - Approximate total content: [01:53:44.234] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: My MP4 Container, 1920x1080, AutoGOP, AAC-256 - Quality: High Quality (Default) - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [21:55:36] PHASE ONE, Encoding - [21:55:36] Processing: VID_00005 (1 of 2) - [21:55:36] Extracting A/V streams [VID_00005] - [22:01:31] CreateAVS() 00000 [22:02:23] - Could not create AVS file Enabling the subtitle streams in stream window makes no difference. But it works if I set [Forced on] for a stream. I choe the 2nd as this one contains forced Subs only and is identical with the 9999 file. avs file for segment 00005: Code:
#Created by BD Rebuilder - v0.50.15 DirectshowSource("C:\USERS\xxx\VIDEOS\BD_ORIGINAL\DEATH_PROOF_BD\BDMV\STREAM\00005.m2ts", fps=23.976, framecount=114, audio=false) LoadPlugin("C:\Program Files (x86)\AviSynth 2.5\plugins\SupTitle.dll") SupTitle("C:\USERS\xxx\VIDEOS\BD_RB_WORK_4\WORKFILES\00005.track_4609.sup") ConvertToYV12().AssumeFPS(24000,1001) Code:
#Created by BD Rebuilder - v0.50.15 DirectshowSource("C:\USERS\xxx\VIDEOS\BD_ORIGINAL\DEATH_PROOF_BD\BDMV\STREAM\00006.m2ts", fps=23.976, framecount=163504, audio=false) LoadPlugin("C:\Program Files (x86)\AviSynth 2.5\plugins\SupTitle.dll") SupTitle("C:\USERS\xxx\VIDEOS\BD_RB_WORK_4\WORKFILES\00006.track_4609.sup") ConvertToYV12().AssumeFPS(24000,1001) Code:
---------------------- [06.29.16] BD Rebuilder v0.50.15 [21:55:36] Source: DEATH_PROOF_BD_00021 - Input BD size: 31,61 GB - Approximate total content: [01:53:44.234] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: My MP4 Container, 1920x1080, AutoGOP, AAC-256 - Quality: High Quality (Default) - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [21:55:36] PHASE ONE, Encoding - [21:55:36] Processing: VID_00005 (1 of 2) - [21:55:36] Extracting A/V streams [VID_00005] - [22:01:31] CreateAVS() 00000 [22:02:23] - Could not create AVS file ---------------------- ... ---------------------- [06.29.16] BD Rebuilder v0.50.15 [22:10:19] Source: DEATH_PROOF_BD_00021 - Input BD size: 31,61 GB - Approximate total content: [01:53:44.234] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: My MP4 Container, 1920x1080, AutoGOP, AAC-256 - Quality: High Quality (Default) - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 - Resuming from previously started job. [22:10:21] PHASE ONE, Encoding - [22:10:21] Processing: VID_00005 (1 of 2) - [22:10:21] Reencoding video [VID_00005] - Source Video: VC-1, 1920x1080 - Rate/Length: 23,976fps, 114 frames - [22:10:21] Reencoding: VID_00005, Pass 1 of 1 - [22:10:24] Video Encode complete - [22:10:24] Processing audio tracks - Track 4352 (deu): Reencoding audio to AAC... - [22:17:09] Processing: VID_00006 (2 of 2) - [22:17:09] Extracting A/V streams [VID_00006] - [22:29:06] Reencoding video [VID_00006] - Source Video: VC-1, 1920x1080 - Rate/Length: 23,976fps, 163.504 frames - [22:29:06] Reencoding: VID_00006, Pass 1 of 1 [22:29:40]PHASE ONE aborted by user request Quote:
Long post. Still question marks in your face? ggtop Last edited by ggtop; 29th June 2016 at 21:40. |
30th June 2016, 00:16 | #24384 | Link |
ERROR preparing intermediate audio
I receive the above error when trying to rebuild/compress a movie (for which I used DVDFab to remove Cinavia, so the audio track is modified from the original). The movie is Amour. Are there any tips to troubleshoot this? Thanks in advance.
Log file below. ---------------------- [06/29/16] BD Rebuilder v0.50.14 [05:52:26] Source: AMOUR_(CINAVIA_REMOVED) - Input BD size: 30.40 GB - Approximate total content: [02:07:21.633] - Target BD size: 23.73 GB - Windows Version: 6.1 [7601] - Quality: Highest (Very Slow), Two Pass - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=640 [05:52:26] PHASE ONE, Encoding - [05:52:26] Processing: VID_00001 (1 of 1) - [05:52:26] Extracting A/V streams [VID_00001] - Extracting video streams [VID_00001] - Extracting audio streams [VID_00001] - [06:17:05] Reencoding video [VID_00001] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 183,216 frames - Bitrate: 24,052 Kbs - [06:17:05] Reencoding: VID_00001, Pass 1 of 2 - [06:52:09] Reencoding: VID_00001, Pass 2 of 2 - [10:02:46] Video Encode complete - [10:02:47] Processing audio tracks - Track 4352 (fra): Reencoding audio to AC3... - ERROR preparing intermediate audio. [10:02:48] - Failed to reencode audio, aborted |
30th June 2016, 04:57 | #24386 | Link | |
30th June 2016, 05:00 | #24387 | Link | |
30th June 2016, 05:09 | #24388 | Link |
@ggtop
Ok. I understand what you're doing. But I can do the same thing on the sources I'm using for testing and not get an error. That's the problem. Maybe if you post the contents of your BDREBUILDER.INI file I can try it with the exact same settings you are using and possibly repeat it. I don't have DEATH_PROOF, and with no donations for a year now I'm no longer buying discs just for testing, so I can't use that as a source. |
30th June 2016, 08:39 | #24390 | Link | |
I made some more tests this morning and I think I can point you where it fails. Using 0.50.15 the setting FORCED_SUB_LANG=deu is not being populated into the inf file. The line is missing and very likely the reason the 9999 file is not created and present and therefore cannot be referenced in the AVS file. Please be aware that this happens ONLY in multipart sources in which the mpls has more than 1 m2ts. I also tried a playlist on my Death Proof BD that does not have the initail Trailer and for this one it worked. I will collect the logs and inf files and post them in a few minutes. ggtop Last edited by ggtop; 30th June 2016 at 08:42. |
30th June 2016, 11:35 | #24391 | Link | |
I generally use DVDFab only to rip (and no other processing). In this case, however, it needs to be used also to remove the Cinavia. In any case, I've done other titles with Cinavia in the same manner without issue; there seems just to be a problem with this title. The LPCM audio seems to play fine, via MPC-HC. My question was primarily if there were specific known issues in the audio stream that can cause that specific error. Maybe I'll try compressing in DVDFab and see if it works. |
30th June 2016, 11:46 | #24392 | Link | |
30th June 2016, 19:25 | #24393 | Link | ||
30th June 2016, 22:55 | #24395 | Link | |
This is the log for an encode using 0.50.15 for playlist 00006 (VID_00006 only): Code:
[06.30.16] BD Rebuilder v0.50.15 [08:55:57] Source: DEATH_PROOF_BD_00006 - Input BD size: 31,60 GB - Approximate total content: [01:53:39.479] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: My MP4 Container, 1920x1080, AutoGOP, AAC-256 - Quality: High Quality (Default) - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [08:55:57] PHASE ONE, Encoding - [08:55:57] Processing: VID_00006 (1 of 1) - [08:55:57] Extracting A/V streams [VID_00006] - [09:07:17] Reencoding video [VID_00006] - Source Video: VC-1, 1920x1080 - Rate/Length: 23,976fps, 163.504 frames - [09:07:17] Reencoding: VID_00006, Pass 1 of 1 [09:17:04]PHASE ONE aborted by user request inf file for this one: Code:
[Status] LABEL=DEATH_PROOF_BD VERSION=v0.50.15 SOURCE_SIZE=33934872576 SOURCE_VIDEO_SIZE=33934872576 TARGET_SIZE=24641536000 REDUCTION=.726141992866283 RESIZE_1080=0 RESIZE_1440=0 AUDIO_TO_KEEP=deu;eng;ger; KEEP_HD_AUDIO=0 SUBS_TO_KEEP=deu;eng;ger; BACKUP_MODE=1 MOVIEONLY_TYPE=37 USE_LAVF=0 INSTANCES=1 DGDECNV=0 DGDECIM=0 FRIMSOURCE=0 FFMS2=0 SSIF_MODE=0 QUICK=0 ENCODE_STEP=1.5 FORCED_SUB_LANG=deu REBUILD_COMPLETE=0 [00006] AUDIO=1000 PGS=00 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=24641536000 SPLITS=1 What I have observed is the following: BDRB processes VID_00005 first and therefore extracts playlist 00021: video part from 00005.m2ts and full audio and all subtiles from the playlist 00021. After those 00021* files are created they are renamed to 00005. The AVS file is created and BDRB quits with error "CreateAVS() 00000". The 00005.track_9999.sup file is present at that time. Could it be that BDRB tries to put 00021.track_9999.sup into the AVS? log file for the mutipart attempt: Code:
---------------------- [06.30.16] BD Rebuilder v0.50.15 [23:48:15] Source: DEATH_PROOF_BD_00021 - Input BD size: 31,61 GB - Approximate total content: [01:53:44.234] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: My MP4 Container, 1920x1080, AutoGOP, AAC-256 - Quality: High Quality (Default) - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [23:48:15] PHASE ONE, Encoding - [23:48:15] Processing: VID_00005 (1 of 2) - [23:48:15] Extracting A/V streams [VID_00005] - [23:53:58] Reencoding video [VID_00005] - Source Video: VC-1, 1920x1080 - Rate/Length: 23,976fps, 114 frames - [23:53:58] Reencoding: VID_00005, Pass 1 of 1 - [23:54:01] Video Encode complete - [23:54:01] Processing audio tracks - Track 4352 (deu): Reencoding audio to AAC... [23:57:23]PHASE ONE aborted by user request Code:
[Status] LABEL=DEATH_PROOF_BD VERSION=v0.50.15 SOURCE_SIZE=33942312960 SOURCE_VIDEO_SIZE=33942312960 TARGET_SIZE=24641536000 REDUCTION=.725982817642372 RESIZE_1080=0 RESIZE_1440=0 AUDIO_TO_KEEP=deu;eng;ger; KEEP_HD_AUDIO=0 SUBS_TO_KEEP=deu;eng;ger; BACKUP_MODE=1 MOVIEONLY_TYPE=37 USE_LAVF=0 INSTANCES=1 DGDECNV=0 DGDECIM=0 FRIMSOURCE=0 FFMS2=0 SSIF_MODE=0 QUICK=0 ENCODE_STEP=3 REBUILD_COMPLETE=0 [00005] AUDIO=1000 PGS=01 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=5401591 SPLITS=1 BTW After VID_00005 is processed I can stop the encoding and deselect subtitles and resume processing and BDRB uses 9999 file. THE AVS error only happens on the first "part". I can even delete the file 00006.track_9999.sup. It immediately gets recreated if all sub stream are disabled and I resume the Encoding. Just a side note. ggtop Last edited by ggtop; 30th June 2016 at 23:09. |
1st July 2016, 20:39 | #24396 | Link |
I've also got a curious problem which I'm not able to fix: I bought a new PC some months ago (Core i7 6700K, 16 GB RAM, Win 10 x64) and I can't get BD Rebuilder to work precisely.
The encoding-process works perfectly but as soon as it comes to Phase 2 there are problems most of the time. As an example here's the logfile of my attempt to use BD Rebuilder with "The Hateful 8" but it also happens with other BDs: Code:
[06.30.16] BD Rebuilder v0.50.14 [17:33:59] Source: HATEFUL_8 - Input BD size: 42,21 GB - Approximate total content: [03:08:18.385] - Target BD size: 22,95 GB - Windows Version: 6.2 [9200] - Quality: Highest (Very Slow), Two Pass - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [17:34:00] PHASE ONE, Encoding - [17:34:00] Processing: VID_00021 (1 of 5) - [17:34:00] Extracting A/V streams [VID_00021] - [17:47:36] Reencoding video [VID_00021] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 242.260 frames - Bitrate: 9.312 Kbs - [17:47:36] Reencoding: VID_00021, Pass 1 of 2 - [18:20:09] Reencoding: VID_00021, Pass 2 of 2 - [20:34:18] Video Encode complete - [20:34:18] Processing audio tracks - Track 4352 (deu): Keeping original audio - Track 4353 (eng): Keeping original audio - [20:34:18] Multiplexing M2TS - [20:39:51] Processing: VID_00101 (2 of 5) - [20:39:51] Extracting A/V streams [VID_00101] - [20:40:06] Reencoding video [VID_00101] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 7.166 frames - Bitrate: 7.194 Kbs - [20:40:06] Reencoding: VID_00101, Pass 1 of 2 - [20:41:01] Reencoding: VID_00101, Pass 2 of 2 - [20:44:37] Video Encode complete - [20:44:37] Processing audio tracks - Track 4352 (eng): Keeping original audio - [20:44:37] Multiplexing M2TS - [20:44:43] Processing: VID_00102 (3 of 5) - [20:44:43] Extracting A/V streams [VID_00102] - [20:45:04] Reencoding video [VID_00102] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 10.854 frames - Bitrate: 7.196 Kbs - [20:45:04] Reencoding: VID_00102, Pass 1 of 2 - [20:46:26] Reencoding: VID_00102, Pass 2 of 2 - [20:52:01] Video Encode complete - [20:52:01] Processing audio tracks - Track 4352 (eng): Keeping original audio - [20:52:01] Multiplexing M2TS - [20:52:09] Processing: VID_00103 (4 of 5) - [20:52:09] Extracting A/V streams [VID_00103] - [20:52:17] Reencoding video [VID_00103] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 24,000fps, 3.243 frames - Bitrate: 5.906 Kbs - [20:52:17] Reencoding: VID_00103, Pass 1 of 2 - [20:52:41] Reencoding: VID_00103, Pass 2 of 2 - [20:54:03] Video Encode complete - [20:54:03] Processing audio tracks - Track 4352 (deu): Keeping original audio - [20:54:03] Multiplexing M2TS - [20:54:08] Processing: VID_00104 (5 of 5) - [20:54:08] Extracting A/V streams [VID_00104] - [20:54:16] Reencoding video [VID_00104] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 24,000fps, 3.409 frames - Bitrate: 5.905 Kbs - [20:54:16] Reencoding: VID_00104, Pass 1 of 2 - [20:54:41] Reencoding: VID_00104, Pass 2 of 2 - [20:56:06] Video Encode complete - [20:56:06] Processing audio tracks - Track 4352 (deu): Keeping original audio - [20:56:06] Multiplexing M2TS [20:56:10]PHASE ONE complete [20:56:10]PHASE TWO - Rebuild Started - [20:56:10] Rebuilding stream 00021 [1 of 5] - [20:56:10] Multiplexing M2TS - Error in attempt to multiplex: MUX_00021.meta - Can't create file D:\EIGENE DATEIEN\EIGENE VIDEOS\THE HATEFUL EIGHT\REBUILD\WORKFILES\TMP\BDMV\STREAM\00000.m2ts - Failed to rebuild BD file(s). Aborted. Now the most curious thing about it: If I copy the Workfiles to an external drive and resume the job on another machine it finishes perfectly. But as this is only a stupid workaround I'd prefer to get the problem fixed on the i7-PC. I don't know if it's helpful, but here's the *.inf of the project: Code:
[Status] LABEL=HATEFUL_8 VERSION=v0.50.14 SOURCE_SIZE=45326066075 SOURCE_VIDEO_SIZE=44868710400 TARGET_SIZE=24641536000 REDUCTION=.538998783548724 RESIZE_1080=0 RESIZE_1440=0 AUDIO_TO_KEEP=deu;eng;ger; KEEP_HD_AUDIO=-1 SUBS_TO_KEEP=all BACKUP_MODE=0 MOVIEONLY_TYPE=0 USE_LAVF=0 INSTANCES=1 DGDECNV=0 DGDECIM=0 FRIMSOURCE=0 FFMS2=0 SSIF_MODE=0 QUICK=0 ENCODE_STEP=0 COMPLETED=5 REBUILD_COMPLETE=0 [00021] AUDIO=11 PGS=1111 APULLDOWN=0 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=23164774496 RATE=9312 SPLITS=1 NSTART=27000000 NEND=481691734 NSIZE=22350342144 FLINK=0 MLINK=0 [00101] AUDIO=1 PGS=1 APULLDOWN=0 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=305356799 RATE=7194 SPLITS=1 NSTART=27000000 NEND=40449686 NSIZE=302174208 FLINK=0 MLINK=0 [00102] AUDIO=1 PGS=1 APULLDOWN=0 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=462827096 RATE=7196 SPLITS=1 NSTART=27000000 NEND=47371601 NSIZE=457568256 FLINK=0 MLINK=0 [00103] AUDIO=1 PGS= APULLDOWN=0 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=122486465 RATE=5906 SPLITS=1 NSTART=27000000 NEND=33080625 NSIZE=120084480 FLINK=0 MLINK=0 [00104] AUDIO=1 PGS= APULLDOWN=0 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=128735470 RATE=5905 SPLITS=1 NSTART=27000000 NEND=33391875 NSIZE=125945856 FLINK=0 MLINK=0 Code:
[07.01.16] Checking System Settings - BD-Rebuilder v0.50.14 - Windows Version: 6.2 [9200] - Working Path Free Space: 1.806,73GB - AVISYNTH Version: 2.6.0.6, Ok - LAVFILTERS: Ok - AnyDVD settings check: Ok. - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [07.01.16] Systems Settings Check complete |
1st July 2016, 22:47 | #24397 | Link |
@Thaddäus
My best guess would be a permissions issue. It looks like you have plenty of space (1.8TB) Try running BD-RB with admin privileges and see if it goes away. If it does, then adjusting the output folder permissions my fix it. Is D: a USB connected drive? I've seen reports before when there were driver issues on USB connected drives (although I've never actually seen it myself that I can remember). If so, you might want to test setting the working folder to a SATA connected drive just to prove/disprove it as an issue. Last edited by jdobbs; 1st July 2016 at 23:01. |
1st July 2016, 22:58 | #24398 | Link | |
Personally I prefer not to use long paths (and avoid spaces in names). You can try to move your WORKFILES folder directly into the root of d:\ ggtop Last edited by ggtop; 1st July 2016 at 23:01. |
1st July 2016, 23:06 | #24399 | Link |
@ggtop
I haven't given up on your problem. I'm just doing testing to see if I can find a way to repeat it. I'd like to make sure that the new code I added (to allow for hardcoding full subtitles) is clean before I release a new version. Last edited by jdobbs; 2nd July 2016 at 02:38. |
2nd July 2016, 03:57 | #24400 | Link |
What I would try to do is use UsEac3to. Drop in the movie file and see if it accepts the audio track. Choose the LPCM audio track and convert it to another comparable format. For example, if the bit rate is not too high (< or around 640) convert to AC3 @ 640. If the bit rate is substantially higher, convert to 'W64' which is basically LPCM wav also (I don't know if i would actually change it or not) Then, use TSMuxer and remux the video and NEW converted audio back into a BDMV structure. Then, if you need to shrink it further, use BDRB at that point, or if you don't, simply keep it or burn it that way.
